Re: Your Creation's Before & After Pics
Postby Bluefang » Fri Mar 11, 2011 6:26 pm
Before
After
(166.91 KiB) Downloaded 3 times
(198.34 KiB) Downloaded 3 times
viewtopic.php?f=10&t=49912 Current build, Electric flat tracker
Bluefang
Postby Kingfish » Sat Mar 12, 2011 1:24 pm
Bluefang, that looks really impressive with nice retro styling. Can you give us a bit more detail about that front fork please? From one of your earlier threads I gathered that it came from a light motorcycle. What is the diameter of the mating neck tube?
Well done, KF :)
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9634 miles-to-date, 4144 as 2WD.
Kingfish
1.21 GW
1.21 GW
Postby electricridefl » Sat Mar 12, 2011 8:28 pm
Hear is my 96volt machine. I've been riding the bike for 5 years now. Its always exciting though, when one gets a new battery. I pedal along at 35mph. 409 motor. battery contain 12 rc 7.2v nimh packs. good for 5-6 miles. marathon xr rear tire, hydraulic front brake, 48-11 gearing. And fenders, and basket, and mirror, and even lights. attachment=0]DSCF0007.JPG[/attachment]
96volts, 35+mph
electricridefl
Postby Bluefang » Sun Mar 13, 2011 9:36 pm
Hey Kingfish, its a standard triple T fork from a chinese pitbike, the neck tube was same as the bikes been i think 1", i was able to reuse the bearings that came with the forks. I had to shorten the neck on the bike by like 10mm from 140mm to 130 to get it to fit ok. Its pretty heavy tho, i would say the forks alone are about 6kg or more with the wheel i used been over 10kg :( With brakes thats like 20kg just in the front end with the rest of the bike including motor weighing less then that :twisted:
If i do it again for the look i think i ll just modify a push bike hub to fit rather then use motorbike stuff, its a 21" motorbike wheel. Its actually on ebay atm so i ll find out soon if people like the look of it, 7days left on the auction with 8 watchers and a large number of emails already :mrgreen: You can get a fork setup for like $80 and the brakes would be under $100 for a twin piston 240mm disc too. So alot cheaper then normal bike stuff and a million times stronger, but alot heavier.
Something like http://www.pccmotor.com/inverted-forks- ... 05050.html would be great, just relace the hub with a bicycle rim and your good to go.
Bluefang
Postby adrian_sm » Sun Mar 13, 2011 10:01 pm
Before:
x408, 48V10Ah LiFePo4, <1000W, ~30kg
After:
Commuter Booster Friction Drive, 5s20Ah LiPo, ~2000W, ~18kg.
Oops, this photo doesn't have the phase extension wires connecting the drive to ESC. :roll:
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby adrian_sm » Sun Mar 13, 2011 11:50 pm
Before:
Avanti Giro Road Bike: 9.4 kg
After:
Commuter Booster Friction Drive (5065 motor), 5s20Ah LiPo
~1000w, 13.5kg 8)
adrian_sm
Postby motornews » Wed Mar 16, 2011 7:14 pm
after 2 months of trying to replace my 1st broken throttle,instaled a compo controller-throttle from gm and im happy.
-48v sla -49klm/h-and 20 klm range no pedaling its nice for my first try
(129.03 KiB) Downloaded 3 times
motornews
Postby gtadmin » Fri Mar 18, 2011 4:22 am
Hi, you wouldn't have a link to the full sized picture your avatar is based on, do you?
Cheers,
GT
gtadmin
Postby Olivettibakebean » Sun Apr 03, 2011 5:04 am
Now I have it running I thought I would add my project.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=25932 My Build Page!
Olivettibakebean
Postby xmasta » Mon Apr 04, 2011 2:49 am
Hello sphere guyze!
Here's mine, before and after.
Contains: Ping custom-size battery 48v10ah, e-bikekit.com rear dd hubmotor, turnigy wattmeter.
before:
after:
( it is winter to spring atm here, so it is liek very shty everywhere and it really likes to hop on my bike, hard to keep clean atm )
cat smells something funny too.
here's 32 hours of making in 10minute video:
http://www.youtube.com/watch?v=DVFHgrAI2ug
here's one minute overview (in estonian):
http://www.youtube.com/watch?v=fF3o-qYEB2A
and here's the build thread in an estonian forum, use google translate for sht and giggles :P
http://www.zev.ee/foorum/viewtopic.php?f=11&t=177
it doesnt look too pretty i know, my first fiberglass work, will do better next time :)
peace!
xmasta
Postby snellemin » Mon Apr 04, 2011 9:35 am
First Ebike conversion. Had to do it cheaply and see if I like first. Runs on 14s Lipo and a cheapy Ebay conversion kit.
49.6mph EVG SX w/24S2P, 12fet Lyen sensorless ESC, Magic Pie II
32mph Fuji MTB w/14s1p 6fet Lyen sensorless ESC, GNG+LR kit, Zombie throttle interface
snellemin
Postby Ecumbent » Wed Apr 13, 2011 8:28 pm
It ain't slick or fast but ...
(78.28 KiB) Downloaded 3 times
Ecumbent
100 µW
100 µW
Postby unklegrumpknee » Tue Apr 19, 2011 12:34 pm
I don't really have before pictures. But here is what I put together and it's cost.
GT Palomar Purchased from the son of a friend. $100.00
Tune up of bike at LBS $100.00
Wilderness energy front hub motor , tire and rear rack $140.00
Crystalyte pedal first controller & Anderson connectors $120.00
& throttle (thumb)
48 volt 7.5 Amp-hr batteries Salvaged ( 2 sets) 0.00
new stop leak filled tube $10.00
Seat $20.00
Moose Zipperless Tank Saddlebags X2 (made for ATV's) $40.00
Charger 24v $20.00
Set of spokes $20.00
Spare GT bike non electrified $45.00
Mirror $10.00
Basket 0.00
Grand total Less some tool purchase $625.00
Comments : Used the battery bag that sat on top of rear rack at first. Found the Moose bags at an ATV shop. They have a Neoprene Harness which acts as a suspension. They lower the center of gravity as well and make the bike much more stable and comfortable to ride. So far around 100 miles or so. Everybody I let ride it comes back with a grin.
Thank you to all the members of this forum . I couldn't have done it without you.
I am proud of the fact that very little new material went into the cobbling together of this project. The motor was part of a kit that was cannabilized at the LBS. The bikes, controller, charger and batteries are used.
Gt Palomar, WE 600 watt DCBL front hub, Xlyte 20 amp Pedal first controller, Moose saddle bags.
unklegrumpknee
Postby Golden Motor Canada » Fri Apr 22, 2011 8:53 am
My CCM Build
Went to Canadian tire one day for a seat and ended up picking up a new CCM downhill Bike at half price. Added two Magic Pies and the battery is in the trailor. Some of the pictures still show the battery on the back before I moved it to the trailor. I added a second throttle to the right upright bar so I can operate it from either position. I also added a third brake lever to the left upright that operates regen plus the the rear disk brake. The two regular brake levers operate the front disk and the rear center pull brake. So yes, I have 3 brake levers and two throttles. :D
Gary
Sorry no before pictures but here is a link to the bike on the Canadian tire website so you can see what I started with
http://www.canadiantire.ca/browse/produ ... 1967914931
Here are the results!
Victoria Day Sale on now! Click here to Save 100 on Any kit and Any battery combined
Gary Salo
Golden Motor Canada
The world is going green with Golden Motor Canada
Have a look at My Ebikes Here
Have a warranty issue with GM Canada? Click Here
Golden Motor Canada
Postby Lemlux » Mon Apr 25, 2011 11:55 am
Hi, GMC
Thanks for displaying your intriguing 2-piece torque arms with your pics.
I can find the torque arm sets on your site, but I can't find the adapter piece that mounts the BOB NUTX about 2" aft of the axle out of the way. Do you sell pairs of these adapters also or are they custom? These adapters would allow a standard BOB bike connector fork to work with a 29er. They would also allow for a further aft pivot point which, I understand would make for a less squirrelly pusher trailer setup.
Lemlux
Postby Golden Motor Canada » Sun May 01, 2011 3:26 pm
Hello Lemlux,
Sorry for the delay getting back to you. I wanted to wait until i had the time to take off one of my arms to show you what it looks like under the nut :)
Anyway, they are custom made. I made them from stainless steel. Originally I was going to make an oval hole that fit perfectly over the oval shapped GM axle. But this was to difficult so I just made a round axle hole. At first they used to slide down with the weight of the trailor. Then I the cut an angled notch in the bottom and the the GM lock nut fits in to hold it in place. Nothing moves now and they are strong and secure.
Gary
Gary Salo
Golden Motor Canada
Golden Motor Canada
Postby Lemlux » Tue May 03, 2011 2:35 pm
Nice touch with the notch and the GM nut.
Lemlux
Postby Jethro56 » Sat May 07, 2011 10:20 pm
Well version 1.0 is finally done
Lycra Roadie who smiles when you drop him
Jethro56
Postby mst3kpimp » Mon May 09, 2011 10:44 pm
Heres what I did to a Schwinn Landmark.. You can see my writeup and more photos here.http://endless-sphere.com/forums/viewtopic.php?f=6&t=27847#p402313
mst3kpimp
Postby Lessss » Thu May 12, 2011 8:11 am
Autobike conversion, geared 500W
Battery temporarily mounted on the handlebars.
I think I should paint the hub black.
Give me nuclear batteries I say!! Ripped off by Joshua Goldberg to the tune of almost $900 re headway groupbuy for batteries, no $ no batteries
http://www.openoffice.org/ or https://www.libreoffice.org/
http://www.ubuntu.com/
Lessss
Postby friedwires » Mon May 16, 2011 8:46 pm
i just put this one together over the weekend. its an amped dd rear sla kit on a new giant suede comfort cruiser. its a little slow for my taste at a top speed of 23mph,but still its a nice ride.
friedwires
Postby Timma2500 » Mon Jun 06, 2011 10:18 am
1.8kw Specialized Rockhopper Pro FSR.JPG (155.18 KiB) Viewed 341 times
Paul :D
Intense M3 DH, HT3525 / 5kw, 18fet, 20s 10ah nano lipo
Norco Empire 5, 80100 130kv / 5kw, HV160, 12s 12ah lipo
Under Construction
Timma2500
Postby StudEbiker » Mon Jun 06, 2011 3:29 pm
Your build is one of my all time favorites Paul! Would love to be able to do what you did to that bike. Must be a great ride!
TidalForce S-750-(build #2) w/9C rear w/EV Components Headway 36v 10ah LiFePo4 pack: http://endless-sphere.com/forums/viewtopic.php?f=6&t=15443&hilit=+headway+rack+pack
Bike-E (Build #3, mostly done)- 400W Kollmorgen mid-drive: http://endless-sphere.com/forums/viewtopic.php?f=28&t=25980#p375646
My Bike E Facebook group: http://www.facebook.com/groups/165756106813440/
"Facts do not cease to exist because they are ignored" - Aldous Huxley
StudEbiker
Postby Red_Liner740 » Tue Jun 07, 2011 3:03 pm
God damn, that bike is sexy!!! such a clean design!!
Red_Liner740
Postby corkscrew » Tue Jun 07, 2011 5:50 pm
Before!
Annnnnd After!
Actionbent T1 Tadpole Trike - 2806 9C Motor in a 700C wheel. 30AH 48v LIPO powered!
--Build thread: viewtopic.php?f=3&t=26520
corkscrew
PreviousNext
Users browsing this forum: loco13, Peter Sternersson, slayer and 13 guests
