Wow, what happened to some of my pics? Are we having problems with the pics again? I thought that had gotten resolved.
Been doing a little work with the cart again. I can't find any motor plate or any info on the controller, but the contactor does have a sticker that says 36v, so I'm going to be treating this like a 36v build, rather than the possible 48v.
- 36v_contactor.jpg (66.14 KiB) Viewed 682 times
I put 3 12v batteries in and fixed the battery connection wiring, wired them in series and got 36.4v, they are some older SLAs that I had laying around and just threw them in for quick testing. I have some other ones on the chargers right now. This is where is starts getting a little weird. I found two switches, one is a key switch in the dash, and the other is a flip switch on the "firewall" into the motor/battery compartment, about where the passengers calves would be. (Don't know of a better way to describe that, here's a pic.)
- firewall_switch.jpg (86.67 KiB) Viewed 682 times
Tracing the key switch, one side goes to a connector on that reverser,
- reverse_control.jpg (72.45 KiB) Viewed 682 times
and the other side goes into a wiring harness that splits to both of the small lugs on the contactor, a 4 pin connection to the controller,
- throttle_input.jpg (68.62 KiB) Viewed 682 times
and into a box on the frame, which I'm thinking is housing the throttle pot. (Hard to get to that area at the moment, but a lever is sticking out of the box that moves with the throttle pedal, so it's my best guess.)
The "firewall" switch goes to the "red" small lug and the same side large lug on the contactor. But the weird thing is that is the not the side that the cable from the battery goes to. And, when I take a voltage read from the output lug of the contactor, I'm getting 36v no matter which switch is off or on. I don't know, there seems to be a lot of ghetto wiring on this thing, so I tend to get halfway lost trying to follow it. Maybe one of the wiring that they did isn't right. But I am getting 36v measuring from the controller B- and B+. But I'm still not getting any reaction from the motor when I press the throttle. Is there any way to test the controller output?
