Hill Helper
Re: Hill Helper
Postby rearengine » Tue Mar 08, 2011 2:43 pm
Spinner... What size is that roller ? I'm going fast enough for me with the 1.25 roller.. I haven't had any loss of sync or power drop .. I peddle to 8-10mph then hit the thottle hard enough so it jumps off the ramp... once on the tire it's 80-100% throttle ... I do hear some what of a scream on the way up, but never any power loss, just really good acceleration up over 24 mph .. hot off the charger @ 26.9 - 27.2 v ... The only gadgets I have for testing are my hands :D every thing is luke warm... And that's 8)
I think I would like to try a knurled roller ... It would be cleaner , and easier on the tire.. ya think?..
Bill
rearengine
Re: Hill Helper
Postby spinningmagnets » Tue Mar 08, 2011 3:41 pm
Cunning until the oneway bearing locks up
Although these type of one-way needle bearings actually have a very good record in industry, those normally have some automatic clean lubrication built-into the system. I can imagine an FD customer never greasing them, (just a smear of grease needed every 6 months or so?) and I imagine the bearings would start producing a dry screetch before complete failure (as I have seen bearings do in the past).
The more I think about your ramp, Bill, the more I like it. And then by adding the steel roller, it would do three things for me. It eliminates greasing maintenance, eliminates the need to occasionally replace the sandpaper, and it clearly removes all possible drag when unpowered. The drag right now is so low I can't feel it, but if an improvement eases a customers concern, it is worth pondering.
Any round thing can be knurled by a jig in a machine shop, though they prefer to do the knurling when the steel is at its softest (before the hardening process), so that the tooling lasts longer and the knurls are deeper and sharper. If you'd like to try out the BMP 1.0" roller, its yours for the asking (your thread here has helped me a lot, its the least I can do!). Going from 1.25" down to 1.0", your top speed would drop from 24-MPH to roughly 20-MPH, but the hill-climbing should be slightly better (less motor-bog, less heat)
spinningmagnets
10 GW
10 GW
Re: Hill Helper
Postby Kepler » Tue Mar 08, 2011 5:48 pm
I really like the launch ramp addition to the friction drive concept. Looks like you have it sorted nicely. This setup really negates the need for one way bearings in the roller. Unfortunately it’s a little more difficult to achieve with the roller hanging above the tire as on a standard bike configuration. I am playing with some ideas using the motor shaft as a launch roller. Having gone to a single swing arm, I can now use the other side of the drive to mount a relatively compact launch ramp mechanism. Not sure if I really need it but certainly worth experimenting with.
Current Rides
Carbon Super Commuter: ON ROAD http://endless-sphere.com/forums/viewtopic.php?f=6&t=47139
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
75 Volt 2.5 kW Stealth Fighter: OFF ROAD http://www.stealthelectricbikes.com/
Kepler
Re: Hill Helper
Postby rearengine » Tue Mar 08, 2011 10:10 pm
Hey Kep ... Thanks for taking a look ... So far I couldn't be happier with the set up .. I say sofar because I don't have nearly the miles on it as you do on yours.. The ramp has given back the free wheeling of an unassisted rear wheel .. I'm sure a ramp would work on yours with a fixed arm on the off side of the drive ... HA!! I sure as hell don't have to tell you how to do it ..
Spinner is sending me his knureld 1" roller to play with .. With out the one way bearings it might slam it back to the park / launch ramp pretty hard ... WE shall see.. I'm glad it's 1" so I can keep cadence with it when I want .. The 1.25 is to fast for me now .. sending a pic with the original soft park taken off..
Picture 043.jpg (118.71 KiB) Viewed 581 times
rearengine
Re: Hill Helper
Postby rearengine » Fri Mar 18, 2011 2:30 pm
I can't say I'm real happy with the 1" roller wth out the one way bearings in it ... The free wheeling roller didn't bounce on engagement from the launch ramp ... 1.25" roller seams to be the right diameter for me...
Do any of you know where I could find a 1.25" one way KNURLED roller ? I emailed Bikemotorsports ,said they stopped offering them 2 yrs ago .. Bill
rearengine
Re: Hill Helper
Postby rearengine » Mon May 30, 2011 9:05 pm
Well I smoked the works ,Esc & motor .. I should say my son did .. I am using the servo tester for throttle , and I didn't tell him that it wouldn't return to off ... He hit the brakes , and you know the rest of the story ... Lots of smoke , but no one hurt ...
It seems this is obout the only motor that isn't on back order at Hobby king .. Can any one tell me if this motor has a skirt bearing ? I'm thinking this motor If it has the bearing & 120 amp or more ESC.. Leme know what you think ...
Kepler which Hyperion motor are you using ... can't find the thread that you listed the different motors you spect... Thanks Bill
6374-170 (Small).jpg (31.37 KiB) Viewed 464 times
rearengine
Re: Hill Helper
Postby adrian_sm » Mon May 30, 2011 10:22 pm
Yep. I have only bench tested it, so can't tell you much more than:
- No skirt bearing.
- 2.3 no load current.
- Bearing quality is not great, I get weird resonance sound at one speed, and some rattle that sounds like it is the bearing.
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
Build #??? ~21kg ~1500w Adrian's Bafang BPM Hardtail MTB Bafang BPM code12, 15s LiPo, ~40kph, ~30kms
adrian_sm
Re: Hill Helper
Postby spinningmagnets » Mon May 30, 2011 10:40 pm
Keplers default motor of choice seems to be the Turnigy 6374-200kV, which does have a skirt bearing. I believe he was using 5S to get around 25-MPH.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=3890
He tried the Aeolian 63mm motor with a 170-kV at 6S because he hoped it would have the same speed but lower amp-draw (heat being a concern to pay attention to with a motorshell-drive). I don't remember if the Aeolian has a skirt bearing. Its possible that it might not, and if they had worked out for Kepler, he could special order a batch with the 63mm skirt bearing added...
http://www.hobby-parts.com/aeolian-c6374-kv170-brushless-rc-motor-for-rc-airplane-p-414.html
Last edited by spinningmagnets on Mon May 30, 2011 10:49 pm, edited 2 times in total.
spinningmagnets
10 GW
10 GW
Re: Hill Helper
Postby Whiplash » Mon May 30, 2011 10:40 pm
I have over 200 mikes on one and is been through hell with melted together phase wires and the lot, great little motor for the money!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Re: Hill Helper
Postby adrian_sm » Mon May 30, 2011 11:01 pm
Yes the Aeloian 6374-200 motors have a skirt bearing.
I bought all the available motors suitable for my friction drive from HobbyKing recently, and the only one that had a skirt bearing was the 6354-250kv.
http://www.hobbyking.com/hobbyking/stor ... oduct=5144
But they appear to be out of stock at the moment too.
The Aeolian would be the best bet.
adrian_sm
Re: Hill Helper
Postby Kepler » Tue May 31, 2011 12:29 am
Just an update on the Aeloian 170 kv motor. Yes it does have a skirt bearing and looks very similar to the 63-74 in construction. It does however seem to loose sync much more easily then the 63-74. Aeloian 200kv motor might be better for sync. I didnt see much advantage in terms of low speed operation in relation to heat and current draw. Still think the 63-74 is the best choice. Wish they would hurry up and come back in stock. I will order the Aeloian 200kv and see how that goes.
Current Rides
Kepler
Re: Hill Helper
Postby rearengine » Tue May 31, 2011 9:47 pm
I thought the SK 6374 might NOT have a skirt bearing ...Thats why it is the only one that isn't on back order I would guess... If any of you have a motor you want to part with , I'm a buyer..
I've changed my drive to running on the can , and it really ran well ... The 280 KV was a little faster than i wanted to go , so i'm thinking 200 or less would be great ... Guess I will put my order into Hobby King , and get in line ... Maybe I'll try the Aeolian 6374 200 since we know it has the skirt bearing...
I thank you all for the replys ... Bill...
rearengine
Re: Hill Helper
Postby rearengine » Tue Jun 07, 2011 5:13 pm
Has anyone used this controller ? If so what do you think of it ? It is in stock ... Maybe thats bad :?.. Bill http://www.hobbyking.com/hobbyking/stor ... duct=16367
rearengine
Re: Hill Helper
Postby adrian_sm » Tue Jun 07, 2011 10:03 pm
Not me. But I like the adjustable LVC, and aluminium enclosure. Might also be relatively straight forward to water proof.
I think I avoided buying one last time around becuase of the poor user rating, but reading the reviews thery are all around an incorrect label, not performance. Not much feedback on performance in the reviews though...
Let us know how it goes if you get one. Otherwise I'll buy one next time I place an order.
- Adrian
adrian_sm
Re: Hill Helper
Postby Hillhater » Tue Jun 07, 2011 10:05 pm
adrian_sm wrote:Yes the Aeloian 6374-200 motors have a skirt bearing.
Adrian,
have you run the TK 6354 -250kv yet ?
The one i have so far has refused to stay in sync with any combo of controller or setting that i have tried.
Just an update on the Aeloian 170 kv motor. ..... It does however seem to loose sync much more easily then the 63-74.
Kepler, .. is that with the Castle controller ??..or one of the Turnigy's ?
Hillhater
1.21 GW
1.21 GW
Re: Hill Helper
Postby adrian_sm » Tue Jun 07, 2011 10:10 pm
No. Sorry work & personal lives are way too hectic at the moment.
I'll post results on my thread, when I get a chance to play.
adrian_sm
Re: Hill Helper
Postby rearengine » Thu Jun 09, 2011 11:35 am
Well I have the Turnigy dlux 100A SBEC coming ... They say it's shipped , could take 48 days :( I took the 63-64-280 motor apart and it looks ok , with a little luck, maybe it's just the 85A esc that fried ... I'll let yall know how it works out , when up and running ... Bill
rearengine
Re: Hill Helper
Postby rearengine » Tue Jun 14, 2011 4:37 pm
Well .. I'm all set for the new controller from Hobby King ... If it ever gets here ... Going to put it between the mount plates you see in the pix ... Has anyone tried to track an order from Hobby King ? Another question .. How do you log in to Hobby King's US warehouse ? They say it's open ...Castle Creations is state side , is that right
Picture 007 (Custom).jpg (28.61 KiB) Viewed 811 times
Picture 008 (Custom).jpg (36.23 KiB) Viewed 811 times
Bill
rearengine
Re: Hill Helper
Postby Hillhater » Tue Jun 14, 2011 8:09 pm
rearengine wrote:... Has anyone tried to track an order from Hobby King ? Another question .. How do you log in to Hobby King's US warehouse ?
I used the tracking option for a delivery to Australia and it was spot on. It told me exactly where the package was at any day, and even told me when(to the hour almost) to expect the courier at the door ! :o
Logging on to your local w/house is just a matter of picking the "USA warehouse" option from the RH side of the HK "Home" screen.
Hillhater
1.21 GW
1.21 GW
Re: Hill Helper
Postby rearengine » Tue Jun 14, 2011 9:56 pm
Thanks Hillhater... I thought that tab was just for email.. AS far as tracking , all I get is it left Hong Kong for US ... Ah well thats a start :) Bill
rearengine
Re: Hill Helper
Postby rearengine » Fri Jul 29, 2011 12:45 pm
I got my new ESC & servo tester a while back , the motor didn't go up in smoke with the rest of the parts... I'm running the 6364-280 motor with the new 100-120 amp esc... The Black & Decker trimmer battery leaves a lot to be desired , but serves till I can get 5000mah 6s.. I have about 30 miles on this set up , so far I like it ... I haven't put Friction tape on the can ,And don't think I will ... It works like a friction clutch on take off , I peddle up to 8-10 mph before twisting the ST wide open .. Made some more changes to the mount .. It's about as simple as it gets... Some pix if interested... Bill
Picture 040.jpg (132.22 KiB) Viewed 705 times
Picture 041.jpg (136.1 KiB) Viewed 711 times
Picture 046.jpg (117.91 KiB) Viewed 705 times
rearengine
Re: Hill Helper
Postby adrian_sm » Fri Jul 29, 2011 5:28 pm
Looking good mate.
How is the new controller. I was thinking of buying one to test out, but don't really have a need for one as all the other controllers I have work fine.
- Adrian
adrian_sm
Re: Hill Helper
Postby rearengine » Fri Jul 29, 2011 8:49 pm
Adrian .. The controller is good, working fine , Stays cool but I'm only running 18 volts .. The programing is the same as the Turnegy 85 amp that you have,and I got from Spinner with the two large caps he put on .. I do miss the on -off switch though.. I don't have any real tech stuff to tell you ... I pretty much go by sound , and feel I guess.. I can say that Black & Decker gets pretty hot & doesn't go very far on a charge.. The controller has low voltage settings, witch is a good thing ...
I have a question ... I have the TWO wire on-off switch from the old 85 esc ... Could this switch work by taping into one of the THREE wires going to the Servo tester ?? the 2 came out of the controller before..
Bill
rearengine
Re: Hill Helper
Postby adrian_sm » Sat Jul 30, 2011 1:57 am
Yeah me too. I love the on off switch. I is the main reason the controller is my favorite.
You could use the switch to cut the 5v line. This will stop the throttle working, but the controller will still be on.
- Adrian
adrian_sm
Re: Hill Helper
Postby rearengine » Wed Aug 31, 2011 3:20 pm
Is there a tutorial on ES on how to post a You Tube Video ??
I have a video of my drive on You Tube that I would like to put on here ... Any help appreciated...
Bill
rearengine
PreviousNext
Users browsing this forum: Megalowmax and 6 guests
