Keywin E-bike Lab Parameter Designer Software Manual-ver 1.2
Re: Keywin E-bike Lab Parameter Designer Software Manual-ver
Postby Arlo1 » Sun Jul 03, 2011 2:18 pm
IM running or should I say blowing up 24 fet controllers and the xpd doesn't currently support them!
And Dave who has some good deals on STUF
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby gensem » Sun Jul 03, 2011 2:58 pm
Arlo1 wrote:IM running or should I say blowing up 24 fet controllers and the xpd doesn't currently support them!
It already has the 24 and 32 fet ones... just the 36 is missing.
Have a look.
https://developer.berlios.de/project/showfiles.php?group_id=12389
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
gensem
Postby Arlo1 » Mon Jul 04, 2011 8:55 am
WHat is that my comeputer wont let me see it!
Arlo1
Postby gensem » Mon Jul 04, 2011 11:50 am
Its because of the invalid certificate;
direct download url below
http://prdownload.berlios.de/xpd/xpd-0.2.0-windows.zip
gensem
Postby Bubba » Thu Aug 04, 2011 3:49 pm
I've got a question. I've searched for hours looking for a straight answer with no luck....
Which Switch setting do you use on the Lyen 12FET controller when using a Hall Effect throttle? I see Button and Switch options only.
Also, do the three speed settings have any effect?
Thanks in advance!
Bubba
Postby Arlo1 » Fri Aug 05, 2011 1:00 am
Bubba wrote:I've got a question. I've searched for hours looking for a straight answer with no luck....
Thanks in advance!
Haha the switch setting is to choose wether your three speed switch is a switch or a button. And yes the speed settings work eg. 50% is 50% of everything power and top speed!
Arlo1
Postby Bubba » Sat Aug 06, 2011 7:29 pm
Thanks in advance!
But I'm not using either a switch nor a button. I'm using a hall effect throttle.
Bubba
Postby Arlo1 » Sat Aug 06, 2011 9:02 pm
Bubba wrote:[
What I meant is if you use a three speed switch that's what button mode or switch mode is for. Hall effect and Pot type throttles both vary a voltage some ware in between 0-5 v which is what controllers need.
Arlo1
Postby Bubba » Sun Aug 07, 2011 4:24 pm
Ahhh! That's kinda what I thought, but just wanted clarification. Thanks!
Bubba
Postby Arlo1 » Wed Aug 10, 2011 7:40 pm
kevo wrote:Three speed switch is nice!
yup i got "cop mode", "friends test ride mode" and "oh shit mode"
Arlo1
Postby veloman » Fri Sep 16, 2011 5:38 pm
This thread has been very helpful, I wish I found it sooner.
Does anyone know why speed setting 120% doesn't increase top speed on my litte mxus geared motor? It's not a power limit, as at 17mph I'm nowhere near the amps it can pull on a hill or accelerating.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3540, 63v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby DAND214 » Wed Dec 28, 2011 12:08 am
I don't know if this is a new program or old.
I ask Keywin for the software for the EB3xx controllers I received from him. So he sent this
xpd-0.2.2-windows.zip
(79.63 KiB) Downloaded 165 times
I am still assembling the boards, so I haven't tried this yet.
I'm sure I will be asking questions soon.
Dan
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
Postby Kiwi » Tue Feb 14, 2012 5:25 pm
there does not appear to be any EB3xx board option in there.
Kiwi
Postby mxer » Mon Feb 27, 2012 4:02 am
I have tried to download the Perameter designer setup ALL zip "Mike" installer zip package and i cannot unzip it?, it just say's "Unexspected end of archive" or corrupt ? Anyone else experience this ?
Or is my XPD software conflicting ?
mxer
Postby DAND214 » Mon Feb 27, 2012 11:13 am
I can't get it to load either.
I can't get the simulator on Ebikes.ca to run.
Running XP pro.
Gone thru all the posts I could and really it doesn't help.
Dan
DAND214
Postby johnrobholmes » Wed Mar 07, 2012 2:48 pm
Looks like the zip file is corrupt.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
10 GW
10 GW
Postby gensem » Wed Mar 07, 2012 3:11 pm
XPD site is still up...
http://xpd.berlios.de/
Hope this helps.
gensem
Postby toolman2 » Mon Apr 02, 2012 9:42 pm
that setup all file is corrupt? can someone post up a good copy, or is there another way of to do this?
being able to program an ecrazyman controller has been out of reach for me for years now, are we sure it can actually really be done with ant of these files?
i now even have the usb converter made for the new 24 fet, but the software?
toolman2
Postby toolman2 » Mon Apr 02, 2012 11:40 pm
i got things to kinda work, now getting invalid reply byte 'fe'
or invalid reply byte 38
any ideas?
toolman2
Postby Degull » Fri Apr 13, 2012 10:48 am
Hi everyone. I would like to play with the parameters on my motor controller. I have one of Cellman's EB312-AS-2 controllers and I would like to read and save the settings profile that is currently on the controller before I attempt to tweak them. Is there any way to read the profile that is installed on the controller now before I screw everything up? If I mess everything up I can always go back and install the original parameters. Not sure how I can go about reading the info off the controller. Thanks.
Degull
Postby amberwolf » Fri Apr 13, 2012 1:32 pm
No way to read from controllers that I am aware of. You're stuck with "blindly" overwriting whatever is there with your new settings.
You might ask Cell_man if he knows what those defaults are, or see if anyone has published them here on ES.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby Degull » Fri Apr 13, 2012 10:02 pm
Cellman kindly provided the values via email. Thanks for the suggestion. Let see if can make some smoke.
Degull
Postby Mowolar » Tue Jun 05, 2012 9:30 am
Hi Guys,
I have a new e-bike with attached (picture) controller.
Is the e-bike software and cable compatible with my controller?
Thanks, Lars
(76.24 KiB) Downloaded 5 times
Mowolar
Postby ambroseliao » Tue Jun 05, 2012 10:47 am
Hi Lars,
It's hard to tell from the label. Can you open the case up and take a photo of the motherboard?
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby Mowolar » Tue Jun 05, 2012 1:37 pm
Hi ambroseliao,
I didn't know where to focus on, but see attachment for 2 pictures of the mainboard.
Thanks for your help and look forward hearing if it's possible!
(100.71 KiB) Downloaded 5 times
(75.1 KiB) Downloaded 5 times
Mowolar
PreviousNext
Return to E-Bike Technical
Users browsing this forum: fizzit, Rassy and 10 guests
