boostjuice wrote:Hyena, which freewheel/s are you referring to? GB output freewheel, freewheel crank/chainring or freehub?
I was referring to the rear wheel hub - I assume he's using a standard-ish one with the mention of 9 gears ?
Hyena wrote:Nice!
What is the battery capacity of the down tube ? Iooks like it'd hold 8 6S 5ah packs ? So 12S4P or 24S2P ?
AussieJester wrote:The battery capacity within the frame is 15ah worth
of 6s batteries...
Timma2500 wrote:Getting the gearbox mounted will be relatively easy, just time consuming with my high-tech drill press style of cutting lol
Timma2500 wrote:Hey i just saw your build thread Simon, the Black Vigilante looks awsome! That'd be great if you could come along, the more the merrierWould be a good chance to see the Black Beast in the flesh too.
Yeah i'm down in Boganham ah i mean Rockingham...Cloverdales up near Kewdale isn't it? Can you tell i'm a banana bender fresh off the boat? lol
Kids are terrific disease carriers / spreaders, too good (the little turds!!!) in fact, i'm always catching a bug off them..
Paul
Paul
Cheers. I wouldn't have the faintest idea on range etc on this build, the gearbox never lasted longer than 5km before stripping teeth off as per the pics above...waynebergman wrote:Very nice bike by the way. Do you know what kind of range could you get out of your set up here say on a flat road going 30mph and no pedal assist, I am assuming with the ability to gear your drive you can get some good efficiency out of this bike?
waynebergman wrote:I am guessing you have fabricated the motor mount and battery holder out of 6061 aluminum. I am curious if a person finds a frame that is a candidate for such a project are you having to worry about the series of aluminum that the frame is made of or do you just go for it with the 6061 stock for the customizing and weld it to whatever the frame happens to be made of. My guess is that 6061 would work with most Aluminum frames but I am not sure.
Hyena wrote: Wow those gears were really minced! What was the story with that again ? And what did you replace them with ?
Hyena wrote:I like the pic next to the turbo housing, that'd make a good inconspicuous gearbox side cover hanging off the side of the bike
Samd wrote:Subscribed.
Users browsing this forum: deepfraught and 7 guests
