12 x 4110 MOSFET Extreme Modder Controller LYEN Edition $129
Postby Lyen » Tue Apr 13, 2010 5:16 pm
These are newly hand assembled Infineon 12 FET controllers I am selling, they are new and never used. This is the controller of choice picked by most skilled ES members. Most of the buyers on ES preferred a custom made version for use with their added hall sensors Turnigy and Aston RC motors. The allowed disclosed member names are AussieJester, Hyena, Tmaster, Matt, and others. In fact I have sold most of them before I even have got the chance to advertise. Part of the reason is because the 12 FET is originally a special request item from a member. But word of mouths are making it becomes more popular so I had to make a few extra to meet the demand. The un-advertise 12 FET model EC-124110 12 FET controllers at $129. This controller is meant for easy modification without replacing the MOSFETs to IRFB4110 since it is already equipped. I have programmed the current draw at 45A just for broader commuters but you can easily programming with more current.
The controller is like a wolf in sheep's skin because it is under tuned in order to optimize for long range. There are lots of potential and features you can unveil and twist as you go. You can program functions such as enable power regeneration, regenerate braking, pulse width modulation, low voltage cut-off, interface with a Cycle Analyst, and others. You may also add an USB to TTL adapter and connect to the computer for tuning. (Electronics knowledge is required to unleash the potential however)
One unique feature of this controller is that it has an additional speed sensor circuitry built-in with an extra blue wire for output. It is to be used with the scooter style electric bike and electric scooters that have a speedometer in the dashboard. As of April 13th, 2010 the speed sensor wire has been embedded and integrated with the green wire on the CA connector since they both can share the same function now. More practical and less confusion as suggested by previous buyers. :)
If you look carefully in the photos, you will notice this version also uses lock washers to secure the FETs internally and the heat transfer bar outside to place tension against a nut after tightening. It is also to help prevent the nut from loosening. The FETs will get overheated and damaged when detached from the heat-sink which used to be the case from the previous designs.
* For the extremists, this controller is meant for for easy modification without replacing the MOSFETs to IRFB4110 since it is already equipped. You may double and possibly triple the current output to make it a mighty wonder by adding braids wires (http://www.radioshack.com/product/index ... Id=2062744), and add solders to beef up the circuit board traces and shunt.
However, if you are going to use a 9C (Nine Continent) motor, It is recommended to maximize the current output at 65A due to the thinner gauge wires being used with the hub motor. There is a potential that any current & voltage combination higher than the current 72V @ 65A will melt the phase wires in the hub motor and cause potential damage.
The size for the 12 FET controller is as follow. The end to end is 180mm with the mounting plate. Case end to end is 154mm with screws sticking out on each side. The height & width is same as the 18 FET one at 87 x 45mm.
Below is the specification:
Model: EC-124110-LYEN EDITION
Start immediate controller
Chipset: XCKJ8B116A (same chipset being used as in the 18 FET controller)
Circuit board version: EB812XC-A-B
12 x genuine IRFB 4110 MOSFET N-CH 100V (tested up to 110V before damage) for more information about the FET, click the link below:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=IRFB4110PBF-ND)
72V battery optimized (for higher or lower voltage & current such as 24V-100V, you may need to change the resistor network to avoid damage to the LM317 linear voltage regulator)
45A is the current rate (for higher current, you may need to beef up the trace, shunt, and reprogram it via the software)
Low voltage cut-off: 62.5v
Battery and motor phase wires gauge size: 12AWG (High voltage capable wires equipped)
Dimension: 6.2" x 3.4" x 1.75" (155mm x 87mm x 45mm) plus mount extensions
Total weight: 515 gram
I have only 50 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it now and upgrade later once your piggy bank is filled up if needed. :lol:
$129 USD free ground shipping in the United States & Canada. For other locations, please PM or email me at LYEN@HOTMAIL.COM. I accept PayPal, cash or money order. The controllers will be shipped out from me in San Francisco, California, USA. I will provide a tracking number and ship it out as soon as I have received the fund.
For only $10 more, I can include the the following:
1. CA connector
2. Regenerative enable/disable (Enabled simply by connect the wires together without the need to open the case)
3. USB-TTL 5 pin connector (for use with the USB-TTL adapter that is sold separate)
I also have the USB-TTL adapter for adjust and alter the controller settings on your computer. It has the extra 5 pin plug and a "SEND" button. It is also compatible with Windows XP/Vista/7 32/64 bit operating system (real 32/64bit drivers). $15 with purchase, $20 if purchased separately.
You may click on the PayPal Buy It Now link below. For accessories, please send money via PayPal or send me a private message for the total price. Thanks!
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=YNLY2YNCWHLXG
If you are not satisfy with the results or if it is too fast for you, you may send it back to me within 30 days in an unmodified condition.
Update: May 2nd, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, 96V and other battery settings upon request.
Quantity updated as of 2/7/2013: 49 left (buyer bought 1 from Zwingenberg, Germany )
Quantity updated as of 2/11/2013: 48 left (buyer bought 1 from Santa Cruz, CA )
Quantity updated as of 2/14/2013: 47 left (buyer bought 1 from Ternopil, Ternopilska, Ukraine )
Quantity updated as of 2/14/2013: 45 left (buyer bought 2 from Saint-Petersburg, Russia )
Quantity updated as of 2/16/2013: 42 left (buyer bought 3 from Moscow, Russia )
Quantity updated as of 2/19/2013: 41 left (buyer bought 1 from Santeramo in colle, Bari, Italy )
Quantity updated as of 2/18/2013: 40 left (buyer bought 1 from Toowoomba, Queensland, Australia )
Quantity updated as of 2/18/2013: 39 left (buyer bought 1 from Hatfield, Hertfordshire, United Kingdom )
Quantity updated as of 2/27/2013: 38 left (buyer bought 1 from Thamesmead, London, United Kingdom )
Quantity updated as of 2/28/2013: 37 left (buyer bought 1 from Lanester, France )
Quantity updated as of 2/28/2013: 36 left (buyer bought 1 from Maria Enzersdorf, Austria )
Quantity updated as of 2/28/2013: 35 left (buyer bought 1 from Bettystown Co. Meath, Ireland )
Quantity updated as of 3/6/2013: 34 left (buyer bought 1 from Suanluang, Bangkok, Thailand )
Quantity updated as of 3/7/2013: 33 left (buyer bought 1 from  Netanya, Israel )
Quantity updated as of 3/11/2013: 32 left (buyer bought 1 from Haifa, Israel )
Quantity updated as of 3/11/2013: 31 left (buyer bought 1 from CHERNIGOV, UA, Ukraine )
Quantity updated as of 3/11/2013: 30 left (buyer bought 1 from Bad Wörishofen, Germany )
Quantity updated as of 3/14/2013: 29 left (buyer bought 1 from Encino , CA )
Quantity updated as of 3/16/2013: 28 left (buyer bought 1 from Albany, Western Australia, Australia )
Quantity updated as of 3/17/2013: 27 left (buyer bought 1 from Lake Forest Park, WA )
Quantity updated as of 3/19/2013: 26 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 3/21/2013: 25 left (buyer bought 1 from Nooksack, WA )
Quantity updated as of 3/23/2013: 24 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/25/2013: 23 left (buyer bought 1 from Corona, CA )
Quantity updated as of 3/25/2013: 22 left (buyer bought 1 from Elmira, NY )
Quantity updated as of 3/28/2013: 21 left (buyer bought 1 from Moscow, Russia )
Quantity updated as of 3/28/2013: 18 left (buyer bought 3 from Austin, TX )
Quantity updated as of 4/1/2013: 17 left (buyer bought 1 from Palm Bay, FL )
Quantity updated as of 4/4/2013: 16 left (buyer bought 1 from London, United Kingdom)
Quantity updated as of 4/5/2013: 15 left (buyer bought 1 from St-isidore-de laprairie, Quebec, Canada)
Quantity updated as of 4/7/2013: 14 left (buyer bought 1 from Barrie, Ontario, Canada)
Quantity updated as of 4/9/2013: 13 left (buyer bought 1 from Wimborne, Dorset, United Kingdom)
Quantity updated as of 4/9/2013: 10 left (buyer bought 3 from Warrandyte, Victoria, Australia )
Quantity updated as of 4/13/2013: 9 left (buyer bought 1 from Dover, Kent, United Kingdom )
Quantity updated as of 4/16/2013: 8 left (buyer bought 1 from Orono, ME )
Quantity updated as of 4/16/2013: 7 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 4/17/2013: 6 left (buyer bought 1 from Santiago, Metropolitana, Chile )
Quantity updated as of 4/18/2013: 5 left (buyer bought 1 from Bad Wörishofen, Germany )
Quantity updated as of 4/18/2013: 4 left (buyer bought 1 from Green Bay, WI )
Quantity updated as of 4/21/2013: 3 left (buyer bought 1 from Broadbeach, Gold Coast, Australia )
Quantity updated as of 4/22/2013: 2 left (buyer bought 1 from Velserbroek, Netherlands )
Quantity updated as of 4/25/2013: 1 left (buyer bought 1 from Nafpaktos, AITOLOAKARNANIA, Greece )
As for the maximum testified and successful current. Below are the buyers that can tell you the truth. :)
Sent: Tue Mar 30, 2010 6:55 pm
by cord
Lyen,
I just wanted to let you know that I soldered the shunt and took the bike out for a
spin with the battery at 96v. I was seeing 85A during acceleration and my peak amps read 147A! This was on a stand alone CA. The controller wasn't even warm, but the 9C was! I promise I'll try not to blow up your controller, thanks again!
-Cord
Sent: Tue Mar 30, 2010 9:54 am
by TMaster
Hey Lyen Lyen! Controller is working excellent! I was thinking of looping the Regen loop wire onto a swtich, so I could manually turn the regen off and on, on the bike. What EBSlimvoltage should it be set at for a 72.6V pack? ALso I have my LVC at 52v. Let me know thanks man! The BIKE IS AWESOME!!! I passed a truck yesterday, and I had a nice tail wind and got up to 44mph on the strait. LOL. 95 amps.
Also, please see the review and technical upgraded detail information from TMaster below:
http://endless-sphere.com/forums/viewtopic.php?f=2&t=17680
http://endless-sphere.com/forums/viewtopic.php?f=4&t=17679
Additional accessories (prices are reflected with controller purchase only. Please contact if you are interested to buy without controller):
$15 throttle (full/half/thumb) with mated left rubber grip (very good quality) (ebikekit retails @ $36)
$19 cruise control (manually installation required)
$15 three way speed switch (manually installation required)
$15 PAS - Pedal Assist System add-on (manually installation required)
$15 electric brake levers a pair
$29 motor/controller hall/phase/throttle tester
Last edited by Lyen on Thu May 02, 2013 11:41 am, edited 117 times in total. View post history.
Items For Sale
Please sign up here and donate your marrow to save life.
Lyen
Re: 12 x 4110 MOSFET Extreme Modder Controller LYEN Edition
Postby Ypedal » Tue Apr 13, 2010 7:48 pm
Alrighty.... i'll have one of those ! 8)
:P
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby Hyena » Tue Apr 13, 2010 9:07 pm
Yep another testimony from me, with heavily upgraded traces and a slightly modded shunt I saw peaks of 125 A bumping my output to 10kw!
The good thing is it's easy to then back it off in the software, if you have no self control and need to go more than 10km on a charge :lol:
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
10 GW
10 GW
Postby mdd0127 » Tue Apr 27, 2010 10:13 pm
I got mine last week! I've been to busy to do anything with it but I can't wait. My little motor looks scared sitting next to it. It looks awesome. The packaging was also first rate. Thanks so much!
I'll post more when I get time to play.
Turn it OFF!!!
Appocaloptimist! (thx Kiwi!)
mdd0127
Postby SkyCaptain » Thu Apr 29, 2010 10:32 pm
Hi.
Has anyone managed to get this controller to work on a goldenmotor hub?
I have the controller here, and just cant seem to get it running right with my goldenmotor hub.
I have tried all of the phase wire combinations, and tried swapping the hall wires around.
The best combination I can find, the motor runs smooth/sounds okay, but has NO torque at all.
The other combinations motor spins backwards, or doesnt move, or makes strange noises.
Please help, I have spent a few days now tring to get it to work.
Thanks.
SkyCaptain
Postby Lyen » Thu Apr 29, 2010 11:08 pm
SkyCaptain wrote:Hi.
Thanks.
Hi Andrew!
I am sorry to hear that you are having difficulties to get the hall and phase wires to match up. Please resend a detail photo of your existing Goldenmotor controller to narrow down the phase and hall sequence. The last picture that you took was out of focus and therefore I cannot read the labels out of the circuit board.
You may reference to this thread that has mentioned the "The colors on the motor side of the phase is different on the blue and yellow cause the motor is golden motor. ". So the phase sequence should be blue green yellow on the motor side to yellow green blue on the controller side.
Please see below:
http://endless-sphere.com/forums/viewtopic.php?f=6&t=15690&p=243986&hilit=+golden+motor+color#p243986
I appreciate if anyone here can make out the wiring color sequence from the out of focus pictures that SkyCaptain sent fro his Goldenmotor controller below:
Please also request the hall sensor/phase wire sequence from the Goldenmotor forum below:
http://goldenmotor.com/SMF/index.php?PHPSESSID=d2f406d2465edeba0687db71755f8410&
I the meantime, I will continue to troubleshoot the issue with you via email. I appreciate your time and patient. :)
Best Regards,
Edward Lyen
Items For Sale
Lyen
Postby Hyena » Thu Apr 29, 2010 11:37 pm
You need to switch the blue and yellow phase wires for the GM hubs.
So
Green - Green
Blue - Yellow
Yellow - Blue
I can't remember the hall wiring, I suspect it may be the same but that narrows it down alot for you. Mine is soldered and headshrinked so I can't check but thats definitely the right phase combo for Lyen's 12 fet and a GM hub.
Hyena
10 GW
10 GW
Postby Lyen » Fri Apr 30, 2010 12:34 am
Hyena wrote:You need to switch the blue and yellow phase wires for the GM hubs.
So
Green - Green
Blue - Yellow
Yellow - Blue
Hyena, thank you very much for the info. Hopefully it does help him who is also resides in Australia. I appreciate it.
Cheers!
Lyen
Items For Sale
Lyen
Postby TMaster » Sat May 01, 2010 12:22 am
Im using this controller and a GM replica, and I have the Green and yellow switched on the phase wires and the halls.
Specialized HR - 75 lb's
A123 26650M1 23S3P(75.9V Nominal - 81.5V Hot) 7500W+ / 10 hp+
Infineon Lyen 12 Fet/45amp controller heavily modded pushing 110 Amps peak
Golden Motor/9C replica upgraged phase wires
TMaster
Postby Arlo1 » Sat May 01, 2010 2:47 pm
Sweet!
And Dave who has some good deals on STUF
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby olaf-lampe » Sun May 02, 2010 11:36 am
Hi Lyen, master of MOSFets :D
I was looking for 4110 on the bay and found some very cheap ones from Hong Kong. There are rumors of faked chips going round.
Do you know how to identify the good ones?
Thx
Olaf
olaf-lampe
Postby Arlo1 » Sun May 02, 2010 1:34 pm
olaf-lampe wrote:Hi Lyen, master of MOSFets :D
Thx
Olaf
Methods has it posted someware but I think its the color of the metal on the back the coper ones are the good ones I THINK?
Arlo1
Postby MrKang » Mon May 03, 2010 7:23 am
Thx
Olaf
Hi arlo,
These ones are the originals. i just orderedthem for my broken controller.
http://cgi.ebay.nl/5x-MOSFET-IRFB4110-100V-120A-N-Ch-7th-Generation-5-pcs-/220507344948?cmd=ViewItem&pt=Bauteile&hash=item3357431034
MrKang E-Scooter : 24V 750W Bosch Motor modified with YK-43 48V 1kW on 12S6P Lipo - top speed 44kmph
Xinling XTD800A : LYEN 4110 72V (modified for safe 100.8V with extra cooling) - 24S4P/100.8V 25Ah Turnigy + CA with Datalogger + SOUNDSYSTEM + USB power outlet + 78km top speed(120%)
MrKang Retro II : in progress.. ** 12FET MKII LYEN + 28S 20AH LifePO4 cells **
Project link [/color]: http://endless-sphere.com/forums/viewtopic.php?f=10&t=13442
MrKang
Postby Lyen » Mon May 03, 2010 2:14 pm
Here is one of the best thread to read regarding counterfeit MOSFET from Methods. He is also one of the person who has really helped me a lot in the past. :)
Detecting Counterfeit 4110 Mosfets:
http://endless-sphere.com/forums/viewtopic.php?f=2&t=10655&start=0&hilit=counterfeit
Lyen
Items For Sale
Lyen
Postby Ypedal » Tue May 04, 2010 7:00 pm
Yesterday mailman delivered this !!
Ouch !!!
(37.94 KiB) Downloaded 3093 times
Ypedal
Postby Ypedal » Tue May 04, 2010 7:06 pm
But !!! the Lyen packaging prevails ! 8)
(40.48 KiB) Downloaded 350 times
Ypedal
:wink:
(62.24 KiB) Downloaded 350 times
Ypedal
Postby Ypedal » Tue May 04, 2010 7:07 pm
Fancy !
(43.05 KiB) Downloaded 349 times
Ypedal
Postby Ypedal » Tue May 04, 2010 7:08 pm
Thanks Man !!!!..
Great to see proper labeling !
(47.86 KiB) Downloaded 349 times
Ypedal
Postby AussieJester » Wed May 05, 2010 2:59 am
Testament to Mr Lyens packing YPedalz MaN, he had 7 foot of bubble wrap in the consignment he sent me, and a bucket load of foam noodles, was only two 12 fet controllers in the box haha
KiM
AussieJester
Postby MrKang » Mon May 10, 2010 3:52 am
I received my LYEN controller and have some questions about the programming software.
i downloaded the parameter setup and i see 2 programs. the 116 and the 8 version
Which one do i have to use ?
MrKang
Postby Lyen » Mon May 10, 2010 3:56 am
MrKang wrote:I received my LYEN controller and have some questions about the programming software.
It is the 116 version. PM you the info. Thanks for asking! :)
Regards,
Lyen
Items For Sale
Lyen
Postby sandman » Tue May 11, 2010 4:36 pm
Lyen
I am connecting the LVC wires from Gary/Fechter's BMS to the throttle signal and ground. Is there a satisfactory limiting resistor inside your 12 fet and 9 fet controller, or should I put a 1K resistor on the controller side of the connection?
Also, if I set up my Cycle Analyst for current control as shown on page 19 of the Vers 2.2 manual, do I need to make any changes to the aforementioned LVC - resistor connection. They are both in the same throttle signal wire.
Sandman
sandman
10 µW
10 µW
Postby Lyen » Wed May 12, 2010 4:07 pm
sandman wrote:Lyen
Sandman
Hi Sandman!
Thanks for your interest in the controller! Although there are already resistors build-it to protect the regulator, it would be best to place the addition 1K resistor between the BMS & controller to play safe due to designs.
As for the Cycle Analyst, the controller does works straight with the Cycle Analyst direct plug-in version without adding the 1K resistor to the aforementioned LVC - resistor connection. :)
Regards,
Lyen
Items For Sale
Lyen
Postby auraslip » Fri May 14, 2010 6:51 pm
What is shipping time like? My controller burned up, and I am left stranded.
I am willing to pay for express shipping. Are you in the states?
auraslip
1.21 GW
1.21 GW
Next
Users browsing this forum: J Barrie Wilkinson, Michall2008, spinningmagnets and 5 guests
