Motorcycle Hub Motor Part 2
Re: Motorcycle Hub Motor Part 2
Postby Ricky_nz » Fri Feb 18, 2011 1:20 am
liveforphysics wrote:Hook the leads up to a CO2 fire extinguisher nozzle before the start of the race (or put one on the bike),and get that motor in a deep-freeze on the starting line. :)
But that won't get it super conducting,
perhaps try some liquid helium :lol:
PS: I know copper isn't really a super conductor but I imagine its resistance would still be quite low at those sort of temperatures.
Latest Projects: High power vector controller for Turnigy 80-100, Keewe Stealth DJ bike with Turnigy 80-100 180.
Youtube channel: http://www.youtube.com/user/rwhitenz?feature=mhum
1) Specialized Hard Rock + surviving 1/2 of Elation 300W + Sick Bike Parts freewheel and sprockets + echo cranks.
2) Commuter bike with 1000W GM rear hub.
Ricky_nz
Postby Alan B » Sun Feb 20, 2011 12:41 am
CO2 cooling! Great! Now we can have a bigger carbon footprint! (Of course every tank of gas we burn is produces several hundred pounds of CO2 so the amount one would use for cooling is actually pretty small).
This may have merit on our regular hubmotors. A small tube can bring CO2 in. Some one way flaps in the covers can let it out. Just use it when you really need to keep the motor from overheating! Like that one big hill climb!!
Sorry, back to this great motorcycle hubmotor thread...
Which are the best m/c frames to use this on? A list of good choices would be useful. Perhaps some photos of examples collected in one place.
Thanks!
Alan B
1.21 GW
1.21 GW
Postby markcycle » Sun Feb 20, 2011 6:52 am
Alan B wrote:CO2 cooling! Great! Now we can have a bigger carbon footprint! (Of course every tank of gas we burn is produces several hundred pounds of CO2 so the amount one would use for cooling is actually pretty small).
Thanks!
http://www.enertrac.net/photos.php
markcycle
Postby patrickza » Fri Mar 04, 2011 2:28 pm
Ok who's going to design a really lightweight car with two swingarms + 2 du603's at the rear driving it!
Great work Mark.
Greyb.org, Cromotor, Headway 83.2v 20AH, Lyen 18 fet: viewtopic.php?f=3&t=45514
Kona Kahuna, x5305, Headway 76.8v 10AH, Crystalyte 72v48A: viewtopic.php?f=3&t=10256
Bladez Scoot, 450W motor putting out 3kW, Headway 38.4v 10AH, Lyen special controller: viewtopic.php?f=35&t=25872
patrickza
Postby johnhead@frontiernet.net » Fri Mar 04, 2011 11:57 pm
Car NO but motorcycle Yes!
Thanks to Marks great motors and his excellent customer service!
Postby Stevil_Knevil » Sat Mar 05, 2011 1:38 am
+3 ^
Cars lean the wrong direction in turns :)
Stevil_Knevil
Postby TomA » Mon Mar 07, 2011 10:24 pm
Hey Mark:
Neat progress on the motor, especially with the cooling.
I love the forced air cooling, which I probably would make into a CO2 on-demand system, with the custom aluminum wheel likely being fine for me most of the time.
There's still a lot of room for improvement in the wheel's capacity to dissipate heat.
First, surface finishes have a big impact on heat transfer efficiency. Polished metal has about the lowest emissivity of any surface, and what you actually want there is to take advantage of black body radiation on the surface of your heat exchanger. That's why radiators are usually flat black. Black anodizing a dull aluminum surface on the outer wheel would be good, but a thin coating of flat paint is actually better- and cheaper. Here's an interesting short paper about it from the computer business:
http://www.vxibus.org/files/Transferrin ... 20Heat.pdf
There's also a lot of room for improvement in the shape of that wheel. Ideally, it would be like a turbine blade, with axial cooling fins pulling air through itself and around the motor. Probably prohibitively expensive to cast, but fewer, wider blades with enough spacing between them for the machine tools to work could be CNC milled from a thick blank, perhaps within reason on cost. if that isn't practical, blades could be made separately and fitted to spokes cut into the wheel. If nothing else, axial and/or radial fins like on the brake drums of old bikes and cars would also help remove the heat, but they would work even better with the fan blades- cast, machined or attached.
Lastly, even with the best possible fit, the motor should be mounted in the wheel with thermally conductive paste to maximize heat transfer.
Just some ideas for you. By the end of the year, I'll hopefully be needing a setup like this. Also very interested in the 2-4 turn switching.
Great job so far, Mark.
TomA
TomA
Postby markcycle » Wed Apr 20, 2011 2:53 pm
EnerTrac is sponsoring team Catavolt with a custom in wheel motor for the TTXGP
Here is a write up on the team and EnerTrac
http://www.egrandprix.com/news.php?id=202
Yea I know it's a little over the top
markcycle
Postby ryan_lirui » Thu Apr 21, 2011 6:22 am
Would it be possible to get a 603 in a 10 inch rim?
ryan_lirui
Postby markcycle » Fri Apr 22, 2011 7:51 am
ryan_lirui wrote:Would it be possible to get a 603 in a 10 inch rim?
Smallest we do standard is 16 inch
If you have the rim I'll look at it and see if it is possible
markcycle
Postby whatever » Sat Apr 23, 2011 7:51 am
how long till crystalyte sell it to all and sundry...........mmmm
whatever
Postby markcycle » Sat Apr 23, 2011 9:04 am
whatever wrote:how long till crystalyte sell it to all and sundry...........mmmm
You think
I'm about to place a order for my third container of motors I take a basic motor and turn it into this
and this
and this
We may have a motor wound in China but EnerTrac builds wheels and traction systems for customers
markcycle
Postby johnhead@frontiernet.net » Fri May 20, 2011 8:39 am
Mark,
Great looking new wheel designs. I may have to design a LOWRIDER, two wheeler around one of these? It only takes time and $$$$! :-)
John Head
Postby markcycle » Sat Jul 02, 2011 8:09 am
The EnerTrac.net dual motor on the Catavolt race bike
here is the link to the full set
http://flic.kr/s/aHsjvmpAjw
markcycle
Postby SplinterOz » Sat Jul 02, 2011 9:29 pm
Thanks for the link :) Next race is 4pm this afternoon. I will let you know any info as I get it.
SplinterOz
In the Capital of Australia
http://rgelectric.wordpress.com
SplinterOz
Postby markcycle » Sun Jul 17, 2011 9:09 am
Forced air cooled thru the axle Dual motor mounted on the Catavolt Race bike.
Race Report
http://t.co/saxvgHJ
Catavolt_amy Omara.jpg (38.81 KiB) Viewed 1397 times
markcycle
Postby markobetti » Sun Jul 17, 2011 12:08 pm
Congratulation to Marks motor and Catavolt team !
markobetti
Postby markcycle » Sun Jul 17, 2011 11:25 pm
markobetti wrote:Congratulation to Marks motor and Catavolt team !
Thanks more hard work ahead as we tweak the bike for the next race. Its hard when the competition is running Lipo VS our heavy tin can headway cells
markcycle
Postby markobetti » Mon Jul 18, 2011 10:11 am
Well that sucks since i dont think the fuel aka batteries should decide the winner .. You dont see in gas races diferent mixes of fuel ; at least i think so. Anyway i read on some e blog that catavolt motor is 10 kw continious; shouldnt it bee 20kw? Good luck on races to come
markobetti
Postby markcycle » Mon Jul 18, 2011 10:34 am
markobetti wrote:Well that sucks since i dont think the fuel aka batteries should decide the winner .. You dont see in gas races diferent mixes of fuel ; at least i think so. Anyway i read on some e blog that catavolt motor is 10 kw continious; shouldnt it bee 20kw? Good luck on races to come
the motor I developed with forced air cooling is more like a 50KW motor
markcycle
Postby markobetti » Mon Jul 18, 2011 11:52 am
markobetti
Postby markobetti » Mon Jul 18, 2011 11:57 am
http://green.autoblog.com/2011/01/21/en ... acing-big/
here it is.. just tell them if you like to fix the data
markobetti
Postby markobetti » Mon Jul 18, 2011 11:58 am
just saw its January date..... just ignore me , its better :)))
markobetti
Postby Nuts&Volts » Mon Jul 18, 2011 7:45 pm
peak rating, you saying? Anyways great job mark, i think that double stack motor will start kicking some azz soon. Having ridden a heavy bike with one of your standard motors, i am quite impressed and cant wait to follow your continued process
Nuts&Volts
Postby dangerzone » Tue Jul 19, 2011 11:55 am
markcycle wrote:the motor I developed with forced air cooling is more like a 50KW motor
Hmmm, which controller setup did you plan to use..?
dangerzone
PreviousNext
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: No registered users and 0 guests
