Nissan Leaf EV
Re: Nissan Leaf EV
Postby BeninTucson » Sat Aug 22, 2009 8:29 pm
Since I live in one of the designated test cities, I'll be seeing these on the streets sooner than most. Here's how the local press has mapped out the charging station situation for the big Arizona cities . . .
http://www.azstarnet.com/allheadlines/303793
I figure I've got a few more good years on my '95 Saturn (getting my teenage son through his driving lessons with that old crate while absorbing the resultant insurance payment bump on that car) and then I can start making a serious consideration on an EV like this as they become commonplace.
The current body style is kinda middle-of-the-road but I suppose it could be worse. Although not as aerodynamically slippery, I wouldn't mind a variation on the current Cube with electric power (Nissan, after all, used an older version of that body shell to run their tests on EV powertrains for the Leaf these past couple of years.) I'm just glad to see some forward motion on something like this after so many years of stalled action on EVs.
The "buy the car but lease the battery" idea was slightly off-putting to me at first. But then I thought out some scenarios. It stands to reason that battery technology will only get better over the useful lifespan of the car. The rental fee for "100 mile" batteries will likely drop as "150 mile" packs come online (and so on.) The well healed can always buy their own batteries and forgo renting. Aftermarket companies will pop up to offer their own versions of batteries to fit this or that EV. The technically adept who don't mind voiding warranties will "roll their own" (the concept of the hot rod may go through a growth period not seen since the 1950 and 60s.) Most will probably just rent the best version of the stock batteries provided by the dealer and get on with fetching their groceries with minimal fuss.
Ben in Tucson
BeninTucson
10 µW
10 µW
Re: Nissan Leaf EV
Postby Toshi » Sun Dec 06, 2009 5:50 pm
link courtesy of the other, separate thread. merging and quoting it here.
LAtimes: Getting a charge out of Nissan's Leaf
The Nissan Leaf is described as "sweet, glycerin smooth, techy, frisky and even a little bit beautiful." (Don Bartletti / Los Angeles Times / November 13, 2009)
By Dan Neil
November 20, 2009
This thought came to me as I was piloting the Nissan Leaf electric vehicle prototype around Dodger Stadium last Friday: When gasoline-powered cars sleep at night, they dream of being electric.
Think about it: Every year, automotive engineers find new ways to smooth more rough edges off the conventional automobile. For example, long gone are the rude jolts that used to accompany gear changes in automatic transmissions. These have been ironed out either by continuously variable transmissions (which have no stepped gear intervals) or by sophisticated suites of computer programming that modulate engine torque at the precise moments of gear change. Even set-to-kill sports cars like Ferraris and Lamborghinis and Porsches -- cars that used to wrench your neck like a Leavenworth hanging -- now shift gears with a kind of eerie, liquid transparency. The only things that change are engine pitch and the needle on the tachometer.
This level of refinement, which is such a struggle to achieve in conventional cars, is a birthright of electric cars. In the Leaf -- an all-electric, five-passenger car that will start hitting American streets in late 2010 -- you step on the accelerator and the car spools out velocity in one continuous, syrupy stream. It's nothing short of elegant.
Once upon a time -- 10 years ago -- cars had such things as torque curves. Which is to say that, because of the peculiarities (the volumetric efficiency) associated with different internal combustion engine designs, each model of car hit maximum torque at a particular rpm. Cars with big American push-rod V8s under the hood typically had massive torque at lower rpm, and cars with multivalve overhead-cam fours and sixes hit peak torque at higher rpm.
These liabilities have been largely erased in the current generation of cars, thanks to computer-controlled throttles, variable valve timing and duration, forced induction and variable-geometry intake manifolds -- all of which help optimize the flow of gas in and out of an engine and establish a "flat" torque curve. In the case of a BMW twin-turbo 3.0-liter engine, for example, maximum torque comes at 1,400 rpm and doesn't start to go away until 5,000 rpm.
The BMW engine is, in other words, more like an electric motor. In fact, an EV's motor produces maximum torque at 0 rpm and maintains consistent torque across most of its operating speed range. That's what makes EVs such little hot rods -- loads of off-the-line quickness and mid-range punch.
During my all-too-brief drive, the Leaf prototype (clad in Nissan Versa bodywork), with three people on board, shot across the stadium parking lot like it had been pinged with a BB gun. Zero-to-40 mph acceleration, I estimate, is in the mid-5-second range, which would suit a decently sporty little car. Arrayed around the Leaf chassis is 90 kilowatts worth of lithium-ion batteries driving an electric motor good for 106 horsepower and a healthy 207 pound-feet of torque. According to Nissan, the Leaf's top speed is 90 mph and the nominal range is 100 miles.
One last tech-wonk example: Automakers are continuously evolving technology to help cars maintain traction and directional stability. With conventional traction and stability systems, if wheel slip or vehicle yaw is detected, the computers will pulse the appropriate wheel's brake or retard engine timing or both, until the vehicle regains stability. But this is a big, sloppy, coarse means of doing the job. What's needed is a finer-grain method of modulating wheel speed without scrubbing off all the speed and momentum.
Electric motors are instantly and almost infinitely variable, and are vastly more articulate with regard to changes in traction. This is why the Tesla Roadster, which can maintain almost 100% traction at the rear wheels under acceleration, corners harder and faster than the Lotus Elise upon which it is based.
Imagine the potential road-holding power of an all-wheel-drive electric sports car, such as Audi's promised e-Tron. Imagine what you could climb with an electric Jeep.
Here's my point: As repeatedly underlined at the Nissan Leaf's U.S. debut last week, the future of EVs comes down to the question of consumer acceptance. Will consumers buy them? Will they like them? What about battery leasing and recharging infrastructure, and carbon emissions? What about cost? These are reasonable questions.
But I predict consumer acceptance will ultimately be a nonissue. Why? Because the trajectory of vehicle engineering has trained car buyers to expect their next car to be smoother, quieter, quicker, more high-tech, with better cabin isolation and more road-holding, than the one before.
Two decades of computerization of the automobile have created a kind of well-oiled semiautonomous being, half semiconductor, half metal and glass. Many cars today have electric steering, electric brakes, virtual gauges, video camera mirrors, even virtual bumpers. In other words, cars are nearly electrified already.
The next logical -- even inevitable -- step in the evolution of the automobile is when we jettison the big, heavy, hammering, noisy piece of reciprocation under the hood.
The Leaf is definitely Car 2.0. Sweet, glycerin smooth, techy, frisky and even a little bit beautiful. It just feels like tomorrow. Perhaps the question is not "Will people buy them?" but "Can we build enough?"
Toshi
Re: Nissan Leaf EV
Postby Eric » Thu Dec 10, 2009 10:48 pm
I attended the Nissan Leaf Tour today in Bellevue, WA, USA. The car is not as tall as I expected and it looks a lot nicer in person than in photos. I only learned a couple of new points.
The NEC/Nissan Alliance group is going to manufacture the battery packs in the US and has already signed an agreement to sell it to Subaru.
The price quoted, both in the Seattle Times and during the Nissan presentation this morning, is closer to $25,000-$35,000 rather than the originally quoted $10,000-$15,000.
Some local coverage:http://seattletimes.nwsource.com/html/localnews/2010468141_electriccars10m.html
Eric S.
Eric
Re: Nissan Leaf EV
Postby Toshi » Fri Feb 12, 2010 11:36 pm
I saw the Nissan Leaf in the flesh today. Tomorrow marks the last day of the Leaf's USA tour. The car making the rounds is the same one that showed up at the auto shows. Fun facts: price TBD, theoretically shipping by the end of the calendar year (yeah, we've heard that line before), 80 kW motor, 32 kWh Li-Mn battery iirc designed to be used between 90% and 10% depth of discharge, and both fast chargers for 240V-equipped garages and a really high voltage DC charger for institutions.
My shots of it (horribly boring video to come later this weekend):
The cargo area is quite tall! I was impressed.
Both sides of the charging apparatus.
Fancypants dashboard designed for my generation.
Jessica liked it.
Toshi
Re: Nissan Leaf EV
Postby Toshi » Sun Feb 14, 2010 12:00 pm
A short video showing the Leaf that I whipped together this morning, all footage shot by yours truly:
http://www.youtube.com/watch?v=B2xNvC0lcMM
Toshi
Re: Nissan Leaf EV
Postby AndyH » Sun Mar 14, 2010 1:41 am
Here's an old video that shows a bit more of the battery construction and a cut-away of the major systems. Battery closeups at 1:04.
http://www.youtube.com/watch?v=WrNmplhx7ag
It looks like as of at least Feb 10 the split car/battery plan is dead.
http://blog.caranddriver.com/nissan-leaf-pricing-clarified-somewhat/
"Nissan today announced a timeline for the rollout of its Leaf electric car, but, perhaps more important, the company confirmed that the car and battery pack will be purchased or leased—just like a normal car—as a single unit. Previously, speculation about how the company might meet its aggressive pricing goals—“a well-equipped C-segment vehicle,” in their words, probably about $25,000—suggested the battery would be leased separately from the car. We now know that will not be the case."
AndyH
Re: Nissan Leaf EV
Postby voicecoils » Sun Mar 14, 2010 6:06 am
AndyH wrote:Here's an old video that shows a bit more of the battery construction and a cut-away of the major systems. Battery closeups at 1:04.
FYI, the battery pack is from AESC if it hasn't already been mentioned in the thread.
voicecoils
Re: Nissan Leaf EV
Postby Miles » Thu Mar 18, 2010 4:11 am
Miles
Re: Nissan Leaf EV
Postby liveforphysics » Thu Mar 18, 2010 5:18 am
I've managed to convince my mom to buy one of these Nissan Leaf's the moment they become available for sale. :) She has been looking for a new commuter car, and only has a 20mile round-trip commute, and doesn't care much about performance, so it seems like a perfect choice for her.
I'm excited to get enough of them on the roads to create a steady supply of wrecked Leafs at the auto-wrecking yards. It will make a cheap supply of many handy EV parts. :)
liveforphysics
Re: Nissan Leaf EV
Postby AndyH » Thu Apr 08, 2010 9:33 pm
Ok...the real question is...how much LiPo can we get behind the rear seat? :mrgreen:
Range is based on the LA4 urban drive cycle which has a small bit of expressway and a bunch of starts/stops. The 100 mile range estimate is without AC or heat. AC may drop range 10-20% and cabin heat will take a bigger bite at about 20%+. It should be a bit easier than an ICE car on at least initial climate control, since it can be pre-heated or -cooled on 'shore power' before driving away with a full pack. One estimate suggested a real-world 80 mile range in hot weather.
AndyH
Re: Nissan Leaf EV
Postby AndyH » Mon Apr 19, 2010 11:58 pm
Last day to sign-up on-line for a LEAF reservation -- $99 deposits start Tuesday the 20th by email invitation.
I look forward to reading about real-world experience from those of you in the initial roll-out areas! It's looking like Texas isn't in the early roll-out so I gotta wait. :cry:
AndyH
Re: Nissan Leaf EV
Postby jmygann » Tue Apr 20, 2010 1:25 pm
The auto maker will begin delivering the car, which is expected to have a 100-mile range, in December. The Leaf will start at $32,780, and buyers will be eligible for a $7,500 federal tax credit for electric vehicles. Nissan has a capacity to build 50,000 Leafs annually for the global market, including the U.S., at its plant in Japan.
http://www.treehugger.com/files/2010/04 ... r-leaf.php
sign up ...
http://www.nissanusa.com/leaf-electric- ... .Link.Leaf.
48 V Semi-recumbent
jmygann
Re: Nissan Leaf EV
Postby AndyH » Tue Apr 20, 2010 6:21 pm
All Righty! Nissan redesigned their website and has another round of pre-registration for the 15 May 'general' rollout. The folks that registered prior to the 20th are receiving email from Nissan with a link to register and place a $99 refundable place-holder fee.
(34.07 KiB) Downloaded 279 times
Not all Nissan dealers will be in the LEAF 'system'. Those that are can take place-holder fees from walk-ins starting May 15th.
AeroVironment is making the 240V home charger interfaces.
More EVs on the road is a very, very good thing!
AndyH
Nissan Altra?!
Postby AndyH » Tue Apr 20, 2010 9:01 pm
Could it really be that Nissan has more LiIon experience than any other auto maker?!
The Nissan Altra - a crossover vehicle before there were crossovers - used LiIon to get a 120-140 mile range - 1n 1997!
http://www.allcarselectric.com/blog/103 ... powered-ev
http://www.altfuels.org/events/testdriv/altra.html
Could it really be that while the gen-1 EV1 used lead and the RAV4 had NiMh that Nissan fielded a purpose-built EV and filled it with LiIon?
:D
AndyH
Re: Nissan Leaf EV
Postby Miles » Tue May 18, 2010 3:50 am
Miles
Re: Nissan Leaf EV
Postby Toorbough ULL-Zeveigh » Tue May 18, 2010 10:53 pm
liveforphysics wrote:I've managed to convince my mom to buy one of these Nissan Leaf's the moment they become available for sale. :)
hey, way to pimp ur mom.
"ah weel tairn yeww out"
the pessimist engineer sees a glass that’s twice as big as it needs to be.
the optimist engineer sees that the glass has a 100% safety tolerance.
http://what-if.xkcd.com/6/
there is zero consequence to ignoring ayn rand
Re: Nissan Leaf EV
Postby Toshi » Fri May 28, 2010 10:04 am
ABG: Nissan Leaf battery details further unveiled
Battery porn:
The taller part of the battery pack in the background of the image will go under the rear seats. The flatter part will go under the floor and front seats.
Note the scheduled charging to take advantage of off-peak rates and scheduled A/C and heat timing that'll be used to cool or heat the car while it's still on the charger, minimizing its use (and maximizing comfort) once off the charger and on the road. :thumb:
[Nissan] PRESS RELEASE
Type: Laminated lithium-ion battery
Total capacity (kWh): 24
Power output (kW): Over 90
Number of modules: 48 [each containing 4 cells, so 192 total]
Battery pack contents:
-Positive electrodes – Lithium manganate
-Negative electrodes – Carbon
-Cells
-Modules
-Assembly parts
Charging times:
-Quick charger DC50kW (0 to 80%): apx. 30 min
-Home-use AC240V charging dock (0-100%): less than 8 hrs
Battery layout: Under seat & floor
Battery life: After 10 years, the battery is expected to have 70-80 percent of its original storage capacity
The 70-80% remaining capacity estimate after 10 years depends on how much fast vs. not-as-fast (see below) charging one does, with fast charging causing more depletion down the road. The good news it that utility companies may well be interested in buying back those batteries at the end of their useful automotive-application range, regardless of whether they hold 70 or 80%.
Fast = Level 3, high voltage DC, 30 minutes to 80% charge, think municipal charging station
Not as fast = Level 2, 220/240V AC, 8 hours to go from 0-100% charge, installed in every Leaf owner's garage
Other interesting bits from the article are that Nissan's Smyrna, TN plant, for which ground was figuratively broken yesterday, will have the capacity to build 200,000 battery packs per year. The nearby Leaf assembly plant only can build 150,000 Leafs per year at full capacity. This implies that Nissan will be selling excess battery packs to other manufacturers or will be building some non-Leaf BEVs or hybrids. Excellent.
Toshi
Re: Nissan Leaf EV
Postby ngocthach1130 » Sat May 29, 2010 1:41 am
Toshi wrote:Other interesting bits from the article are that Nissan's Smyrna, TN plant, for which ground was figuratively broken yesterday, will have the capacity to build 200,000 battery packs per year. The nearby Leaf assembly plant only can build 150,000 Leafs per year at full capacity. This implies that Nissan will be selling excess battery packs to other manufacturers or will be building some non-Leaf BEVs or hybrids. Excellent.
Not really. It's only 50,000 pack. Which can be used as service parts and repair. I'm sure not all those 150,000 Leaf will be fault free. Even if they're fault free i don't think you can remove the human. We're prone to error.
Worse part of waking up...is having to stay up!
Thach(Tut)
ngocthach1130
Re: Nissan Leaf EV
Postby Toshi » Fri Jun 25, 2010 11:41 pm
Design News: Nissan Bets on the Electric Car. This is a solid, slightly technical article on how Nissan's choices over the years are paying off now.
Since shelving the electric Altra almost a decade ago, it has kept its eye on the all-electric prize, working non-stop on EV batteries. The automaker has pulled together big teams of engineers at its Technical Center and at its Advanced Technology Center in Atsugi, Japan, as well as at its Research Center in Oppama and its Operations Center in Zama. Their task: to build a higher-energy, lower-cost, EV battery.
The Leaf's engineering team says the resulting battery will take the car 100 miles between charges, without clogging up valuable space in the back seat or trunk. The key, they say, has been a dedicated 17-year effort that has resulted in a two-fold boost in the battery's energy density. By packing more energy into less volume, the battery provides Nissan engineers with choices - longer range or smaller batteries, or an idealized combination of the two. That's why they've been able to store the battery under the Leaf's floor while still reaching 100 miles of range.
"The breakthrough happened in 2002 or 2003," says Mark Perry, director of product planning for Nissan USA. "We changed the chemistry, went to laminate cells, and at the end of the day, we had twice the energy density. That allowed us to optimize the vehicle platform. Suddenly, we had a mass market vehicle concept."
Toshi
Re: Nissan Leaf EV
Postby dnmun » Sat Jun 26, 2010 12:39 am
it is possible that we could build fast charge stations which only produced about 7kW of power at the high DC level they mentioned. it appears the pack is 48S of LiMn in these big pouches that lay flat in the trays under the body.
so we are talking about a switch mode supply producing 35A at about 200V. manzanito micro is building these fast chargers used for these quick charge municipal charging stations that ecotality is building out here.
already on even the company website where they have a message board for future owners, the talk is about how they will be able to avoid the huge costs of the charging spots by rigging up a simple pigtail to the dryer outlet to charge using the onboard 6kW charger that is the long term charger, rather than the big buck module that nissan is requiring people to use to charge with. but the initial charger at release will only be a 3kW onboard charger, so 8 hour charge is what they are using for the press.
by leaving the charge spot build out to one monopoly, i can already see the seeds of this whole program's destruction, they really should be giving the chargers away free, if the city or municipality would match with tax credits for the real estate that the charger would occupy. i am already thinking of how to provide charging for people without going through the nissan web based monitoring of the charging cycle.
i hope they do not write code to prevent you from charging without logging into nissan's network.
the other problem will be the technical people needed, build out will have huge numbers of failures and new techs will not be savvy so the chargers will be down alot. could be a good job too in the future, better paid than straight work even i would expect. so worth learning about how to fix chargers, big chargers. but i expect onsite repairs would be swapout of whatever module called for.
dnmun
Re: Nissan Leaf EV
Postby Toorbough ULL-Zeveigh » Sat Jun 26, 2010 10:21 am
dnmun wrote:they really should be giving the chargers away free,
ha ha, good one.
the hang up preventing the widespread adoption of EV's has never been technical.
the problem has always been the sheer simplicity of the system doesn't allow for a cheap way to implement a choke-point onto which subscription costs can be bridled & a monopoly based upon.
otherwise we could have easily been tooling around in electric cars for over the past century.
the mpu has now changed all that with closed source code being the pass key locking out the end user which is why the EV push is now on, more so than improvements in battery capacity.
Re: Nissan Leaf EV
Postby MitchJi » Sat Aug 14, 2010 3:36 am
Hi,
Interesting battery information here:
http://electric-vehicles-cars-bikes.blogspot.com/2009/11/nissan-long-range-battery-may-be-ready.html
Nissan Motor Co. is developing a lithium ion battery for electric vehicles that can store electricity at double the current capacity. Nissan aims to equip electric cars with the battery by 2015.
The new system is a lithium-ion battery using a lithium nickel manganese cobalt oxide cathode. Capacity is raised by improving the positive electrode, specifically, using nickel and cobalt, not only manganese. The new battery can store about twice as much electricity as batteries with positive electrodes made only from manganese. It is robust enough for practical use, able to withstand 1,000 or so charge cycles.
Nissan estimates that the battery will cost about the same as conventional lithium ion ones to produce, as it contains only a small amount of cobalt, a relatively expensive metal.
The new battery will be able to power an electric vehicle for 300 kilometers (186 miles) on a single charge, about twice the distance currently possible.
http://electric-vehicles-cars-bikes.blogspot.com/2010/05/nissan-say-leaf-ev-battery-pack-cost.html
Nissan say they have been working on EV batteries for the past 18 years and are currently working on a lithium nickel manganese cobalt oxide cathode based battery that they expect to be fitting to Leaf EVs by 2015. With double the energy density of current cells, they will give the Leaf 200 miles range on a single charge.
Nissan expect this range combined with the money savings on EV running costs will 'tip' the market the same way the European market for Diesel cars 'tipped' 15 years ago.
Nice gallery of pictures here:
http://green.autoblog.com/photos/nissan-leaf-battery-plant-groundbreaking/#3019888
Nice series of articles here:
http://www.allcarselectric.com/blog/1047669_2011-nissan-leaf-your-ultimate-reference-guide
Here's the list:
    * My Nissan Leaf Won't Be Here Until...April?
    * So, Can You Drive The 2011 Nissan Leaf Cross-Country?
    * 2011 Nissan Leaf: Waterboarded For Your Safety
    * 2011 Nissan Leaf Drive Review: A Real Car For Real People
    * 2011 Nissan Leaf First Drive
    * Can't Afford To Buy An EV? Rent A 2011 Nissan Leaf In January
    * 2011 Nissan Leaf: Batteries. - All you need to know about the battery pack.
    * 2011 Nissan Leaf Prototype Quick Drive Impressions
    * 2011 Leaf EV: Timeline For Rollout, More About Hand-Raisers
    * The 2011 Nissan Leaf is a Mac: The 2011 Chevy Volt is a PC
    * 2011 Nissan Leaf Matches Volt: 8 Year, 100,000 Mile Warranty
    * Video: 2011 Nissan Leaf EV Navigation System Demo
    * Nissan Gives Test-Drives of 2011 Leaf Production Model, Feedback Positive, 80% charge in 30 minutes
    * Nissan Leaf. We Order Ours, And Show You How
    * What's Slicker, The Nissan Leaf iAd Or The Nissan Leaf?
    * Got A Leaf And An Apple iPhone? There's An App For That
    * Hertz Wants You To Rent A Leaf
    * 2011 Nissan Leaf EV To Be Built in U.K> As Well As Japan, U.S.
    * Nissan Tuning 2011 Leaf EV To Be Audible, Not Audacious
    * Armstrong, Apple Ads Accelerate 2011 Nissan Leaf Marketing
    * Nissan Leaf Audio Warnings Disappoints Advocates, Need For Sound Questioned
    * 2011 Nissan Leaf Spied Testing on Arizona Roads
    * 2011 Nissan Leaf Hits Japanese Sales Goals, 60% of Pre-orders From Baby Boomers
    * Get a Tree Planted On Your Behalf Just For Liking The 2011 Nissan Leaf?
    * Nissan Announce Leaf Pricing in E.U., Confirm Three More EVs
    * 2011 Leaf Priced $40k in Japan, $33k for U.S. Buyers
Best Wishes!
Mitch
MitchJi
Re: Nissan Leaf EV
Postby MitchJi » Sat Aug 14, 2010 3:41 am
Hi,
http://green.autoblog.com/2010/08/09/nations-first-public-quick-charge-station-opens-up-in-portland/
Okay, despite the argument that there may not be a need for public chargers, we can't help but be giddy to announce that the U.S. finally has its first quick-charge station. The installation is now complete at the parking garage of the World Trade Center building in downtown Portland, OR, and the charger is capable of boosting most electric vehicle batteries from zero to 80 percent charge in just 20 to 30 minutes.
The grand opening event was led by Oregon Governor Ted Kulongoski, who is seen in the video after the jump cautiously attaching the charging cable to the Nissan Leaf. As Engadget reports, use of the quick-charge station is free of charge, but entry into the public parking garage will set you back three dollars. (Here's why.)
PRESS RELEASE
Portland General Electric opens North America's first public-use quick-charge station for electric vehicles in collaboration with NEC Electric vehicles can charge up in 20 to 30 minutes
PORTLAND, Ore. - Portland General Electric (NYSE: POR), Oregon's largest utility, and NEC Corporation (NEC; TSE: 6701), a leading network, communications and information technology company, announced today they have opened North America's first public-use, quick-charge station for electric vehicles.
The station was awarded public-use certification by the City of Portland following the successful installation and testing of the station manufactured by Takasago Ltd., a subsidiary of NEC, at the PGE headquarters in the Two World Trade Center parking garage, 121 SW Salmon St, Portland, Ore. The Takasago Rapid Charging Station is specialized for recharging electric vehicles with lithium-ion batteries and requires only 20 to 30 minutes to recharge a battery to 80 percent of full strength.
PGE and NEC officially opened the quick-charge station today with Governor Ted Kulongoski, who charged up an all-electric Nissan LEAF, during a two-day LEAF test drive event at PGE. Portland and the state of Oregon have been designated as top-tier launch markets for the Nissan LEAF when it goes on sale in the United States in December.
"Quick-charging stations are an exciting advancement in our effort to bring electric vehicles to Oregon," said Gov. Kulongoski. "By making charging convenient and available for public use, we are telling car manufacturers that Oregon is ready for the next generation of electric vehicles - and we want our state to be a leader in introducing these cars to the rest of the country."
"Partnering with NEC to bring the nation's first publicly available, quick-charge station to Oregon further solidifies PGE's commitment to developing the infrastructure needed to support electric vehicles now coming to the U.S. market," said Jim Piro, president and CEO, PGE.
"With the addition of the Takasago Rapid Charging Station to the growing network of EV charging stations in Oregon, we are able to further our research on how this new technology will interact with our electrical system and support our EV-driving customers," Piro added.
"This project reflects NEC's ongoing commitment to the development of new infrastructure that utilizes renewable resources. As a supplier of electric vehicle batteries, our introduction of the rapid electric vehicle charging station is a natural stage in the evolution of NEC's environmentally friendly solutions," said Hideki Niwaya, general manager, Public Utility Solutions Division, NEC. "Looking forward, NEC aims to continue developing mission critical solutions, including information and communications technologies (ICT) services and smart grids that represent the latest in technological innovation."
The Takasago Rapid Charging Station complies with the "CHAdeMO," a global EV charging standard developed in Japan. The station provides power output of 50kw (50-500V, 0-125A) and supports power input of AC200V+-30V.
PGE's alliance partner, Portland State University, and the Oregon Transportation Research and Education Consortium will document the acquisition, installation, certification, and testing procedures for this quick charger and release its findings in September
Best Wishes!
Mitch
MitchJi
Report:NissanAllocating 2,000 LeafsToUK In 2011,HalfForFleet
Postby MitchJi » Sat Aug 14, 2010 6:31 pm
Hi,
http://green.autoblog.com/2010/08/14/report-nissan-to-allocate-2-000-leafs-to-uk-in-2011-half-heade/
Report: Nissan to allocate 2,000 Leafs to UK in 2011, half headed to fleets
Aug 14th 2010 at 5:52PM
Last weekend, Nissan revealed some info regarding the Leaf's availability and its allocation in the UK and managed to do so with little fanfare and virtually no media coverage. It's almost as if Nissan intended to slip this announcement by without us getting wind of some pertinent info that could make electric vehicle-loving residents of the UK a bit angered. What's the news? Half of the Leafs headed to the UK in 2011 will be reserved for fleet use. The company also suggested that its allocation of 1,000 Leafs have already been claimed by fleet customers. A Nissan spokesperson said:
We probably could have sold all of next year's allocation to fleet customers, but we wanted to make sure retail customers who wanted to buy the Leaf were able to, so we decided to split equally between fleet and retail.
Combining the statements above gives us the impression that Nissan intends to ship just 2,000 Leafs to the UK in 2011, with half headed to the retail market. Now, that will likely upset those early adopters who may find it hard to get their hands on a Leaf for a long while, but Nissan could have allocated all of the 2011 model run to fleets, thus making it impossible to get one in the UK until 2012. Thankfully, Nissan did not choose to follow that route.
Best Wishes!
Mitch
MitchJi
Re: Nissan Leaf EV
Postby AndyH » Thu Sep 09, 2010 2:30 pm
AndyH
PreviousNext
Return to E-Vehicles General Discussion
