DC to DC Multi-Purpose Voltage Converter $14.98
Re: DC to DC Multi-Purpose Voltage Converter $14.98
Postby shorza » Tue Mar 15, 2011 1:23 am
Great, cheers. How do you determine the voltage out? or is it always 4v?
shorza
Postby NeilP » Tue Mar 15, 2011 3:11 am
To run these at higher input volatages...72 (84v) or more could you wire a pair in series on the input side? or would thatnot work if the output from one was not eh same as the output from the other?
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
10 GW
10 GW
Postby thewmatusmoloki » Tue Mar 15, 2011 4:06 am
Fechter can explain these better than me, check out this thread from 2007....
viewtopic.php?f=16&t=2264
shorza wrote:How do you determine the voltage out? or is it always 4v
Regardless of the input voltage the output is always at the rated dc volts in my experience.
There is no spoon.
thewmatusmoloki
Postby NeilP » Tue Mar 15, 2011 3:27 pm
I did read through the post you mentioned, and all i can see about putting supplies in series, is using the outputs in series...not the inputs.
If I had two of these supplies as mentioned in this current thread, with Max input voltage of 60volt, and setup two of them in series on the INPUT side ...so 84 volts across two of them in series, so 42 volts across each one under no load conditions...will that work if the outputs of both have different loads on them?
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby hillzofvalp » Sat Apr 16, 2011 9:21 pm
Is this just a glorified LM317T?
hillzofvalp
Postby Lyen » Sun Apr 17, 2011 5:26 pm
Hi hillzofvalp,
Thanks for your interest in the DC to DC multi-purpose voltage converter. It actually uses a number of electronic components other than the LM317T. For further technical inquiry, please email me at LYEN@HOTMAIL.COM.
Best Regards,
Lyen
hillzofvalp wrote:Is this just a glorified LM317T?
Items For Sale
Please sign up here and donate your marrow to save life.
Lyen
Postby icecube57 » Thu Apr 28, 2011 3:50 pm
Is it possible to wire 3 of these parallel to a power supply at 48v and series the output of the converters to make a high voltage variable power supply.
Is the current limited internally or would they have to be regulated externally.
Im essentially looking for a way to turn my 48v power supply to a 75v charger.
icecube57
1 GW
1 GW
Postby Lyen » Thu Apr 28, 2011 8:59 pm
Hello Icecube,
Thanks for your interest in the converters. You may consider a step up voltage converter to up convert from 48v to 75v.
Regards,
Lyen
icecube57 wrote:Is it possible to wire 3 of these parallel to a power supply at 48v and series the output of the converters to make a high voltage variable power supply.
Items For Sale
Lyen
Postby webfootguy » Fri Apr 29, 2011 12:37 am
No you can't because these are not isolated. But, if you did get an isolated DC/DC converter at the right voltage, you could series the output with the 48v input to boost the 48v to 75v easily. You would need a 75-48v = 27v converter. Make sure you find one that says the output is isolated from the input and you are good to go (as long as you deal with limiting the current)
webfootguy
Postby NeilP » Fri Apr 29, 2011 1:16 am
How could these be used with a 84 v supply?
I do not want to tap into the supply for a lower voltage and un balance the pack...could the inputs of two be wired in series? and then use the outputs independantly? one for back lights one for front lights?
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby wojtek » Fri Apr 29, 2011 10:46 am
another question- are there any converters available that would take around 20W-30W out?
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby Lyen » Fri Apr 29, 2011 10:05 pm
Hi Woktek,
Thanks for your interest in the DC converters. I think the converter is ready 20-30W capable according to the specification. For example, power is voltage multiply by current. So for instance, 10v at 3A is already 30 watts.
Regards,
Lyen
wojtek wrote:another question- are there any converters available that would take around 20W-30W out?
Items For Sale
Lyen
Postby mikebikerad » Mon May 02, 2011 11:11 pm
Recieved mine. Works awesome and powers up my magic shine nicely. Running it on 48 volt battery.
mikebikerad
Postby NeilP » Thu May 05, 2011 3:12 pm
Well after a couple of PM's with Lyen, and talking about my 84 volt pack...my requirements could not be met with these convertors...so I went down the local dump and came back with about a dozen small mains power supplies form things like LCD monitors, video cameras, portable speakers, printers etc etc.
all ranging from 100 to 240 volt input and various outputs, from 5 volt to 18 volt. Well sticking 84 volt DC in to them, and they pretty much all worked.. Often taking a few moments longer to power up than if feeding them with 240v AC. SO now I have a variety of small SMPSu's all usable with 84 volt in.
So my problem solved, all with PSU's from the dump
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby ambroseliao » Thu May 05, 2011 3:28 pm
I'm wondering how clean (ripple) the DC voltages are from those small units? Do you have a oscilloscope by any chance? :?:
Ambrose
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby NeilP » Thu May 05, 2011 3:38 pm
Possibly. At least I can probably get access to one
I only plan to power small halogen or led light units off them, so should be ok for that. I recently picked up a box of 20 or more 12 v 20 and 35W mini spotlights.... Not sure what they are called, but they are the same type as my 6v 10w Catseye bike headlamp...so as long as I do not melt the housing , should be ok
Will see if I can get a scope across the outputs
Neil
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby hillzofvalp » Thu May 05, 2011 8:20 pm
send me a light ;)
hillzofvalp
Postby NeilP » Fri May 06, 2011 12:31 am
They are not complete units, just the bulb . Only have one of the housings
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby ecodean » Sun May 08, 2011 6:03 pm
Hi Lyen. Could 4 of these be wired in parallel to make a 12a supply?
ecodean
Postby NeilP » Mon May 09, 2011 1:42 am
Sorry Ambrose, still not chance of getting to a scope.
I have tried running my 7.2 volt lights off a 12 v unit and they work fine. I did not just stick 1 v straight up them...I mailed the manufacturer, andt ehy mailed me back saying the front end voltage control circuitry was OK to up to 12 v..Di Notte lighting..make great lights
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby thenate1 » Tue May 10, 2011 10:24 am
Anyway to get more AMPs flowing through these? I want to use one to power some heated grips and the manufactures emailed me back saying:
"12 volts DC will be fine to run the grips. They will draw about 3.5 amps or 44 watts per pair as they come up to the set temperature. After they have reached the set temperature (when the blue lights on each grip stop pulsating) the amp draw can vary between 0 and 3.5 amps, depending on conditions."
thenate1
Postby oldpiper » Tue May 10, 2011 10:56 am
thenate1 wrote:Anyway to get more AMPs flowing through these? I want to use one to power some heated grips and the manufactures emailed me back saying:
If you just want a standard 12V, why not get one of the many 48V-12V converters available on eBay or such? Lyen's converters are about the only ones I've seen which you could tweak for nonstandard voltages, but there are several to choose from for conversion to 24V, 12V, 5V, 3.3V, etc.
Cameron
Schwinn StingRay OCC XL, front AmpedBikes DD hubmotor, 37V, 10 Ah Lipo
"If it jams-force it. If it breaks, it needed replacing anyway."
"Just because you're paranoid doesn't mean they aren't out to get you."
oldpiper
Postby NeilP » Tue May 10, 2011 2:03 pm
Or just do what I did and find an old Mains PSU that runs 12volt. If it has an input showing 100-240V AC, chances are it will work...not if it is a big old fashoned heavy transformer type, it needs to be a switched mode type.
I found a load, in the range 3-6 amps...the sort used to power LCD PC monitors are good
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby Lyen » Thu May 12, 2011 2:41 am
Hi Ecodean,
Thanks for your interest in the DC to DC multi-purpose voltage converter. Yes, you may connect four converters in parallel as a 12A power supply.
Regards,
Lyen
ecodean wrote:Hi Lyen. Could 4 of these be wired in parallel to make a 12a supply?
Items For Sale
Lyen
Postby ChinaPhil » Thu May 12, 2011 3:09 am
I use an iPhone 4 for navigation and have been trying to power / charge it with one of these converters set at 5V and powering a USB charging cable - cannot get it to work, any suggestions?
Phil
Cyclone 500W, SRAM DualDrive, hardtail; 8s Lithium Iron Phosphate, 38A
Cellman 350W geared hubs, 2WD, hardtail; 12s Lithium Cobalt Oxide, 2 x 17A
Cellman 500W Mac rear geared hub (upgraded gears), full suspension; 12s Lithium Cobalt Oxide, 59A
ChinaPhil
PreviousNext
Users browsing this forum: kayakdave23 and 5 guests
