Post up your photos, share & discuss
I'll start things off with a few that I know of...
Mark_A_W wrote:Full-Throttle's bomber is missing something...
voicecoils wrote:Voicecoils' Stealth Fighter
Kepler wrote:Looks good voicecoils. Are you going to run 100V?
WARNING: MOdding your Stealth bike will void your warranty... but it will probably be fun ;-D
voicecoils wrote:Kepler wrote:Looks good voicecoils. Are you going to run 100V?
That's the plan24S4P of 6S 5Ah lipo packs should fit, but I'd better make some mockups before I head to hobbycity and pull the trigger.
- Code: Select all
turbodan78 wrote:@ voicecoils... good idea for this page! i will try and get some interesting pics up when mine arrives... will be good to see how something ''very'' good can be made better again! does anyone know roughly how much speed you could get from upping the volts on the intermediate motor, i have no idea
Kepler wrote:voicecoils wrote:That's the plan24S4P of 6S 5Ah lipo packs should fit, but I'd better make some mockups before I head to hobbycity and pull the trigger.
It fits 14 x 6S 5ah Turnigy packs OK. I think you will have trouble getting those last 2 packs in to make up 20ah 100V but it might be possible.
I run 30S 2P as the main pack and throw in a reserve 24S 1P pack for extra endurance when l need it. The 24S 1P is my "get me home pack"
Warranty, yes that's long goneNever worried me in the slightest though. The frame and mechanics are bullet proof and electrics really not that expensive to replace if something breaks from me pushing the boundaries.
full-throttle wrote:Mark and his X-Ray visionYeah the batteries have not arrived yet.
Kepler wrote:I run 30S 2P as the main pack
Grips are for softies!
No, seriously - just misplaced the 'lock-ons'
turbodan78 wrote:''Kepler wrote... I think the intermediate motor is good for 60 kph to 65 kph stock. I use the high torque motor which did about 65 kph on 100V and 80 kph on 125V. 65 kph was plenty fast enough and a speed I could only use occasionally. I have only pushed the latest setup to 80 kph just to see if it could do it and rarely go above 60 kph.
turbodan78 wrote: Kepler... cheers for the advice, did you mean you managed to get the high torque motor to 80kp/h ? that is good to know if so but the managing of batteries like that i beyond me still/for nowalso pushing the intermediate motor in amps and volts would probably not be a good idea if hitting heaps of hills and soft ground hey
will be good to hear more of these other mods as they come to light
Mark_A_W wrote:Unless you get a LH throttle, you will be running the shifter backwards on the LH bar end.
I had a similar setup with the twist shifter you gave me and a normal derailleur. I found it impossible to shift down while braking. So I fitted a rapid rise derailleur which works backwards, and now I have the normal action of the twist shifter, just on the LH bar.
You can't do that with the gearbox shifter, unless you can reconfigure it internally.....or drive it with a stepper. We could do that, we have the technology
Users browsing this forum: loco13, Ryanthelion and 7 guests
