icecube57 wrote:I just recently got another job. Its security for a very large apartment complex. I thought this would be a perfect application to use my ebike to cover the grounds. It takes almost 30-40 min to completely walk the property.. thats taking shortcuts and walking through buildings to save time and distance.
icecube57 wrote: I hear something shaking in the controller. Im like wtf. What popped in my head is I though the shunt or the traces on the controller got hot enough to reflow the solder and drip away from the traces. So I though I had some solder beads or shunts just rattling in the controller box. I finally get the controller open and guess what falls out. A resistor. R01 resistor just fell out of its hole. But everything else looks fine. I soldered it back in and it works fine.
chroot wrote:and rest kind of hardened silicon or epoxy filled
Once you do it and you will not able repair if it needed
ambroseliao wrote:Hey Ice,
What voltage were you seeing running WOT? Doesn't the Lumenator draw off your CA and can lower your voltage a bit?
Ambrose
Users browsing this forum: Bing [Bot], ecologymagnet, Google [Bot], miro13car and 13 guests
