18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Lyen
Post by Lyen » May 21, 2010 6:44 pm
If you have any hope of driving the latest motors in their full glory (by which I mean max'ed out potential) and at high native speed, I can’t overstate how important it is to have a powerful controller in your electric bike. For my purpose here, I would choose the 18 FET controller from using the latest IRFB4115 MOSFET.
Introducing the newly brewed 18 FET 84-132V Infineon Programmable Brushless Controllers with high voltage IRFB4115 MOSFETs (EC184115-LYEN EDITION)
This is for a new, never used high voltage controller for racing in mind. It is originally designed people who have the gut for going above 50mph or 80kph.
There are other reasons for utilize the controller below:
1. You want to give higher speed to your beefy and robust high torque low speed motors such as the Crystalyte 5306, 5305, 5304, 4011, 409, 408, BMC V2 Torque version, Nine Continent - 9C 2807, Golden Motor HBS36 series, etc.
2. You have hub motors 20” or smaller high torque wheels and need to find a way to boost significant speed
3. You have a hall sensors added RC motor (Turnigy & Astro in this case) but want to take the advantage of higher RPM or to improve the gear ratios for more torque and/or speed
4. You hate getting horned by cars behind you telling you to get out of their way
5. You think high voltage is cool
6. You want to horn cars in front of you telling them they are too slow
7. You want a high voltage high speed controller in a small enclosure/chassis
8. You want to win the Spooky Tooth Death Race and compete against gas engine cycles after all
9. You want to combine your two 48v battery packs in series together for the high speed experience at 96v
10. You want to combine your three 36v battery packs in series together for the even higher speed experience at 108v
Another unique feature of this controller is that it has an additional speed sensor circuitry built-in with an extra output lead/pin. It is to be used with the scooter style electric bike and electric scooters that have a speedometer in the dashboard that reads electrical pulses.
This version also uses lock washers to secure the MOSFET transistors internally and the heat transfer bar outside to place tension against a nut after tightening. It is also to help prevent the nut from loosening. The MOSFET transistors will get overheated and damaged when detached from the heat-sink which used to be the case from the previous designs.
By purchasing the controller, you understand the following:
1. Your electric bike may classify as a motorcycle class vehicle in most states
2. Riding at high speed may not be legal on public road without proper driver’s license and auto insurance.
3. Risk of high voltage shock with improper high voltage batteries handling
4. Safety wears is advised and may required in most states by law
5. Typical bicycle cantilever, rim, and even disc brakes may not have sufficient stopping power
6. Typical bicycle frames are not designed for high speed application
7. Motorcycle class/training course(s) is highly recommended to ride safely at high speed
Note: Do not use a regular Cycle Analyst due to high voltage will destroy the internal circuitry. You should use the controller with the CA-LS model only.
This is a top of the line controller that comes with all the bells and whistles that are typical needed for the racing application including the CA connector, regen enable/disable jumper, USB-TTL plug, USB-TTL programming adapter with a push to send button and connector. Windows XP/Vista/7 32/64 bit operating system (real 32/64bit drivers). A special LVC calculation formula will be provided via PM or email upon purchase.
Below is the specification:
Model: EC-184115-LYEN EDITION
Start immediate controller
Chipset: XCKJ8B116A (same chipset being used as in the 18 FET controller)
Circuit board version: Confidential
18 x genuine IRFB 4115 MOSFET N-CH 150V (tested up to 150V before damage) for more information about the FET, click the link below:
http://search.digikey.com/scripts/DkSea ... 4115PBF-ND)
120V battery optimized (for higher or lower voltage & current such as 84V-132V, you may need to program the low voltage cutoff. Be aware the absolute battery topped off or fully charged voltage cannot exceed 150v)
45A is the current rate (for higher current, you may need to beef up the trace, shunt, and reprogram it via the software)
Low voltage cut-off at default: 95v
Battery and motor phase wires gauge size: 12AWG (High voltage capable wires equipped) Silicon wires installed!
Dimension: 9" x 3.4" x 1.75"( 229mm x 87mm x 45mm) plus mount extensions
Total weight: 805 gram
I have only 35 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it as soon as your piggy bank is filled up. :lol:
$259 USD free ground shipping in the United States & Canada. For other locations, please PM or email me at LYEN@HOTMAIL.COM. I accept PayPal, cash or money order. The controllers will be shipped out from me in San Francisco, California, USA. I will provide a tracking number and ship it out as soon as I have received the fund.
You may click on the PayPal Buy It Now link below. For accessories, please send money via PayPal or send me a private message for the total price. Thanks!
https://www.paypal.com/cgi-bin/webscr?c ... VY2LDRPLMQ
If you are not satisfy with the results or if it is too fast for you, you may send it back to me within 30 days in an unmodified condition.
Updates as March 21st, 2015
Quantity updated as of 12/28/2013 : 34 left (buyer bought 1 from Cambridge, MA, United States )
Quantity updated as of 1/8/2014 : 33 left (buyer bought 1 from Kyabram, Victoria, Australia )
Quantity updated as of 1/8/2014 : 32 left (buyer bought 1 from Morpeth, Northumberland, United Kingdom )
Quantity updated as of 1/30/2014 : 30 left (buyer bought 2 from Kyabram, VIC, Australia )
Quantity updated as of 2/4/2014 : 29 left (buyer bought 1 from Vilamoura, Quarteira, Portugal )
Quantity updated as of 2/9/2014 : 28 left (buyer bought 1 from Tittmoning, Germany )
Quantity updated as of 3/1/2014 : 27 left (buyer bought 1 from Kyabram, Victoria, Australia)
Quantity updated as of 3/13/2014 : 26 left (buyer bought 1 from Norman Park, Queensland, Australia )
Quantity updated as of 3/15/2014 : 25 left (buyer bought 1 from Landsdale, Western Australia, Australia )
Quantity updated as of 4/4/2014 : 24 left (buyer bought 1 from Gordonsville, VA, United States)
Quantity updated as of 4/5/2014 : 23 left (buyer bought 1 from Norfolk, VA, United States )
Quantity updated as of 4/12/2014 : 22 left (buyer bought 1 from Saint-paul, Quebec, Canada )
Quantity updated as of 4/19/2014 : 21 left (buyer bought 1 from Carthage, NY, United States )
Quantity updated as of 4/25/2014 : 19 left (buyer bought 2 from Brooklyn, NY, United States)
Quantity updated as of 5/7/2014 : 18 left (buyer bought 1 from Vancouver, CT, United States )
Quantity updated as of 5/9/2014 : 17 left (buyer bought 1 from West Des Moines, IA, United States )
Quantity updated as of 8/19/2014 : 16 left (buyer bought 1 from MONROVIA, CA, United States )
Quantity updated as of 8/30/2014 : 15 left (buyer bought 1 from Greenwich, CT, United States )
Quantity updated as of 9/16/2014 : 14 left (buyer bought 1 from Swanton, OH, United States )
Quantity updated as of 10/11/2014 : 13 left (buyer bought 1 from Unna, Germany )
Quantity updated as of 11/9/2014 : 12 left (buyer bought 1 from Unna , Germany )
Quantity updated as of 11/16/2014 : 11 left (buyer bought 1 from Fort Washington, PA, United States )
Quantity updated as of 11/25/2014 : 10 left (buyer bought 1 from maastricht, Netherlands )
Quantity updated as of 11/22/2014 : 9 left (buyer bought 1 from Berlin, Germany )
Quantity updated as of 12/8/2014 : 8 left (buyer bought 1 from roma, Italy )
Quantity updated as of 12/13/2014 : 7 left (buyer bought 1 from Greenwood, IN, United States )
Quantity updated as of 12/19/2014 : 6 left (buyer bought 1 from Cap-Santé, Quebec, Canada )
Quantity updated as of 12/23/2014 : 5 left (buyer bought 1 from Temple City, CA, United States )
Additional accessories (prices are reflected with controller purchase only. Please contact if you are interested to buy without controller):
$15 throttle (full/half/thumb) with mated left rubber grip (very good quality) (ebikekit retails @ $36)
$19 cruise control (manually installation required)
$15 three way speed switch (manually installation required)
$15 PAS - Pedal Assist System add-on (manually installation required)
$15 electric brake levers a pair
$29 motor/controller hall/phase/throttle tester
Items For Sale
Please sign up here and donate your marrow to save life.
John in CR
Re: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $
Post by John in CR » May 23, 2010 12:41 am
Ugh oh, my secret weapon is in the public domain now. Time for me to get out on the highway for a speed run. I've been working on the aero before even installing this baby. I figure aero is going to be pretty important at 80+mph. :twisted:
John
Hyena
Post by Hyena » May 23, 2010 8:29 pm
Your a bad man Lyen :twisted:
Thats a good price considering there's little other options available. I'm very tempted but I think it'd cost me alot more than $259 in the divorce settlement :lol:
www.HyenaElectricBikes.com
AmpEater
Post by AmpEater » Jun 18, 2010 10:25 pm
Is that last one still available?
I'll take it
Lyen
Post by Lyen » Jun 18, 2010 10:35 pm
AmpEater wrote:Is that last one still available?
I'll take it
Hi AmpEater!
Thanks for your interest in the controller. Yes, it is still available for purchase. :)
Regards,
Edward Lyen
Items For Sale
AmpEater
Post by AmpEater » Jun 18, 2010 10:47 pm
Payment sent....x2
Lyen
Post by Lyen » Jun 18, 2010 11:40 pm
AmpEater wrote:Payment sent....x2
Hi AmpEater,
Thank you very much for your purchases. I will start fulfill your order and get back to you with the tracking information. :)
Best Regards,
Edward Lyen
Items For Sale
Lyen
Post by Lyen » Jul 28, 2010 6:03 am
Dear all respective members and buyers,
I have recently noticed there is a couple of competitors who are bad mouthing the high voltage controllers I sell will fail. They are making false statement to lurk potential buyers toward them. I am usually peaceful and quiet until now due to unfair statement made by competitors. I will try not to mention their names to avoid starting fires here.
I have requested for proof of evidence on June 21st, 2010 and received no proof of evidence for the cause of failure as of today.
Update as of August 4th, 2010, the bad wording from that seller has been removed with the help of the forum moderators including Ypedal and other respective forum members. I really appreciate your help. :)
Your Truly,
Edward Lyen
Items For Sale
The Mighty Volt
Post by The Mighty Volt » Jul 28, 2010 4:45 pm
Anyways.....I bought this......I hope to mate it to a 120v A123 Battery.....we will soon find out what it is capable of! :shock: :shock: :D
MadRhino
10 GW
10 GW
Post by MadRhino » Nov 29, 2010 1:40 pm
Many thanks Lyen,
I just received my new controller, well packed and mint. It is incredibly small, for the juice it can feed. I can't wait to install it on my ride and experience the new power. If you don't hear from me anymore, I'll be stucked in the branches of a tree with my bike, somewhere in the mountain. :mrgreen:
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
sharadona
100 µW
100 µW
Post by sharadona » Jun 01, 2011 4:14 pm
Hello Lyen,
is it possible to build up this powerfull controller (same specifications) as an sensorless controller? I'm planing a project with the new Crystalyte Phoenix II sensorless hubmotor (sensorless, halfweight 5000er series of the original Crystalite Phoenix hubmotor). For this motor is a sensorless controller required like crystalytes own sensorless controllers. But their contollers have max 72V 40A=2880W. I'm planing a high speed project. And your assembled controllers are, so far i know, the best on the market for high speed ebike applications. In this forum you selling also a sensorless controller with less power. So i hope you can provide a sensorless controller with this high power specifications. One more question.
What is the minimal capacity the batterypack should have to work with this controller + crystalyte Phoenix II ? Hope for a positive quick answer. Thanks.
Best regards.
Silvio (sharadona)
Lyen
Post by Lyen » Jun 02, 2011 2:00 pm
Hi Silvio,
Thanks for your interest in the controller. A PM is being sent with answers to your questions.
Best Regards,
Edward Lyen
sharadona wrote:Hello Lyen,
Best regards.
Silvio (sharadona)
Items For Sale
itchynackers
Post by itchynackers » Aug 19, 2011 6:03 pm
I'd like to revive this thread. Anyone been running this controller near its limits? I'd like to know how hard to push mine without overdoing it. Right now I'm only at 103V hot, 65a peak (160 phase).
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
Floont
Post by Floont » Aug 19, 2011 6:18 pm
itchynackers wrote:I'd like to revive this thread. Anyone been running this controller near its limits? I'd like to know how hard to push mine without overdoing it. Right now I'm only at 103V hot, 65a peak (160 phase).
I ran the Lyen 24FET version which has the same 4115 MOSFETs in it at 148 volts one day with no obvious problems. Right now, I use it at 132v consistently.
Build 2: (present build): Rear x5304 on full suspension Mongoose, 127v 30s3p 10aH Turnigy Lipo, Lyen 24FET 100amp controller, CA2.2, 26" Hookworm front, 26" Crazy Bob rear, 203mm disc brakes, Airzound horn, twin Blaze 2 watt front lights - BURNED
All my posts on this site are licensed under the Creative Commons Attribution-Noncommercial-No Derivative Works 3.0 License
Lyen
Post by Lyen » Aug 19, 2011 11:09 pm
PM Sent :)
Items For Sale
cassschr1
Post by cassschr1 » Aug 20, 2011 12:17 pm
lyen,public answers would be helpful,then we would not need to inconvience you
itchynackers
Post by itchynackers » Aug 20, 2011 12:25 pm
He just reminded me that mine was optimized for 103V regen operation (as I asked him to do). If I wanted to up the voltage, I'd need to adjust a resistor.
Lyen
Post by Lyen » Aug 20, 2011 9:58 pm
Hi Cass,
You have multiple controllers purchased in several time frame with different revisions. It would be best for me to answer via PM to avoid confusions.
Regards,
Lyen
cassschr1 wrote:lyen,public answers would be helpful,then we would not need to inconvience you
Items For Sale
cassschr1
Post by cassschr1 » Aug 20, 2011 11:08 pm
pm sent
zombiess
1 GW
1 GW
Post by zombiess » Nov 27, 2011 4:20 am
Just going to bump this with an awesome review. Got this from Lyen 1 day before the Grange race and unfortunately it came with a dud FET and didn't even make it one mile. Since Lyen and I decided to room together for the race he said he could fix it for me the night of the race if I brought it + some 4115 FETs with me. Just so happens I had four brand spanking new IRFB4115's sitting around the parts bin (don't all of us extreme ebike geeks?). We stayed up to 2AM but he swapped out the bad phase that had just one single bad FET that wasn't even visible with 3 new ones I got since we didn't trust that bank even though 2 tested out OK (now spares). Did a few late night parking lot test runs and all was good as new.
Lyen provided me with service that I myself try to provide, above and beyond what is required.
I've since gone to the extreme and modded this controller (post is in the tech section) some more and it now draws a continuous 60A from the battery without even getting warm, highest logged FET temp was a whopping 57C after a bunch of 0-40mph, hit regen abuse. Stock I don't feel it should be run over 45-50A (on the cycle analyst with a calibrated shunt) and definitely keep it to 30-32S lipo 126-134 V max so you have some head room left.
The freeway speed comment in his title is no joke either. My 9C 2806 in a 20" wheel pushes me to 56mph quite quickly and this is a low inductance low resistance motor. I would not try this same stunt on this motor in a bigger wheel though.
Tommy L
Post by Tommy L » May 21, 2012 8:37 pm
Edward Lyen,
Invoice Received and Invoice Paid!
I appreciated the fact that you have answered all my questions/emails.
Amazing customer service!
Thank you and Best Regards....
Tommy L sends....
I will make a Video Review once I receive products :) \\m//
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
https://endless-sphere.com/forums/viewto ... =4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
Stielz
Post by Stielz » May 29, 2012 9:15 pm
Very impressive controller!
Anyone have figures of actual power output (at the wheel) achieved with this controller?
pendragon8000
Post by pendragon8000 » Jan 20, 2013 12:10 am
Hi Lyen,
just droped this post
https://endless-sphere.com/forums/viewto ... 45#p690106
but i think the 4115 fets will be more relieable for 100v and then i have option for 125v(30s lipo)
are these still availiable? and do you think it would suit a ht3525 hub in 26" mtb
thanks
Pendragon8000
8)HYENA high power ebike kits
My builds
scott 29er + Hyena kit, mon-goose to MON-STER 6KW, Free Agent RC Mid Drive, videos
my bike goes so fast 'cos it charges the battery while I pedal
pendragon8000
Post by pendragon8000 » Feb 01, 2013 11:27 pm
Thanks for sending promptly after payment and testing with youtube video.
I'm really keen to try this out. should be a great build (eventually).
I'll most likely beef up tracks and pump 60amps.
My builds
alsmith
Post by alsmith » Apr 30, 2013 1:52 pm
Does anyone have the shunt resistance value- it's for the cycle analyst RShunt setting. It doesn't seem to be the same as the 18 x 4110 FET controller.
