Chrystalyte Motors, Ready to ship!
Re: NewCrystalyte controllers in stock (motors are back orde
Postby maxwell65 » Fri Apr 30, 2010 5:46 pm
Spanky wrote:Hi Max - I have a 5303 rear that I run with a Crystayte 4840 controller; most of the time I run with a lipo 60v pack and some time my 48v headway pack. Question (1) is there a difference between the 48 & 60 volt controllers (2) can the LVC on the 60v controller be adjusted so I can run both of my battary pack?
So you still have 60v controllers forsale?
Frank
hmmm, the 4840 controller,can you tell me what fets you have in there and how many? i believe my 4840 was only 6 fets,although i may be wrong and unless im mistaken the 4840 is 48v40amps correct?ok as for the controllers i have yes,i still have the 60v48amp 18fet controllers irfb 4110 genuine,you cannot run this at 48v as the lvc cuts out at 48v,,,,so unless you are an electronics guy maaayyybbeee and i say maybe because i just dont do mods,you can change the lvc to cuttoff at a lower voltage.but i can tell you this,according to crystalyte it is not advisable to change the volts on these 18fet 48amp controllers,,,,the 35 amps they can and are sending me new 48v-72v 35amp 12 fet 4110 controllers with the lvc only operable at the 48v level,so if you chose to buy one of these you will not have lvc cutoff when using higher volts above the 48v level.so if for example you are using 60v the controller will keep on running to the point of destroying your batteries :shock: so unless your batteries have its own lvc circuit it is not advisable to run anything more than 48v just because of the lvc factor,otherwise these controllers will handle up to 72v without any problems.
maxwell65
Postby Nogwin » Mon May 03, 2010 8:43 pm
I have a BMC 1000W V.3 motor that I can't get working properly with the infineon controller (or any infineon I tried ), so will these Xlyte controllers (72V) work ok?
Has anyone else tried this with the V.3 BMC motor and got it to work, and if so, can they post their wiring codes?
72V50amp 18 FET controllers with GENUINE 4110 MOSFETS including all plugs for Cycle analyst,cruise control,low medium high switch,forward reverse switch,brake,throttle,etc. $250.00 ////NOW $220
Thanks,
..if it will work, I will order one right away.
Nog
Nogwin
Postby oatnet » Tue May 04, 2010 8:28 am
Nogwin wrote:I have a BMC 1000W V.3 motor that I can't get working properly with the infineon controller (or any infineon I tried ), so will these Xlyte controllers (72V) work ok?
Thanks,
Nog
the v3 doesn't like digital controllers, here are a few threads on it, there are 3-4 others if you do a search.
viewtopic.php?f=6&t=12461
viewtopic.php?f=4&t=15335
oatnet
Re: Chrystalyte Motors, controllers are here! Ready to ship!
Postby maxwell65 » Sat May 15, 2010 10:20 am
hi all,
just a small note to let everyone know clyte has made some changes to the connectors on the motors and the controllers,,,they are now the anderson 75amp and they plug and unplug like a charm.i will post pics soon.i have controllers with the original connectors and anything you may need for your build.
thanks
max
maxwell65
Postby cprobike » Sat May 15, 2010 12:12 pm
what size are the phase wires? is it still the same as before?
cprobike
Postby maxwell65 » Sun May 16, 2010 8:31 am
cprobike wrote:what size are the phase wires? is it still the same as before?
they look like 12g,,
maxwell65
Re: Chrystalyte Motors, Ready to ship!Controllers $150!
Postby maxwell65 » Sat Jun 12, 2010 7:53 am
i just found out that the new 5x series does not accept the standard 14g spoke as it goes right through the hole,you must use a 12g,,,,,standard rims only accept 14g,but we have a solution,,,,there is an alexis rim with no eyelets and the holes can be easily drilled to fit the 12g,,,,any rim without eyelets can be used in this fashion,,,i mention the alexis as it is reasonably priced (25.00)and my bike mechanic assures me it is a solid rim. i will provide the model# to you later today as i do not have that info now. of course anyone who wants this service done i can provide at a reasonable cost.
maxwell65
Postby The Mighty Volt » Sat Jun 12, 2010 12:00 pm
maxwell65 wrote:i just found out that the new 5x series does not accept the standard 14g spoke as it goes right through the hole,you must use a 12g,,,,,standard rims only accept 14g,but we have a solution,,,,there is an alexis rim with no eyelets and the holes can be easily drilled to fit the 12g,,,,any rim without eyelets can be used in this fashion,,,i mention the alexis as it is reasonably priced (25.00)and my bike mechanic assures me it is a solid rim. i will provide the model# to you later today as i do not have that info now. of course anyone who wants this service done i can provide at a reasonable cost.
Hi Max, what spokes do I need to lace the 5304 you sold me into a 26" wheel?
The eyelets in my wheel are offset.
Thanks.
The Mighty Volt
Postby maxwell65 » Mon Jun 14, 2010 10:11 am
Thanks.
u need 12g spokes,,,as for the length i will have those figures 4 u as soon as crystalyte gets back to me.u will have to drill out the eyelets on your rim in order for the 12g spoke nipples to fit,,,i do not know how well the eyelets will respond to the drilling,,,thats why you may need to buy a rim without the eyelets,,,,the holes drill easily making it an easy modification.
maxwell65
Postby The Mighty Volt » Tue Jun 15, 2010 10:57 am
Cheers Max.
Crystalyte are slow mothers. They sure take their time!!
The Mighty Volt
Postby SkyCaptain » Thu Jun 17, 2010 8:06 am
Hi.
Could you give me an idea of the approx shipping cost to Melbourne Australia for one 5x motor?
Thanks.
SkyCaptain
Postby maxwell65 » Sun Jun 20, 2010 10:48 am
The Mighty Volt wrote:Cheers Max.
yea tell me about it,,right now they are on holiday and im trying to get answers from them and its like pulling teeth,only worse.
maxwell65
Postby maxwell65 » Sun Jun 20, 2010 10:54 am
SkyCaptain wrote:Hi.
Thanks.
shipping to Australia unfortunately is not cheap,$260.00 usd for 7 days, or $140.00 for apx 4 week delivery time,
maybe i should go into the shipping biz :mrgreen:
maxwell65
Postby The Mighty Volt » Sun Jun 20, 2010 1:59 pm
Hey Max, any word on those spokes?
Cheers!
TK
The Mighty Volt
Postby maxwell65 » Tue Jun 22, 2010 9:21 pm
The Mighty Volt wrote:Hey Max, any word on those spokes?
Cheers!
TK
whoops,almost forgot, here are the spoke lengths only for the 5X series 5303 to 5306 mounted on these rims:
700c = 194mm
26" = 165mm
24" = 138mm
20" = 77mm
a word of caution: the alexrim model # DM 18 size 700c takes a standard 191mm spoke so the 194mm that clyte says it takes would probably be too long,,,,depending on the rim the spoke size may differ slightly,,,also be aware that you must drill out the holes on the rim to accommodate the 12 g spokes the new 5X series requires.
maxwell65
Postby The Mighty Volt » Sun Jun 27, 2010 10:21 am
Cheers!
TK
700c = 194mm
26" = 165mm
24" = 138mm
20" = 77mm
Cheers Max, I sure appreciate that. I ordered some spokes, I will let you know how they fit. Cheers and thanks again.
The Mighty Volt
Re: Chrystalyte Motors 5303
Postby Marcoux » Sun Aug 15, 2010 1:07 pm
Hi there I am interested in the Chrystalyte 5303 hub motor kit ... what is your pricing and availabilty here in Canada
Thank you marcouxdon@hotmail.com
Marcoux
Postby Mark Sommers » Sun Aug 15, 2010 7:48 pm
Howdy Maxwell,
Big build ... One motor @ rear of velemobile (a rear motor)and TWO(fronts) with disk brakes .....on an overloaded trailer.
I will poss. use 48v/40ah LiPo.
QUESTION : Can I use one(which)controler for both trailer motors?
QUESTION: Is reverse avail. for trailer only?
QUESTION: Could I mechanicaly/electricly (trailer can/will be disconnected periodicly) link all three , then sepperate and use individually(the
trailer @ low speed) ?
Thanks,
Mark.
Mark Sommers
Postby Mark Sommers » Wed Aug 18, 2010 7:09 pm
Maxwell...
If I may clarify above post . .
The (rear) motor on the velo should/may be a high torque w. disk brake. Will have its own batt. w thumb throttle(left side)and controler.
The two(front)motors on the trailer should be high torque w. disk. One right side short twist throttle and hopfully will run from one controller.
I hope to use LiFePo 48/40 (1-velo and poss.only 1in trailer).Two separate systems.
My concerns are : (and I may query methods) can I run two x-lite 53xx motors from one controler or will I need two? (I have followed posts
regarding syncronous motors on paralell paths, poss.an issue). Which 5 series motor is the climber. Can Reverse the trailer only . And LMH SW.
I am sure there are other questions I should ask and this may be the wrong forum.
Thanks,
Mark.
Mark Sommers
Postby maxwell65 » Wed Sep 22, 2010 3:25 pm
Mark Sommers wrote:Howdy Maxwell,
Thanks,
Mark.
hi ,,sorry for the late reply as i have not checked here in quite awhile,,,,,im pretty sure that there exists dual controllers for the X5 series,,,,as for the model u would probably want the most torque so that is a 5306,,,,,5303 fastest less torque,,,,on 48v20ah for 5303 i go up to 53 kmph on the straights on 700c wheels,,,,,i have had ppl ride my bike who weigh 230lbs with no problems,,,so there is a lot of power and torque even though it is the least torque of the 4 models offered,,,,so 5306 has the most torque.
maxwell65
Postby chroot » Wed Sep 22, 2010 3:31 pm
Hi maxwell,
How fast if used 5306 with 99.6v LiPo?
chroot
Postby maxwell65 » Tue Nov 02, 2010 7:57 am
chroot wrote:Hi maxwell,
hollee mollee,,,,sorry i was so busy with work,,,you would probably get your best answer by using the sim located at ebikes.ca
maxwell65
Postby BLUESTREAK » Tue Nov 02, 2010 9:59 am
I do not know about 96volts but heres what I have learned about the x5306 pulling a 450lb. trike(me included),48volts is 20mph,6ovolts is 25mph and 72volts is 30mph on flat ground, so 96volts may be about 40+ mph. and it never get warm. :mrgreen: :mrgreen:
BLUESTREAK
Postby novembersierra28 » Tue Nov 02, 2010 6:21 pm
Hi Maxwell
I've got a couple of questions,
1.can the 5306's be fully spoked into a 26" or 20" rim? what is the cost?
2. How much is the total + shipping for a rear 5306, spoked / 7 speed rear casette / 72v 18 FET controller to the UK?
3. How soon do you ship after receiving funds, and could you PM me your paypal address please
many thanks
Nad
It is amazing how much you can accomplish when it doesn't matter who gets the credit
Harry Truman
Plasma Boy Jr.(11months ago) knew physics, several books later I built my first PCB balancer + A123 battery pack
Etek 300a Curtis 9.2ah A123 lifepo4 16s4p 59.5mph
crazy video 0-94km/h in 6 seconds http://www.youtube.com/watch?v=FEGyLBg0kDM
novembersierra28
Postby Radens » Wed Nov 03, 2010 4:43 am
Hi Maxwell!
I would like to buy the Crystalyte 5304 motor. What will the cost for shippment to Sweden and Jonkoping be!?!
// Anders
Radens
10 µW
10 µW
PreviousNext
Users browsing this forum: Google [Bot] and 2 guests
