by rkosiorek » Sun Mar 28, 2010 10:51 pm
finally. after a month of running down parts, making drawings and other things i'm getting back to working on the trike. i'm still working on building parts for the rear axle. the first assembly i completed was the mid- drive version of the NuVinci hub.
- the drive side. 20t freewheel with a 27t fixed sprocket
- 640001.jpg (54.87 KiB) Viewed 550 times
on the input side i have a 20t freewheel that will be attached to a 44t chainring at the cranks. it is threaded on to the NuVinci input adapter. beside it is a 27t sprocket that is welded to the back of the NuVinci adapter. i have a machined washer between the two so there is enough room for both chains. the 27t will go to a 13t freewheel on the output shaft of the motor unit.
- rear view
- 640002.jpg (51.92 KiB) Viewed 560 times
this is how it looks from the back.
- 20t sprocket added to output side of hub
- 640003.jpg (61.31 KiB) Viewed 480 times
i drilled a few holes in a 20t sprocket and mounted it to the disc brake adapter on the output side of the NuVinci. this sprocket will attach through another chain to a 20T sprocket that will be mounted on the rear axle differential.
next step is to finish work on the differential.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
