Timma2500 wrote:recumpence wrote:I can attest to the durability of #25 chain (as well as very cheap replacement parts).
Yes i remembered you saying on here somewhere that you'd found it to be quite strong Matt, I've never heard you talk of #25 chain failures or anyone else that i can think of if using HD chain. I considered using #35 chain on the 2nd chain stage but will give the #25 a go first.
I just ordered one of those new 8600w CA120-70 150kvTurnigy outrunners for a slick tyred single speed setup...![]()
I wonder if it'd push 66mph?![]()
Paul
Paul
Timma2500 wrote:I'm designing both a hardtail and single pivot suspension frames at the moment to go into production before the end of year. The frames will be modular in the rear end allowing the user to be able to swap between using a frock motor, cyclone motor or rc reduction drive. I was hoping to use these gearboxs as part of the rc reduction option but i just couldn't trust them to survive esp with larger motors.
Paul
Timma2500 wrote:does anyone know the exact can dimensions of Astro 3220's?
PowerPedro wrote: Do you guys have a solution for that? Do you still drive with normal cassette gearing timma?
Users browsing this forum: DanGT86 and 4 guests
