NOT-YOUR- GRANNY Trike build.
Re: NOT-YOUR- GRANNY Trike build.
Postby AussieJester » Sat Feb 27, 2010 2:21 am
rkosiorek wrote:doesn't take much for a wheelchair to get stuck in the snow.
rick
Or sand hahaha..going up stairs and sand, biggest PITA for wheelchairs... OH..hills doable but not so enjoyable either...
Personally I hope your snowed in for a few weeks so we can see this u-beaut trike come together hehe :mrgreen:
KiM
Your avatar reminds me of a trike i came across when researching building my first trike -->
(195.83 KiB) Downloaded 27 times
And this one, first decent hybrid effort i have come across-->
(109.07 KiB) Downloaded 23 times
(120.32 KiB) Downloaded 20 times
AussieJester
Postby rkosiorek » Sat Feb 27, 2010 7:28 am
i wish i had the trike in the avatar. alas it is just a photo i downloaded from the net. it is gas only. but i really like the simple lines. i'm just using it for inspiration til i get my own done.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Mid-Drive Nuvinci
Postby rkosiorek » Sun Mar 28, 2010 10:51 pm
finally. after a month of running down parts, making drawings and other things i'm getting back to working on the trike. i'm still working on building parts for the rear axle. the first assembly i completed was the mid- drive version of the NuVinci hub.
the drive side. 20t freewheel with a 27t fixed sprocket
on the input side i have a 20t freewheel that will be attached to a 44t chainring at the cranks. it is threaded on to the NuVinci input adapter. beside it is a 27t sprocket that is welded to the back of the NuVinci adapter. i have a machined washer between the two so there is enough room for both chains. the 27t will go to a 13t freewheel on the output shaft of the motor unit.
rear view
this is how it looks from the back.
20t sprocket added to output side of hub
i drilled a few holes in a 20t sprocket and mounted it to the disc brake adapter on the output side of the NuVinci. this sprocket will attach through another chain to a 20T sprocket that will be mounted on the rear axle differential.
next step is to finish work on the differential.
rick
DISCLAIMER:
rkosiorek
RAW Differential
Postby rkosiorek » Sun Mar 28, 2010 11:26 pm
still some machining to do but here are most of the parts for the differential.
stripped apart
still need to drill a few holes and machine up the axles.
rick
DISCLAIMER:
rkosiorek
Postby 02jze » Wed May 05, 2010 11:19 pm
Need an update on this.
02jze
Postby rkosiorek » Thu May 06, 2010 8:05 am
02jze wrote:Need an update on this.
i need to start working on this again. i have spent most of the last month adding a quick change tool post to the lathe and making some tool holders for it. so thanks for the kick in the pants. now i feel guilty and neglectful.
rick
DISCLAIMER:
rkosiorek
Postby rkosiorek » Fri Jun 04, 2010 7:23 pm
Well, after much procrastination and other crap. i finally cut a couple of plates from aluminum to trial fit the NuVinci CVT hub.
left hand side
rear view
NuVinci CVT computer
with a couple of minor adjustments it fits. and since i'm using this as a mid drive there will be 3 chains going to it. Whoopee!! it looks like i have enough clearance for all 3 of them.
rick
DISCLAIMER:
rkosiorek
Postby rkosiorek » Sat Jun 05, 2010 3:51 pm
although the differential would fit the axle, there was no way to assemble the rear end. so out came the hacksaw.
now i just have to make up some bits so i can connect both halves of the rear end again.
rick
DISCLAIMER:
rkosiorek
Postby rkosiorek » Sat Jun 05, 2010 3:54 pm
seing as how i had it mocked up anyways. i figured i'd see how it looked with the wheels on.
rick
DISCLAIMER:
rkosiorek
Postby Quajochem » Sat Mar 10, 2012 12:15 pm
UPDATE ??
:lol:
Quajochem
Postby hillzofvalp » Fri Apr 13, 2012 1:10 pm
Lol
hillzofvalp
Previous
Users browsing this forum: electricbandit and 10 guests
