Been brain stormin with fellow riders, and if you could invent a 2 mode controller 36/72v, OR 48/96v, for econo/performance, you would make allot of ppl happy.
Is such a controller even possible? All ideas are welcome...
Well, in theory, if you just stayed at the higher voltage all the time and just limited the throttle in one mode, it should perform almost exactly the same as running at a lower voltage. In fact, if you limited the throttle on a 72v pack so that the top speed was the same as a 36v pack, you would have even more torque available since the current limiter is measuring the battery current.
RatoN wrote:Ok i understand now
So there is no need for a 2 mode switch then, since the throttle constitute a dimmer switch.
Thx!
Like I said before, AMPS = Torque
Voltage = Speed POTENTIAL
"Each cell has to carry the same load either way."
This is where we differ.
The equalizer in your " Specific " situation is that your motor runs better at higher voltage.... 5 amps at 80v.. or 10 amps at 40v... equals things out.. so the amp load on each cell is the same..
You either have a magic motor or a magic controller.
Now tell me about your magic motor and magic controller.
Don
There is a tiny advantage to running a lower voltage if you're going slow. The greater the difference between the pack voltage and what the motor's getting, the more losses there are in the inductor (controller).
I don't think the difference is very big, and usually not worth the bother of a dual voltage switch.
Users browsing this forum: Gator, Merlin, shorza, spinningmagnets and 5 guests
