shocktotheweb wrote:Got the Lyen 12 X 4110 MOFSET controller and hgve a couple questions:
1. Lyen pre-programmed my controller for me to 48v, how can I display the current setup on my controller in the Lab Software?
2. As I understand it, if the regen is jumpered then regen works whenever I am not throttling more than the current speed of the motor. If I short the brake yellow and black, that will apply regenerative BRAKING to the moto. Is this correct?
3. Can I, using the controller software, see what the regen is set for voltage and amps?
4. What happens when the low voltage number is met?
shocktotheweb wrote:If I short the e-brake wires from the controller, will regen braking occur? All the way to 0mph?
The Mighty Volt wrote:AFAIK, the BMS plugs into the brake-connector of the controller.
i have the two white wires, can I wire these into a Universal Handlebar Switch for braking??? Or do I have to use the yellow/black wires of the controller.
Are there any special considerations I need to bear in mind? What happens to my battery when I regen?
Make SURE that brake can stop you completely even if the regen doesn't work at all. Regen is a complex system, requiring the motor, controller, battery, BMS, and brake switches all to work correctly over a wide voltage range. Lots of things can cause "issues" with it (but hardly ever do), and an issue at high speed where you need to stop quickly means you better have a mechanical brake that will let you do that.I won't have a mechanical rear brake, too much effort setting it up, welding etc.
I will have a mechanical front disc brake for basic stopping needs.
Zenid wrote:I bought the 12-FET versiion of this controller about a week ago, and with the exception of one minor gripe I've been very happy with it so far.
On my initial test drive, though, with the controller set to 50A/125A rated/phase. I noticed something odd just now and again: I found that this was if I tried to start from a dead stop - or very slow - with the throttle wide open. There would be a 'thunk' as power to the motor would cut off. It wouldn't pull power unless I opened the throttle more gradually, then fully once I was moving.
However this seemed to go away after the first journey. Yesterday, though I raised the current to 55A/135A, and the problem came back with a vengeance - clearly there is some kind of current limitation in operation here. Lyen said the controller was capable of pulling 65A continuous in its existing form, but clearly things aren't set up right or another modification needs to be made to enable this to happen.
I'm hearing lots of talk about "shunt values", and the fact that they sometimes have to be changed to enable you to draw more current. Am I going to have to make a change here too?
If so, then this doesn't sit easy with Lyen's assurance that the I can draw 65A from this controller in its current form, as that clearly does not appear to be the case...
icecube57 wrote:I would have strongly advise you to upgrade to an 18fet right away. It seems like you need alot of current to feed you hungry motor and the 12fet isnt up to the job in its stock condition it has to be really beefed up. It seems like the performance you are after and the motor you have... you are going to need 75-100A to get the going for a dead stop without it hitting the current limit of the controller. One thing about these low turn motors is they arent very forgiving. They only think of themselves in operation. They want all the current they can take and dont care if the controller can keep pace with it or not. Everything else will die before the motor will. Ive ran a low turn count motor and its a blast when fed properly but its a pain in the ass and its a costly road to walk to find that butterzone to where you and the motor is happy.
{...} Oh yeah.... keep playing around and bumping the current limit up you will surely kill your controller. I personally dont go above 45-125 myself.
aaronski wrote:my Lyen 12 fet is set to 65/65, with no issues. when I set the phase currents that high I also see it cutting out to protect the controller if I floor it from a dead stop. I actually have it on my "to Do" list to try every phase setting at 65 amp battery settings and see where the limits are. With any luck I'll have that info on Saturday to give everyone a feel for where this controller freaks out.
also, thanks for the Block time info. if it's unlimited, won't it trip just like it does when phase amps are set too high?
Zenid wrote:You're using 65A for both rated AND phase current? Everybody else I know is using a phase current of around 2.5 times the rated current (such as 30/75A, 50/125A etc.). How do we decide what multiple to use, and with what kind of motor? Is it just trial and error, or is there some reasoning behind this multiple. Nobody I've asked seems to understand why this figure (2.5) is used and what can happen if others are used instead, except that there can be 'odd effects'...
Zenid wrote:There would be a 'thunk' as power to the motor would cut off. It wouldn't pull power unless I opened the throttle more gradually, then fully once I was moving.
bmxed wrote:Hi Zenid,
This is probably no fault of the Lyen controller. See if you have a BMS in your battery pack and what the current rating is. It might be sensing an over-current condition and is shutting down to prevent damage to the battery.
