SURVEY: Your watts at various speeds
Get the forum community involved in polls and surveys.
Postby TylerDurden » Sun Dec 13, 2009 8:59 pm
How much power do you use, cruising on the flats?
You don't need to provide figures for all speeds, but more entries are better...
Watts at:
10mph -
15mph -
20mph -
25mph -
30mph -
35mph -
40mph -
45mph -
50mph -
>50mph -
or*
Watts at:
10kph -
15kph -
20kph -
25kph -
30kph -
35kph -
40kph -
45kph -
50kph -
55kph -
60kph -
65kph -
70kph -
>70kph -
Comments regarding your power use on hills (at speeds) are welcome.
A brief description of your system, or a link to your setup would also be helpful. (One post for each vehicle.)
(Having this info in one place could help new folks plan their setups)
*Edit: added for the more advanced civilizations and species. Also, just in case... http://www.sciencemadesimple.net/length.php
Have a Nice Day,
TD
FYI: Adding pictures?
TylerDurden
Re: SURVEY: Your watts at various speeds
Postby amberwolf » Mon Dec 14, 2009 5:12 am
As I am currently gathering data such as this, I'll post it when I have enough to be useful. Right now all I can say is I use typically 30-35Wh/Mile, at around 15-18MPH, on my 300lb (bike+rider) CrazyBike2, with frequent complete starts and stops (usually at least two per mile, and often four to eight, depending on traffic controls and path taken).
CB2 uses a four-pole powerchair motor that is nominally 24V 650W as designed, along with a gearbox reduction built-in. I run it at 36V, and the gearbox output goes via sprocket/chain reduction to about 100RPM max into the bike's regular 18-speed shiftable drivetrain. Most commonly I use only the largest front ring and the lower four or five of 6 rear cassette sprockets.
There is always at least some pedal assist, but not usually much; occasionally there is a lot, when I feel I need the extra push to accelerate very fast (but I am afraid of breaking the drivetrain again so I don't try to push it too hard--the motor can do that all by itself!).
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby deardancer3 » Mon Dec 14, 2009 10:00 am
It has been soooo cold here, but this is what I got for you last week:
0 mph 0 watts.
:oops: d
Chain Drive Advocate
deardancer3
Postby TylerDurden » Mon Dec 14, 2009 10:27 am
"No hurries, no worries"... as watt-meters become more affordable, more people can submit info. This should be an evergreen topic.
The typical prospective EV owner may start with a post like: "I hope to go 30mph for 15mi.". A simulator could roughly predict the power needed, but actual reports with descriptions will give noobs examples of setups they can use for reference.
Have a Nice Day,
TD
TylerDurden
Postby TPA » Wed Dec 23, 2009 5:33 pm
This is the only data I've noted
20mph - 450W
25mph - 700W
35mph - 1700W (at 80V)
270lb me plus about 70lb bike.
Absolutely flat around here, I only go uphill when coming out of a pot hole.
Crystalyte 406 with Clyte controller 24-72v analog.
Bosch 36v fatpacks at 12Ah.
Forge Sawback 5xx Blue.
My Ebike is built with a hub motor purchased from www.ebikes.ca
It has performed flawlessly since it was installed. I cannot
recommend the professional folks there enough.
TPA
Postby Drunkskunk » Sun Jan 24, 2010 11:50 am
I haven't paid too much attention to this in a while. Only remember @15mph, but:
15mph = 200 watts
I'll update later.
Drunkskunk
10 GW
10 GW
Postby TylerDurden » Mon Jan 25, 2010 10:42 am
Tostino posted in a similar thread:
22mph = 374W-440W
45mph = 1575W-2025W*
tostino wrote:Well, my bike while i'm going 25mph on my bike, averaging 22mph on flat land with no wind, I am getting about 17-20 wh/mi.... If i'm blasting about going 45mph, my wh/mile can range from 35-45 wh/mi.
viewtopic.php?f=2&t=15455&p=229463#p229463
*Edit: Revised, as per TPA's post below.
Have a Nice Day,
TD
TylerDurden
Postby TylerDurden » Mon Jan 25, 2010 10:44 am
SoSauty posted...
Bafang:
22mph = 440W
Trek 3700 hardtail MTB
48V Lith-ion 10.5amp hr
25amp C-lyte controller
408 C-lyte
1.5" Schwalabee Marathon tires
cruise control
Clyte:
20mph = 350W
Schwinn 26" MTB
48V Ping 10amp hr
Bafang 8FUN
20amp 36V Shenzen Controller
1.75" Schwalabee tires
spring removed from throttle
SoSauty wrote:My Ping 48V 10ahr batt provides 500W and I get close to 25mi with easy pedalling, maybe 400W Bafang. I weigh 180lbs, and cruise 20-22mph on somewhat level terrain. So, around 20W per mile :) My Lith-ion is a slightly stronger performer, 48V 10.5 provides 525W and will run 30 miles at 19-20mph in the hills with easy pedalling, C-lyte 408 maybe 500W; 17.5W per mile for it :P
Have a Nice Day,
TD
TylerDurden
Postby TPA » Thu Jan 28, 2010 2:13 pm
Extremely skeptical of <1000W at 45mph
40wh/mi at 45mph is more like 1800W.
40 Wh/mi * 45 m/h = 1800W
TPA
Postby hydro-one » Thu Jan 28, 2010 2:54 pm
Come on guys, can we get with the TWENTIETH CENTURY HERE !!!! A LITTLE SI UNITS PLEASE!!!! WTF IS A MPH?????
Make ya guys sound like you were born in a barn!!<---a joke,
Cheers,
Ps: I am collecting data on riding in various snow conditions and temperatures. 20wh/ Km in -25C. Combination of sheer ice and 1-2 inch crusty snow. Big 2.5(6.35cm!) maxxix advantage runing at 30psi(206.7kPa!) 700km so far in the last month!!!!
mike
hydro-one
Postby amberwolf » Thu Jan 28, 2010 6:15 pm
Heck I only used MPH because I couldn't remember the abbreviation for cubits. :P
amberwolf
Postby jag » Thu Jan 28, 2010 10:53 pm
For my 9C Stumpjumper
http://www.endless-sphere.com/forums/viewtopic.php?f=4&t=9549
With slicks:
Max speed around 50km/h at 800-1000W
At 30-35km/h it is about 500W
With new studded tires
Max speed around 45km/h at 1000-1200W
jag
Postby amberwolf » Thu Feb 04, 2010 1:58 am
DayGlo Avenger stats:
Fusin 36V hubmotor kit, 800 successful previous owner miles on it.
36V 9Ah D-type NiMH pack (from a Giant suede-e brand bike). I hadn't been able to fully charge it yet at the time I got this data.
Forgot to note the watts at actual specific speeds yet, but if this data is useful, here it is anyway:
2.5 mile trip to work at typical straightway speeds of 12-16MPH, with around a dozen or more full stops and starts for traffic controls:
42V starting rest voltage
40.47V finish rest voltage
34.32V minimum trip voltage
16.35A peak
22.4Wh (about 9Wh/Mile)
578W peak
0.538Ah
2.5 mile trip home from work at typical straightway speeds of 12-16MPH, with around a dozen full stops and starts for traffic controls. The light was also powered during this trip (had to put electrical tape over it to keep *every single light source* from turning it off!), which takes roughly 70mA extra:
40.68V starting rest voltage
38.64V finish rest voltage
32.01V minimum trip voltage
18.64A peak
23.9Wh (about 9.5Wh/Mile)
616W peak
0.652Ah
amberwolf
Postby liveforphysics » Thu Feb 04, 2010 5:01 am
My bike does roughly 1 (0.94) parsec per petasecond, and uses about half a nano-quad/second of power to maintain the speed.
Quickly jumps to a full nano-quad/sec of power in hills.
liveforphysics
Postby jonescg » Sat Feb 06, 2010 3:54 am
Remind me how many cubits are in a bushel??? Or was that 7 chains to the fathom? :P
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby paultrafalgar » Sat Feb 06, 2010 4:52 am
Hey TD, how about getting the troops to submit a standard format CSV file as an attachment then you can publish a spreadsheet here intermittently. For example,
MemberName, BikeName,SpeedInKph,Whrs,Speed,Whrs,Speed,Whrs,Speed,Whrs...
Just a thought.
If we knew what it was we were doing, it would not be called research, would it? Albert Einstein
A paranoid is someone who has SOME idea of what's going on. Allen Ginsberg(?)
If the greatest pleasure is giving, be selfish - give pleasure.
paultrafalgar
Postby Cold-E-Commuter » Tue Feb 09, 2010 9:31 pm
Here are some fairly typical commute numbers for my set up. WE BL-36 600W front hub on Trek 3700 MTN Bike with total load of rider and bike at 270lbs running on 36V 14Ah SLA pack. Sorry I do not have watts per speed calculations. I hope to get some this week if it stops snowing. Typical ride has 3 or 4 full stops and starts over 8.68 miles so it is wide open most of the time at between 21mph and 25mph.
20 degrees F 8.68 miles 21.7mph avg 40.45V starting 4.293Ah 153.7Wh 23.00A peak 33.76V min 821.3W peak 37.27V stop 19.9Wh/Mi
43 degrees F 8.68 miles 22.6mph avg 40.63V starting 4.095Ah 146.8Wh 22.92A peak 34.21V min 818.2W peak 37.47V stop 18.9Wh/Mi
Trek 3700 MTB
NC2806 in 26" Front Hub on Rockshox XC32TC fork w/ Avid BB7 disc brake
Infineon 12xIRFB4110 mosfet controller
Ebikes.ca SS Dual Torque Arm and CA/DP Large Screen Unit
CA Data Logger w/ GPS
Schwalbe Marathon Green Guard tires 26x1.5 at 70 psi
Cold-E-Commuter
Postby D-Man » Tue Feb 16, 2010 12:43 am
Interesting. An ebike takes double the amount of watts as a road bike at 20mph. At 30mph, it uses 3 times the amount of watts. :roll:
408 front hub
11000+ miles on sla's.
Michelin pilot sport 2.3
Miles 50
Flats 0
Quality posts will not be sold.
D-Man
Postby StevenR » Mon Feb 22, 2010 9:07 pm
I will make a quick post then update it later to keep to the one post per person idea.
I soon will have three complete systems with all interchangeable parts so documenting all the possible combinations is unlikely - although putting some numbers to a 5303 Front/5303 Rear powered by a 120V of series headways/Ping v3 could be fascinating. I will put some numbers to the normal combinations and get more precise as I get some logging in (it's COLD around here yet although I still get 40 miles a week or so). I may try to document temperature variations, as I will surely get them.
Bianci MTB, No Suspension, V-Brakes
26" - 5303 Front
Ping v3 48V20aH
Crystalyte 48V35A Controller
Schwalbe 26x2.3 Big Apple Folding
10 MPH I don't go 10MPH
20 MPH 15 wh-m
30 MPH 30 wh-m
38 MPH 50 wh-m
My editor screws up with text longer than this. I'll edit offline and update: Updated 02-22-2010
Bianchi Alante MTB with C'lyte 5303 Front Hub Motor / Motobecane hardtail MTB with C'lyte 5303 Rear Hub Motor
CT48V35A Controller / method monster 100A100V controller
Schwalbe 26"x2.3" Big Apples / 26" Schwalbe Ice Spiker Pros
Ping v3 48V20aH with 60A v2.5 BMS / Headway 48V10aH BMS used to balance, bypassed on discharge
Pick one from each row above
StevenR
Postby Lyen » Tue Feb 23, 2010 3:00 am
I'm using about 26Whr a mile average with a Super BMC 750W planetary drive & 4P DeWalt DC9360 batteries on a Dahon Cadenza folding bike with modded 700c wheels. :)
Items For Sale
Please sign up here and donate your marrow to save life.
Lyen
Postby TylerDurden » Sat Feb 27, 2010 12:31 pm
JEB posted in another thread:
JEB wrote:On a 6 mile run, same place every time (to stores) I found that if I used 100% battery power it would take 1amp hour per mile @ 24 volts. or 6amp hours for the run. On a sunny day when I was not in a hurry, peddeling away from every stop, and running 12 to15mpr instead of full throttle (20~mph), only 3 amp hours were used for the same trip. Lots of savings using the same wheel size.
http://endless-sphere.com/forums/viewtopic.php?f=3&t=16553
12-15mph = 240W (+ some helping)
20mph = 480W (motor only)
Have a Nice Day,
TD
TylerDurden
Postby swbluto » Sat Feb 27, 2010 12:45 pm
D-Man wrote:Interesting. An ebike takes double the amount of watts as a road bike at 20mph. At 30mph, it uses 3 times the amount of watts. :roll:
Power is cubed to speed according to aerodynamics. So, (30/20)^3 = 3.375 times as much. So, that sounds about right.
An even more interesting fact, 20 mph can go nearly 2.25 times as far as 30 mph. :shock: A 10 mph difference doesn't sound like much, but a 15 mile difference between 15 miles and 30 miles does!
swbluto
10 GW
10 GW
Postby veloman » Wed Mar 31, 2010 11:58 am
It's amazing how efficient a road cyclist is, especially on good racing equipment in a skinsuit. The pros you see on the Tour de France, most of them can ride 30mph in their time trial gear on 400 watts, on a flat, windless road. It sure helps having a 15-18lb bike and having the aero dynamics of a skinsuit and full aero position on aero bars.
I myself, still feel quite efficient on my road bike, it's nice because I can coast and my speed holds pretty well compared to my ebike, which drags down so much faster. I can't really figure it out, I guess it's just a combination of more drag from casual clothes, and more rolling resistance, especially due to the weight. I can roll around at <15mph on smooth pavement for what seems like forever on the roadie, like in a hilly parking lot, just going back and forth, coasting. So efficient, those 1" 120psi tires.
Here's a website some of you may go crazy over: www.analyticcyling.com
Since you have a CycleAnalyst, compare your input wattage to what you calculate you are putt to the wheels on your ebike, going up a known steady % grade hill.
Is there a cheaper alternative to the CycleAnalyst, maybe with less functions?
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby bbushwacker » Wed Apr 14, 2010 2:12 am
It is quite interesting to see that the watts may pretty much stay constant at 1,000 to 1,100W. In case of my ebike this is limited by the CA. You could pull more out of the batteries, but I set 25Amps as the max set for the 10Amp/hr 48V LiFePo4s I got from Justin. As a result, I am drawing an almost constant power out of the pack. Close to max efficiency, the wattage seems to drop a little.
(fast windings nine continent in 26 inch wheel, 25 Amps controller, 48V battery pack = low acceleration, but cruise speed of 43km/hr).
bbushwacker
100 µW
100 µW
Postby dozentrio » Fri Apr 16, 2010 11:19 am
1700 watts @ 55 kph
1900 watts @ 60 kph
numbers are very rough, unfortunately and averaged by my poor heuristic based algorithm (brain). I am running a M1018z at 50V (~38 amps) with final gear reduction of 12.6 or so.
My Turnigy 80-100 bike (40V 120A)
http://www.youtube.com/watch?v=GGc1hF5evVE
dozentrio
Next
Return to Polls & Surveys
Users browsing this forum: No registered users and 0 guests
