12 x 4110 MOSFET Extreme Modder Controller LYEN Edition $129
Re: 12 x 4110 MOSFET Extreme Modder Controller LYEN Edition
Postby Kingfish » Thu Jul 21, 2011 5:49 pm
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9653 miles-to-date, 4163 as 2WD.
Kingfish
1.21 GW
1.21 GW
Postby Kingfish » Thu Jul 21, 2011 7:22 pm
Kingfish
1.21 GW
1.21 GW
Postby Kingfish » Fri Jul 22, 2011 10:00 pm
Kingfish
1.21 GW
1.21 GW
Postby oatnet » Sat Jul 23, 2011 12:25 pm
KingFish, you have hijacked this for-sale thread to make it your personal troubleshooting blog. (22) of the past (23) threads have been about your troubleshooting instead of sales, (14) of which you posted. This is inappropriate content for a for-sale thread, it belongs in "E-bike Technical" or "E-Bike general" etc. Further, any knowledge/content you generate here will be ERASED when this for-sale thread is eventually, automatically, deleted.
You posted earlier in this thread that you created this thread for your troubleshooting details: http://endless-sphere.com/forums/viewtopic.php?f=3&t=26675&start=60#p428840 . That is an example of an appropriate place where anyone who cares can find the details, and it will not be automatically deleted.
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
oatnet
Postby Kingfish » Sat Jul 23, 2011 3:12 pm
Kingfish
1.21 GW
1.21 GW
Postby nicobie » Sun Jul 24, 2011 2:27 pm
I believe that you got three responses to your shunt value question. All said that it was 2.4. You were offered a way to calibrate it correctly but you confused yourself by trying to use the max amps function on your CA.
oatnet made a good point when he mentioned that the forum rules spell out that all the for sale threads eventually disappear.
Hope you get your problems sorted out.
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby ZOMGVTEK » Sun Jul 24, 2011 8:51 pm
I have 3 of these controllers and they work just dandy at 100V 40-80A. Lyen did the high voltage regen mod for me, I got the 3 position switch from him, and I have never had any single issue with any of the controllers. I was briefly running slightly over 9KW until I determined my GM isnt much faster at that power level. The controller barely was warm, generally. The only time I was concerned, was when I was towing a car down the block. The high sustained power, and very low speed, lead to a warm controller.
The Rshunt isn't an exact science, setting it to the exact number for one will only get you fairly close, not dead on. If you really care about accurite values, get something like a Watts-Up or Turnigy meter, and calibrate it yourself. Set the CA to a rough value, like 2.4 or 2.0 mOhm, it wont matter much. Go a few miles, and compare the total AH consumed, mulptily the CA shunt value by the difference between the two values, BAM, it should be as accurite as the meter you used. The resistance of the in line power analyzer will not impact the shunt value, as both should be reading identical current. The Turnigy meter is probably a better bet, due to higher current ratings, backlight, the lower price, and POT's to calibrate it yourself.
I don't see how the seller should be responsable in ANY way for informing you of the exact Rshunt value.
ZOMGVTEK
Postby Arlo1 » Sun Jul 24, 2011 9:56 pm
I think its in the methods 18 fet thread but there is a way to run power through on phase lead and ground it will go through the freewheeling diodes in the fets and you can hook a multimeter in series or use something like the wire cut mode on a lipo charger set to a known amperage.
There is many ways to calibrate the shunt and king fish you seem alot smarter then me with this stuff so I know you can find a way.
And Dave who has some good deals on STUF
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Apology
Postby Kingfish » Sun Jul 24, 2011 10:26 pm
I am here to apologize, and to remove my posts between at Sat Jul 02, 2011 9:40 am and Sat Jul 23, 2011 1:12 pm on this thread by request. A copy of these posts and relevant replies may be placed on my Trailer thread possibly – that being the spawn of interest in dual controllers et cetera. This post shall remain as a pointer.
Lyen makes fine controllers. I have the namesake 12-FET mounted on my ebike and a 6-FET Mini-Monster in reserve; it is a nice unit accepting any-voltage and is quite flexible in utility. For more information on how I have adapted this controller, please refer to the Trailer thread as a primer.
Sincerely, KF
Kingfish
1.21 GW
1.21 GW
Postby Bubba » Wed Aug 03, 2011 5:07 pm
Zenid wrote:FYI, the second part of my blog/review of the LYEN 12-FET controller detailing my experiences with it is now available for the perusal of anyone who is interested:
http://zenid10.wordpress.com/2011/04/10/50-at-50-amps/
(Part one: http://zenid10.wordpress.com/2011/04/04 ... and-angry/)
Excellent blog! Thanks for sharing!
Bubba
Postby hillzofvalp » Fri Aug 12, 2011 5:51 pm
what is the max phase current stock?
hillzofvalp
Postby Lyen » Sat Aug 13, 2011 4:52 am
hillzofvalp wrote:what is the max phase current stock?
PM sent :)
Items For Sale
Please sign up here and donate your marrow to save life.
Lyen
Postby nicobie » Sat Aug 13, 2011 2:19 pm
PM sent :)
I'd like to know that too.
Thanks,
Nick
nicobie
Postby hillzofvalp » Sat Aug 13, 2011 7:01 pm
I'm talking about phase current.. not max controller current... the parameter for phase current can be defined in programming...
hillzofvalp
Postby hillzofvalp » Sat Aug 13, 2011 7:30 pm
hillzofvalp
Postby gensem » Wed Aug 17, 2011 9:16 am
I also would like to know the maximum phase current.
BR
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
gensem
Postby Arlo1 » Wed Aug 17, 2011 9:19 am
I would like to know the max phase current too. Why not post it in the thread LYEN?
Arlo1
Postby oatnet » Wed Aug 17, 2011 11:16 am
Arlo1 wrote:I would like to know the max phase current too. Why not post it in the thread LYEN?
I believe that Lyen considers data about the stuff he sells to be IP (intellectual property) because I have only seen him send it in PM. I think I once made him cross when I innocently posted his ebike-tester instructions, like I would with any other product used on endless-sphere.
-JD
Image大鸡巴 Motors
oatnet
Postby Arlo1 » Wed Aug 17, 2011 3:15 pm
Endlesssphere is about helping each other. And knowing phase amps for a controller you are trying to sell to make money will make you more money!
Arlo1
Postby grindz145 » Wed Aug 17, 2011 4:08 pm
He probably doesn't know, the only control mechanism on these is the shunt feedback which is battery current. It's not easy to measure phase current, let alone specify it in certain limits.
He does like to send information directly though, I've noticed that. Good guy though.
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby hillzofvalp » Wed Aug 17, 2011 9:12 pm
He had an idea of what to set it to in his response to me in pm. I've seen figures quoted elsewhere in the forum so I will just say the ones I've seen: phase current should be about 2.3-2.5 times controller current. This is an open forum, but I do respect Lyen's effort to maintain his status as the Go-TO guy...
hillzofvalp
Postby gensem » Wed Aug 17, 2011 11:09 pm
If I was to guess I woulda say 50-60 main and 125-150 phase.... but leaning toward the lower end, because phase 150 phase can blow a 12fet controller easily in a hot day.
gensem
Postby Lyen » Fri Aug 19, 2011 11:23 pm
Replied via PM on August 13th, 2011. :)
nicobie wrote:
PM sent :)
Thanks,
Nick
Items For Sale
Lyen
hillzofvalp wrote:I'm talking about phase current.. not max controller current... the parameter for phase current can be defined in programming...
Items For Sale
Lyen
Postby Lyen » Fri Aug 19, 2011 11:27 pm
gensem wrote:I also would like to know the maximum phase current.
BR
Replied via PM :)
Items For Sale
Lyen
PreviousNext
Users browsing this forum: emcee, nechaus, XLR8 and 4 guests
