Yamaha YSR 50 conversion.
Collossus runs bitches
Postby Arlo1 » Mon Jul 25, 2011 4:53 pm
And Dave who has some good deals on STUFF Incl. Mosfets, Current sensors and Nomex paper.
Arlo1
Re: Yamaha YSR 50 conversion.
Postby Thud » Mon Jul 25, 2011 6:53 pm
congrats!
I allways forget how small the ysr50 is LOL. but awsome fun on a kart track I bet!
i'll be looking for the next steps you take waking that collosus beast up & making it hammer.
the CF parts are going to be sic also....great build.
get some......
Thud
Postby Arlo1 » Mon Jul 25, 2011 6:55 pm
I just took two turns off the inductors and laid down 3.6 hp thats 1hp jump lol.
Arlo1
Postby Arlo1 » Wed Jul 27, 2011 12:59 am
Almost double the HP in 24 hours! At this rate I will be at 27 HP by the week end :mrgreen:
Arlo1
Postby Arlo1 » Thu Jul 28, 2011 1:31 am
:mrgreen:
Arlo1
Postby Jay64 » Tue Aug 02, 2011 4:03 pm
Arlo, the first 2/3 of that video was like a kid with ADD. Can't decide where to pay attention to. :lol: :lol: Like the progress you've got man.
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby jonescg » Tue Aug 02, 2011 8:29 pm
Jay! Where have you been??
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby Arlo1 » Mon May 06, 2013 9:35 am
Ok so I decided to learn how to build a controller from scratch for this bike lol.
This thread is long overdue for an update. I will be pushing hard to get this bike insured and on the road very soon.
Here is where IM at. Best run 13.4hp at the wheel (DYNO reads low a 2010 YZ450F made 33 with a fresh motor and hi comp piston on my dyno)
There has been more then a few videos like this.
But soon I hope to make more videos like this :)
Arlo1
Postby etard » Sun May 19, 2013 9:15 am
Sturdy work man! Riding impressions?
etard
Postby Arlo1 » Sun May 19, 2013 9:54 am
etard wrote:Sturdy work man! Riding impressions?
Thanks. Although I'm just sitting on a frame lol. Its AWESOME! You can feel how great the little bike handles and partially because there is very little spinning weight to cause a gyroscopic effect so you can lean into and back and fourth very quickly. Its hard to explain but you have to ride it to understand.
The power is AWESOME and I make it better every time I work on it. Its not crazy power wheelie but its PULLS HARD. You can realy feel the power build as speed increases. Its a little (just a little) like a 2 stroke. But that will change as I play with phase amps and phase amplitude. IM working on 3 more levels of controllers at the same time! I should have something to melt this motor into goo soon enough ;)
Arlo1
Postby Arlo1 » Wed May 22, 2013 12:34 am
Got the variable regen working. IM just working the bugs out of the current sensing circuit for the dyno so I can measure efficiency while I make changes to find more power with different settings like PWM frequency before actually upping the power
Arlo1
Postby Arlo1 » Tue May 28, 2013 12:01 am
Arlo1
Postby John in CR » Tue May 28, 2013 12:46 am
Great to see a solid power run with nothing letting the smoke out of itself. It looks like the Colossus needs a blower, but that's easy. The part I don't understand is the noise. I thought sine wave controllers were supposed to be quiet. A question about the Lebowski, is tuning possible in the form of timing advancement and/or retardation? On the fly?
I really like that little bike frame, but I need to make it larger just not full size. Your early pics in the thread for 3 years ago don't work, and I'll like to get enough of quality side shot to maybe copy it. Hubmonster would really turn it into a mini crotch rocket. What is the OD of the wheels you have on it now?
John in CR
Postby Arlo1 » Tue May 28, 2013 12:54 am
John in CR wrote:Great to see a solid power run with nothing letting the smoke out of itself. It looks like the Colossus needs a blower, but that's easy.
The PWM frequency at 14khz will cause more heat in the motor... Less in the controller. So new versions of the controller will have faster switching fets then I will UP the PWM frequency. I have not hooked up the liquid cooling yet... REMEMBER colossus is liquid cooled?
Noise is the harmonics in the motor for the most part. Its a DELTA wound motor with a big skirt bearing. There is other reasons for noise other than controller stuff. This controller is WAY quieter then a CHINA controller but I am also running 120% phase amplitude which gives a small amount of trapezoid wave added to the sine wave for more HP and higher top speed. (you can selsect this) I tested this for hours on the dyno to find what is close to the best.
Lebowski's code measures the inductance and resistance in the motor and sets the timing to the most efficient place for your motor. He told me how to change it but its highly experimental!
I will try to fix pictures. Its a Yamaha YSR 50 with R1 replica bodywork im building with carbon fiber. The od of the wheels is 19"
Last edited by Arlo1 on Tue May 28, 2013 12:58 am, edited 1 time in total. View post history.
Arlo1
Postby Lebowski » Tue May 28, 2013 2:10 am
John in CR wrote:Great to see a solid power run with nothing letting the smoke out of itself. It looks like the Colossus needs a blower, but that's easy. The part I don't understand is the noise. I thought sine wave controllers were supposed to be quiet. A question about the Lebowski, is tuning possible in the form of timing advancement and/or retardation? On the fly?
In my controller IC you can change the inductance used in the FOC algorithm, but this is in the setup menu, not on the fly.
Lebowski
Postby John in CR » Tue May 28, 2013 2:37 am
Your liquid and the metal it touches are too far from the heat source to be very effective. Heat transfer is a relatively slow process, and our motors need cooling at the copper and the magnets. Don't get caught up in that trap due to your experience with ICE's. The delta T's and the temp of the heat source are too different, and to make matters worse your cooling liquid can't get nearly as close to the heat source like in the water jacket of a cylinder. I assure you that motor is best cooled by a strong flow of fresh air through the gaps in the stator and the magnetic gap, and it's easily accomplished with a proper set of radial blades. You're turning plenty of rpm to make it highly effective.
John in CR
Postby Arlo1 » Tue May 28, 2013 9:01 am
John in CR wrote:Your liquid and the metal it touches are too far from the heat source to be very effective. Heat transfer is a relatively slow process, and our motors need cooling at the copper and the magnets. Don't get caught up in that trap due to your experience with ICE's. The delta T's and the temp of the heat source are too different, and to make matters worse your cooling liquid can't get nearly as close to the heat source like in the water jacket of a cylinder. I assure you that motor is best cooled by a strong flow of fresh air through the gaps in the stator and the magnetic gap, and it's easily accomplished with a proper set of radial blades. You're turning plenty of rpm to make it highly effective.
John
#1 The guys in Croatia hooked up liquid cooling and did some testing at higher power levels then me and had very good sucsess with it.
#2 when I run 20 kHz pwm the motor only climbed to 50 deg! So Im not worried about it yet.
#3 Oil sprayed on the ends of the windings is the best it works better then air but this works best on inner runners I will try to make sure some air moves through the motor but as I am not worried about it because I will be only using this controller until I get the next one finished with a faster switching time for faster pwm.
Arlo1
Postby hillzofvalp » Wed May 29, 2013 1:01 am
I have to say, Arlo, this is a pretty frocking cool project. I am very interested in building my own controller, but I don't know where to start. Probably finish EE degree..
hillzofvalp
Previous
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: Yankee1919 and 3 guests
