Show off your lipo setup!
Postby moostrodamus » Sun Apr 25, 2010 7:16 am
I want to build a lipo setup with some RC packs. In researching I realize there are a lot of options with regards to rc packs, chargers and balancers...
Show off your pack! What charging method do you use, what cells, what chargers etc. Include some pics if you can...I don't read so good!!!
Moos
Commuter: Crystalyte HS3540
Infineon 40 amp controller
Ping V2.5 48v 20ah
moostrodamus
Re: Show off your lipo setup!
Postby Metallover » Sun Apr 25, 2010 10:35 am
I run six 5ah turnigy packs at either 66.6v (or 44.4v if I desire). I charge them with a hyperion eos0610i charger. I need to charge them as a 30ah 6 cell pack, and I charge and balance them induvidually every few cycles. The charger is rated for 250w output and has a built in balancer. There is a charger link feature; if you have two identical chargers you can charge 12s packs at 500w. The biggest downside of one charger is the 6s max lipo capability.
Add your bike to the Unofficial E-Bike Garage! - http://spreadsheets2.google.com/ccc?key ... OWcg&hl=en
Novara Buzz FS MTB- 18s 15Ah Turnigy Lipo - 12Fet controller @57A - 9C 2807 motor - 600W charging - 4500W peak - 40Mph - 20Mi range
Metallover
Postby Bazaki » Sun Apr 25, 2010 3:10 pm
Metallover wrote: The charger is rated for 250w output and has a built in balancer. There is a charger link feature; if you have two identical chargers you can charge 12s packs at 500w. The biggest downside of one charger is the 6s max lipo capability.
Do you mean you put 2 chargers in Serie to the 12S pack ? Would that work 100% ?
Would it also be possible to put 2 indentical chargers in parallel ?
http://www.elektrischeMTB.nl/
Ebike parts and more
Bazaki
Postby Metallover » Sun Apr 25, 2010 3:31 pm
This feature is specific to hyperion chargers. You might be able to hook other chargers together, but I don't know anything about that.
This is what I am talking about. The chargers hook together with a little cable that just sends data.
Metallover
Postby Battboy » Sun Apr 25, 2010 5:03 pm
Do you ride your bike with these Lipo Packs exposed like you show in the picture?
DH
Battboy
Postby Metallover » Sun Apr 25, 2010 5:25 pm
ATM I have a towel I wrap around them and I duct tape that to secure it.
The way I mounted the batteries,, It takes some work to make a nice enclosure. If I plan to leave the bike locked up in public, I'll really need something pedestrian-proof. I am working on a better enclosure, ideas welcome. The one I have right now, I don't think it'll work out because I dont have access to a welder. :|
Metallover
Postby wasp » Sun Apr 25, 2010 6:37 pm
Metallover wrote:ATM I have a towel I wrap around them and I duct tape that to secure it.
lmao...
look at some of the vinyl rain pipe for houses they make cheap bat housings and no welding required
nice bike to
wasp
Postby AussieJester » Sun Apr 25, 2010 7:33 pm
I (currently will be increasing) use 6x22v 5000mah 20c Turnigy packs 44v 15ah
weight is 11 pound or 5kilo. I use GGoodrum parallel adapter boards (see sig for link)
Here's a pic of my pack
And the cable I made to parallel the packs in series.
I use a meanwell 320-48v PSU to charge the pack (in series/parallel config) and a Battery medic to balance (will soon
have GGoodrum charge controller and battery medic mod .see link for these also)
Lipos are housed in a custom fiberglass enclosure i made.
(184.16 KiB) Not downloaded yet
Turnigy meter is used to monitor battery during riding
KiM
AussieJester
Postby moostrodamus » Mon Apr 26, 2010 3:17 am
Thanks Metallover & AussieJester ,
Pics of connections and chargers help alot, I can SEE how stuff gets hooked up...just the way my brain works.
Moos
Ping V2.5 48v 20ah
moostrodamus
Postby ryan » Sat May 07, 2011 6:40 pm
I think this thread ended too soon. I'd love to see more.
Marin DH Electric Mountain Climber. Crystalyte 5304. 72v20Ah (Dual 36v20Ah 12S2P LiFePO4 Headways). 18 FET Low RDS MOSFET Overclocker Ready LYEN Controller. (See Build Thread)
ryan
Postby AussieJester » Sat May 07, 2011 8:10 pm
Since you asked...Here's my new bikes 12s 2p (44v 20ah) LiPO setup...Using 3mmx~8mm thick copper bus bars too parallel/series the main pack
leads. The balancing leads are parallel ed using modified GGoodrum parallel adapter boards available from http://TPPacks.com
Here's some pics of the construction-->
The parallel leads and main charging leads are then connected to a DB25 connector for easy connection to the Hyperion 1420i
charger. I can then bulk charge at ~50V with simultaneous balancing... Main pack leads run via a 12v 400amp capable
battery isolation switch before bolting to another small set of buss bars where additional wires are added for powering
dc/dc converters etc etc...Apologies no pics of this part of the setup at the time i had no access to camera mine failed
not long after taking the bus bar pics.
Hope this helps :-)
KiM
AussieJester
Postby dogman » Sun May 08, 2011 5:38 am
A mo bettah way to carry some lipo on a mongoose blackcomb.
At this time, I actually have a smaller box on the mongoose, which carries 72v 10 ah. But the key element is something a bit more protective than some tape and a towel.
Every time I see lipo just taped to the frame I cringe. I'll assume AJ just left out the pic showing his side covers that protect the batts and beautify the bike.
Here's my charging rig.
A 350 watt power supply runs the two 8s 150 watt chargers. With paralell adapters, I can charge the whole pile shown at once. Usually though, I charge them in paralelled pairs, so two pairs at a time.
dogman
Postby rscamp » Sun May 08, 2011 8:25 am
Some pics...
Table devoted to battery charging/maintenance
Battery Charging Table.jpg (19.53 KiB) Viewed 2394 times
Some older hobby chargers
Orbit Microlader Pro and TP1010C Chargers.jpg (27.34 KiB) Viewed 2385 times
Hyperion 1420i with extended balance cables
Hyperion 1420i With Balance Cable Extensions.jpg (24.43 KiB) Viewed 2385 times
27V 1000W Power supply for Hyperion
Meanwell 27V 1000W Power Supply.jpg (22.38 KiB) Viewed 2385 times
Power resistors for battery testing
Power Resistors.jpg (27.25 KiB) Viewed 2385 times
Battery pack for ebike - made with heat shrink and aluminum reinforcements for corners
Battery Pack.jpg (17.35 KiB) Viewed 2394 times
Battery installed in ICE trike
Rob
Trice QNT with Astro 3215 8T & V4 Drive
Trice Q with eZee (EZ-R-09001-32)
rscamp
Postby rui_fujino » Thu Feb 02, 2012 12:07 pm
I've noticed this thread hasn't been used for a while but since I got new lipo setup completed I thought I'll post them here!
I think it helps new lipo users to see what we do is working here on pictures rather than them asking what to do and telling them what to do...
Here is my 20s2p setup. I'm using 8X5s turnigy packs and I have paralleled balance charging tabs for balance charging with battery medics
This is battery medics when its bulk charging to keep all the cells balanced
BMSBattery charger on the back for bulk charging
Project 1: Apollo slant hard tail MTB 52v lifepo4, conhismotor, 52T-11T gearing 39.6mph top speed (with pedal)
Project 2: Diamondback s:10 Full suspension 20s2p (83.5v 10ah Lipo), 35kg, HS3540 sensored (MethTek), 12FET lyen controller, Bulk 600w balance charger.
Top speed 45mph(72.4km/h)
Project 3: DOPPELGANGER d2 Visceral
Project 5 Specialized Epic20s2p (83.5v 10ah Lipo), 30kg,HS3540 sensored (MethTek), 12FET lyen @ 50A
rui_fujino
Postby kfong » Thu Feb 02, 2012 1:45 pm
Go with the 1420i and you can go as high as 28S when 2 are networked together. Best charger for ebike use that I have found.
Metallover wrote:This feature is specific to hyperion chargers. You might be able to hook other chargers together, but I don't know anything about that.
kfong
Postby emergence » Wed Feb 08, 2012 3:07 am
This is a great thread for us Lipo newbies. Please keep posting!
Also re charging I'm still pretty confused about the whole process. I take it if you want to have a single plug solution for charging then you need to make up a series to parallel adapter like AussieJester, disconnect (or use a switch) the pack from your speed controller including the series connections, then plug the parallel connector into the charging rig.
Thanks everyone!
emergence
Postby emergence » Wed Feb 08, 2012 3:38 am
And I just spotted this which should answer a lot of questions:
http://endless-sphere.com/forums/viewtopic.php?f=14&t=23551
emergence
Postby amberwolf » Wed Feb 08, 2012 3:45 am
emergence wrote:I take it if you want to have a single plug solution for charging then you need to make up a series to parallel adapter like AussieJester, disconnect (or use a switch) the pack from your speed controller including the series connections, then plug the parallel connector into the charging rig.
Nope. You can use a setup like Method's HVC/LVC built into your pack, and just bulk charge at the same voltage and configuration you ride at. Every so often if you like you can check balance at each of the paralleled balance plugs on the little boards, using your choice of devices from multimeter to Battery Medic or whatever. If they're out of balance enough to warrant it, then use the BM or something like it to manually balance the cells.
If you're not running them down very far most of the time, they're likely to stay in balance pretty well if they were already cycled and tested good and equal to each other to start with.
But if you like, you can also do parallel-series conversions for each charge...it just adds a slight-to-great potential for disasters like SoSauty's (where the entire pack was destroyed because of an accidental cross-connection), depending on how you setup your changeover from charge to ride and back. It's possible to essentially idiot-proof this kind of setup, and not all that hard to do so. But if you don't do that, then it's possible to misconnect things and cause bad stuff to happen. ;)
I'm sure it's possible to cause bad stuff the other way, too, but I suspect it would happen less often and be less disastrous.
So far all I have had to do is bulk charge, but I don't take the pack down very far, and the one I'm using at the moment isn't RC LiPo, but soon I will be using that, too.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby neptronix » Wed Feb 08, 2012 4:43 am
emergence wrote:This is a great thread for us Lipo newbies. Please keep posting!
Thanks everyone!
Depends on your setup entirely. If you're running up to 14S ( ~52v nominal ), a hyperion 1420 will allow you to charge everything in series.. or even better, balance charge it all..
neptronix
Postby emergence » Wed Feb 08, 2012 5:55 am
Yes, sorry I was thinking of 50v plus charging where you get more cells in series than hobby chargers can handle.
amberwolf wrote: You can use a setup like Method's HVC/LVC built into your pack
Thanks that sounds good, will search it out.
emergence
Postby Farfle » Wed Feb 08, 2012 12:33 pm
Heres my battery setup, 24s3p of turnigy nano-tech 50c packs. First wrapped in fiberglass tape to prevent expansion, then a layer of aluminum is added to the top and bottom, then the whole thing is wrapped in gorilla tape. it measures exactly 4"x12"x6" .Everything battery side is wired with triple paralleled 10 awg, and everything motor side is single 6awg. Its all charged with a ggoodrum/fechter "lite" BMS mated to a pair of 48v meanwells.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby corkscrew » Wed Feb 08, 2012 3:55 pm
I have 8 6S 5amp/hr batteries in a 44.4 20amp/hr setup.
8 mount on either side of my trike in stainless steel battery boxes. 4 batteries on each side make for two 6S 20amp/hr packs. They are paralleled together with a anderson connector harness I made, and some 6S balancing harnesses from progressiveRC. A serial adapter cable connects the two packs, turning the pack into a 12S 20amp hour pack. Charging and balancing are done with a Hyperion 1420 charger, and GGoodrum's 12S one plug charger kit. So every time I charge, I make one connection, and it charges and balances for me.
I have room to add another two bricks per side, which would give me 44.4V (49ish off the charger) and 30 amp hours.
I just recently broke the pack down after about a year and over 1000 miles. When I checked each battery individually they all were still within .03 of each other. Only broke it down because the chain chewed through some of my balance wires, and was causing wonky readings @ the charger. Just need to decide if I'm going to order another 4 batteries, or seal it all back up again with new heat shrink.
This photo, despite it's crappy quality shows the new longer parralleled balance harnesses I built. Basically just extended the Progressive RC harnesses to eliminate a JST-XH connection, and give a little more distance. You can sort of see the one plug going from the batteries to the charger.
Here is her all put together. You can see the one plug charge kit hanging off the battery box.
Actionbent T1 Tadpole Trike - 2806 9C Motor in a 700C wheel. 30AH 48v LIPO powered!
--Build thread: viewtopic.php?f=3&t=26520
corkscrew
Postby emergence » Wed Feb 08, 2012 4:19 pm
Farfle wrote:Heres my battery setup, 24s3p of turnigy nano-tech 50c packs. First wrapped in fiberglass tape to prevent expansion, then a layer of aluminum is added to the top and bottom, then the whole thing is wrapped in gorilla tape. it measures exactly 4"x12"x6" .Everything battery side is wired with triple paralleled 10 awg, and everything motor side is single 6awg. Its all charged with a ggoodrum/fechter "lite" BMS mated to a pair of 48v meanwells.
Thanks Farfle, that's a lot of grunt! what is the advantage of using the high C nanotech packs when, as far as I can work out 20c packs in 24s will still put out enough watts and amps to destroy any ebike hub and the wiring too? Voltage Sag?
And thanks for the pics, they really help. Nice build!
emergence
Postby Farfle » Wed Feb 08, 2012 5:24 pm
North of 25 kw a 20c turnigy pack will sag like crazy at only 15ah. The high c rate packs just help reduce the voltage sag. and yes, this will destroy any ebike motor, but im not exactly running a normal ebike motor :twisted: :twisted:
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby boppinbob » Wed Feb 08, 2012 6:01 pm
20s1p zippy's in a removable battery box so I can easily charge on or off the bike.
Project bike-Genesis v2100, Crystalyte HS 3540 with 72v40A controller and four 5s8Ah zippy lipos in series.
boppinbob
Next
Return to Battery Technology
Users browsing this forum: dogman, Lu.Sochr and 9 guests
