Xyster i see a voltage boost, but everything is still going through the controller, i dont see any bypass.
fechter wrote: Another nice feature is if the power for the relay coil comes from across the motor wires so you can't accidently go turbo when you're stopped.
xyster wrote: True, but you'd also lose the benefit of being able to use the bypass to get home if the controller died.
Ouch! my brain hurts trying to follow that.
xyster wrote:Ouch! my brain hurts trying to follow that.
Compared to like your current-control throttle, I'd think this circuit would be a piece of cake for you!
Would using FETs in lieu of relays avoid these problems?
Would FET switches be more synchronous?
Are FET switches less likely to fail to switch?
It makes my brain hurt too, LOL, we are spoiled by circuit design software where everything looks perfect
This may be a silly question, but when you say 24 volt coils, you aren't taking about coils that max at 24 volts? Otherwise, some of those will have in series are way over 24 volts.
36 to 72 is lots easier.
Users browsing this forum: No registered users and 14 guests
