damcard wrote:Okay, got it. To reverse the direction, I wired it as indicated in the diagram above except for the sensor wires. I wired them as such: motor black to controller yellow, motor white to controller blue, motor red to controller green.
Also, I found to run it in reverse, it drew less amps at no load if I adjusted the timing of the hall sensors. I just played with it a bit. But now it works. -Damcard.
I have a Cyclone 1200w motor and a LYEN 12 FET 3077 MOSFET Extreme Modder Controller.
I have it all screwed and bloted onto a wooden board for initial testing. When I wired everything up
(following your carbon rendering diagram
) all went well
I had to wait to get a sprocket bored out that I got back today. I then tried to get my motor to run in reverse via swapping the PHASE wires like you tried....
(this sounded the simplest way, and was after id spent some time soldering up and heat shrinking the sensor wires
damcard wrote:I do have a question for the masses. I need to run my cyclone in reverse direction. I have tried swapping phase, phase/sensor, and sensor wires. Every combination I find that works runs the motor in the wrong direction. Could anyone suggest how to alter the diagram at the top to run the cyclone motor in reverse with this Lyen controller? Can I simply program the controller to run in reverse? -Damcard
....but unlike you any combination I try results in the motor not turning and a rather worrying grinding noise comming from the motor as the wooden board bounces around?
Looks like Ill have to strip everything back down and try rewiring the sensor wires as you did.
Fingers crossed all goes well.
Regards
Tom
