flyinmonkie wrote:I have checked the balance of my batteries with my charger. One pack is great, no more than 0.01 out between cells. My other pack is up to 0.20 out between cells. I have had it on the balance mode of my charger for quite some time, but I have been careful to watch the individual cell voltage and not let it go above 4.2v. Below is a picture of the cell levels of the pack that is out. Will I be able to bring this pack into balance and if so, what is the best option for doing that? Or is this a warranty claim?
flyinmonkie wrote:
I am still waiting to hear input from you guys on how long of wires I can use for the watt meter.
flyinmonkie wrote: l. Despite that I am still a little fuzzy on charging several packs at once. After reading the Lipo care thread and seeing it posted in many places that you can charge lipos in parallel, I have not seen a detailed description of how to wire the packs to do that.
GGoodrum wrote: I usually don't bother paralleling the main discharge leads. I just plug the positive of the 1st pack into the negative of the second pack. I then just parallel them at the pack level.
AussieJester wrote:GGoodrum wrote: I usually don't bother paralleling the main discharge leads. I just plug the positive of the 1st pack into the negative of the second pack. I then just parallel them at the pack level.
Gary, just curious, is there any difference in performance or packs staying better balanced doing it this way over
the method i/we used with my pack? i.e grouping the + & - leads together after packs are connected in series.
KiM
Users browsing this forum: dan974, panurge, planky81 and 5 guests
