after a short hiatus i'm going to build another bike. this time it will be a big delta trike. i will start by using a KHS Manhattan frame.
- stock picture from sales brochure
- 09-trike-3spd-gold.jpg (44.68 KiB) Viewed 3320 times
mine has seen a couple of mods already. but so far they are failed experiments. here is how she looks at the moment.
- 100_1013.JPG (65.63 KiB) Viewed 3312 times
- 100_1015.JPG (70.6 KiB) Viewed 3153 times
Front hub motors on a trike like this are a bad joke. there is so little weight on the front wheel that the motor is constantly fighting for traction. not too bad for flat and level terain in good weather. but not so good when it is wet. also not very good uphill. so that front motor has got to go.
in the past i had also tried a 500W Cyclone kit. but i found the gear box noise to be very annoying. those motors are loud. that is not so bad. but there is something in the pitch or sound of the motor that makes it realy bug me. other than that it worked fine and there was plenty of room to mount it. but i don't want to use one on this bike anymore.
the basics of what i want to do are:
1. add a front suspension.
2. add a differential to the axle so that both wheels can be driven.
3. add disc brakes so that both rear wheels can be used to brake. and they will still work when it is wet.
4. adapt a NuVinci Hub for the transmission.
5. a motor unit that drives through the gears
6. better tires
7. 48V 20Ah LiFePO4 battery pack
8. decent lighting so i can both see and be seen at night.
but i think i'll start with the front suspension. i have a triple clamp fork in mind.
rick
