GGoodrum wrote:Wow, this is great. I have been playing around with trying to find simple "bolt together " solutions for building a123-based packs for, well, for years.This is about as simple as it comes, great job.
Your machined nylon end plates look very good! I'd like to see some pictures of the inner side of the plates. How are the cells held in place? Are there recesses for the ends of the cells?BMI wrote:You can't get a much simpler end plate solution than machined nylon end plates held together with threaded rods.
I'd also like to see some pictures that show how the cells are connected.GGoodrum wrote:But how are the connections handled?
GGoodrum wrote:But how are the connections handled? Are these assuming spot-welded tabs are used? If so, these nice-looking end plates won't work for the cases where loose cells, without tabs are used. The technique described in this thread will work with loose cells just fine.
-- Gary
BMI wrote:No, there is no welding involved. Link bars join the cells and they are held in place by pressure alone when the threaded rods are tightened.
100a per cell is over 40c so that would drain the cell in about 90 seconds. Unless you are planning a dragster its not an issue.katou wrote:One thing I'm not sure about with Leamcorp's construction method, if the clips are not soldered on, can high amperage (say 100a) be passed by the small contact spring bumps?
cell_man wrote:Looking at the plates, I'd say they couldn't be made so easily without at least a milling machine.
You are correct. Using a drill press with a depth gauge would easily do it. But using two layers for each plate would be even easier (a solid end piece and a piece with holes or slots that gets fastened to [glued or bolted] to the piece with holes).katou wrote:I'm almost certain that it could be done without a milling machine. I say "almost" because I haven't tried to make one. I don't want to be all absolute unless I can actually prove it.
The cost of the springs is trivial and springs will retain their spring much better than brass strips.veloman wrote:My plan is to just stamp out tabs in the strip - should act like a spring to keep tension on the cell for proper connection. This should be a LOT cheaper than buying those strips and separate tabs listed by the OP.
I have some small cardboard boxes from shipments, I might try fitting my cells in, then wrapping it all real tight with duct tape.
Just run a bolt or two through the strips (nylon bolts if that helps).katou wrote:I wonder about the thickness of the metal you are using. If you are using the Amazon stuff from the previous posting, it was 0.016" thick right?
I would not use less than 1/8" or 0.125" thick. With such thin metal, I figured it would not stay straight, the spring pressure would push it into a curve.
Katou
MitchJi wrote:The cost of the springs is trivial and springs will retain their spring much better than brass strips.
If you are planning to use duct tape on the brass strips I think it's conductive. You might want to use gaffers tape.
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
Users browsing this forum: No registered users and 15 guests
