- img.jpg (47.65 KiB) Viewed 2581 times
Now that Ultra Motor has come out with their new Hybrid and Velociti models the holdover bikes from the Tres Terra line they marketed after acquiring that company a few years back are being liquidated through various channels. I purchased the Ultra Motor Europa model on eBay this past weekend. The bike has its roots going way back to the original Iacocca E-bikes of years ago. It still has a heavy steel frame with a brushed Heinzmann motor but has been updated with a 36V Li-ion battery instead of the lead-acid batteries of old.
The bike arrived late yesterday afternoon in a BIG box. Actually it was double-boxed yet it still sustained a bit of damaged with the rear steel fender bent out of shape. I immediately unpacked the bike and got the battery on the charger while I assembled and tuned the bike. The battery voltage measured 38.5V or about half-full, right where it should be. Unfortunately the bike manual was missing so I don’t know what the specs are on the battery however I remember reading somewhere it was supposed to be built with Sanyo cells and have a capacity of 9.5Ah. It took just over 3 hours to charge with the included 2A charger, a good quality aluminum unit which runs quieter than many of its type with a small cooling fan, it even has an on/off switch and external fuse.
- Europa 005a.jpg (159.71 KiB) Viewed 3064 times
- Europa 001a.jpg (160.81 KiB) Viewed 3079 times
One reason I never bought a pre-built E-bike in the past was the one-size-fits-all nature of most of them. I was not overly surprised then to find the suspension seatpost did not raise high enough to allow me the proper leg extension. I installed another regular seatpost I had which gave me another inch but that is still an inch short so pedaling would be compromised somewhat. It was now dark out but the battery was fully charged and I wanted to try it out. The bike comes with a new headlight, taillight and computer but I tossed on two cheap-o 3V headlights I bought years ago but never used, a rear blinky light plus a spare wireless computer and hit the road. I only road 2.5 miles just to try it out. I put the battery back on the charger while I made more adjustments.
At midnight I went out for a longer ride and this time I took along a flashlight so I could see the speedometer. I haven’t ridden at night since I was a youngster but I must say it was fun. The two lights I used did little to illuminate the road which added to the sensation of speed however the claimed 20 mph top speed seemed realistic. The electrical noise was messing up my wireless speedo so I would have to use the new wired unit after all (I switched to wired on my Kona Smok-E some time ago for the same reason).
At about 13 miles the “Half†charged LED on the throttle display lit up a steep hill indicating it was time to get home. I put on 15.4 miles however I had no way of knowing how much power I actually used. The resting voltage on the battery was 35.9V after the ride which looking back at data I collected running Bosch LiMn Fatpacks suggested the battery was 75% depleted.
My initial impressions are so-so on the bike. The Heinzmann motor does make quite a ruckus and it’s too much for me (My Bafang is whisper quiet by comparison). Not sure what I’ll do with it now.
-R
