Ykick
1 GW
LFP - Live Fire Pricks...
liveforphysics said:Arlo1 said:Bahahaha You Stressed the motor a bit all right!
LMFAO
I do tend to lean on things a little harder than most folks.
Big Tuna said:liveforphysics said:Arlo1 said:Bahahaha You Stressed the motor a bit all right!
LMFAO
Hit it with the house buddy :wink:
auraslip said:Excuse my ignorance, but what exactly killed the motor? The heat obviously, but what did it kill? The phase cables and the hall sensors? Did the copper melt? Did the magnets go past their Curie temperature and lose their magnetyness? (trying to sound like I don't know what I'm talking about here because I don't)
Is it possible to rebuild this motor?
Hate to see all your hard work destroyed with out even a good ride on it....
John in CR said:They pumped 40hp of electricity into the motor and only got 10hp of work out of it. The other 30hp turned into heat, mostly in the windings. That's over 20kw of heat , which caught the wire varnish on fire shorting the phases for those beautiful plasma flashes. If you're going to burn up a hubbie, you might as well do it right.
They pumped 40Kw (53.6hp) into that motor!!!!John in CR said:auraslip said:Excuse my ignorance, but what exactly killed the motor? The heat obviously, but what did it kill? The phase cables and the hall sensors? Did the copper melt? Did the magnets go past their Curie temperature and lose their magnetyness? (trying to sound like I don't know what I'm talking about here because I don't)
I cant remember if this was lukes sevcon controler or the big Kelly but yes it would work for collossus its just that both kelly and sevcon controlers are not cheep!nieles said:John in CR said:They pumped 40hp of electricity into the motor and only got 10hp of work out of it. The other 30hp turned into heat, mostly in the windings. That's over 20kw of heat , which caught the wire varnish on fire shorting the phases for those beautiful plasma flashes. If you're going to burn up a hubbie, you might as well do it right.
so the controller was be able to limit the current to the phase wires when shorting? that means mabye this controller can even withstand one of the big outrunners wihtout blowing the fets.
Arlo1 said:I cant remember if this was lukes sevcon controler or the big Kelly but yes it would work for collossus its just that both kelly and sevcon controlers are not cheep!nieles said:John in CR said:They pumped 40hp of electricity into the motor and only got 10hp of work out of it. The other 30hp turned into heat, mostly in the windings. That's over 20kw of heat , which caught the wire varnish on fire shorting the phases for those beautiful plasma flashes. If you're going to burn up a hubbie, you might as well do it right.
Doctorbass said:luke.. have you any pic of the inside o fthe sevcon??
liveforphysics said:Doctorbass said:luke.. have you any pic of the inside o fthe sevcon??
Yes. Explicit photos of everything inside the case.
It's 6 rows of 7 TO-220 fets in parallel. It runs the infinion brand 150v FETs, which are actually pretty good stuff. Lots of good cap. Hall-effect based current sensors on 2 of the output phase legs. It's a pretty solid piece.
