Under RC motors... add Scorpion:
http://www.scorpionsystem.com/...motors and controllers etc... like this:
Specifications
Stator Diameter 42 mm (1.65 in)
Stator Thickness 25 mm (0.98 in)
No. of Stator Arms 12
No. of Stator Poles 8
Motor Wind 10 Turn Delta
Motor Wire 1-Strand 1.3 mm
Motor Kv 610KV RPM/Volt
No-Load Current (Io/10V) 1.79 Amps
Motor Resistance (RM) 0.017 Ohms
Max Continuous Current 80 Amps
Max Continuous Power 3000 Watts
Weight 390 Grams (13.76 oz)
Outside Diameter 51.4 mm (2.02 in)
Shaft Diameter 5.98 mm (0.24 in)
Body Length 52.6 mm (2.07 in)
Overall Shaft Length 92.2 mm (3.63 in)
Max Lipo Cell 10s
Max Peak Current 130A (5 seconds)
Max Peak Power 4800 Watts (5 seconds)
Weight including packaging
550g
tks
Lock
