72v 1500W 40A Hua Tong CA08 XM06AD_P04.1 controller
Re: 72v 1500W 40A Hua Tong Generic controller connections
Postby kentlim26 » Sat Aug 06, 2011 4:45 am
My methods above i have been using for years, my previous switch was a cheap type yet it still work for a very long time, about 2years, until the 2 way plastic switches.. I pressed until is damage. now my current 2 switches is alot better quality, i think this will last me a very long time, easily 5years. i think i will use this for any controllers if is a 48v, if is a higher volts.. i think got to do a testing again... 100ohm, or 200ohm, 300ohm, 400, or 500ohm ? test it directly to the battery 88v or 80v.. see until the sparks disappear. try not to used resistor 10watts 1000ohm or more. It output no current to the controller. it needs abit of current to reach the caps.
there is a method used in kelly controller, has the diagram how the circuit works for the controller. it is the same can be used for this controller.
Conhis hub motor run on April 2010, 48v 1000watts hub motor distance run 5800km, and Re~alive cyclone kit bought in year 2009, Bought a greentime controller 18fets- 4110 , 48v~ 90v , 3-speed mode. Latest top speed I got for my greentime controller 76.8km/h ! , yet to reach 80km/h, or I will never reached 80km/h ?
kentlim26
Postby wesnewell » Sat Aug 06, 2011 12:04 pm
I started with one 10W 510ohm resistor. It wouldn't allow enough current to charge the caps. Added another in parallel, but still wasn't enough. Three in parallel for 30W 170ohm works perfect for 50-100V battery pack.
Mongoose 26" FS MTB bike $99, yescomusa.com 48V 1000W rear hub kit $276, Hua Tong 72V 40A controller $35, 10ah 24s lipo $275=40+mph, range=45 miles @20mph
wesnewell
Postby iovaykind » Sat Aug 06, 2011 12:14 pm
My ebike is alive. The ride is crazy :shock: Don't know how I can deal with the throttle being so jumpy though.. makes it feel very unsafe if I accidentally throttle it too much.
Winter needs to end already!
iovaykind
Postby PeeHell » Sat Aug 06, 2011 1:59 pm
Is there someone here that has tried this controlller on a 9c hub ? If yes does the phase wire match ?
PeeHell
Postby iovaykind » Sat Aug 06, 2011 5:58 pm
Not that I know of, but the problem is that the website we were using for lyen controllers is now gone because of the new ownership issues. Good luck finding it. Keep us posted, its valuable.
iovaykind
Postby wesnewell » Sun Aug 07, 2011 3:46 am
wesnewell
Postby PeeHell » Mon Aug 08, 2011 11:36 pm
Is there someone who opened the controller ? Can you see if the battery wire and the voltmeter wire are directly in parallel or is there something between them ? Because the voltmeter plug could be used to bulk charge the batteries or to feed a second controller...
PeeHell
Postby kentlim26 » Mon Aug 08, 2011 11:54 pm
i have open up the controller afew times. i cannot see they join in parallel, i have took the volts meter out Too. they are not useful wires. the volt meter wires are very thin, cannot do anything much except to check volts.
ken
kentlim26
Postby jonathanm » Tue Aug 09, 2011 12:39 am
Yes it does. the voltmeter is the wire in this photo and you can just the the V+ pad in the top of the picture
jonathanm
Postby kentlim26 » Sat Aug 13, 2011 8:37 pm
hi.. every one and good morning !
This hua tong controller will work with cyclone MOTORs too !! im very happy and it really work for hua tong controller. Cyclone controller are a crazy expensive pricing USD160.00.. im really happy and this motor really Work and run very well from hua tong controller. it took me many months to find out why it don't work, it was totally my fault becasue i didn't check the wiring connection properly. so if anyone cyclone controller do not work... please you can really find other source controller to work with..
cheers
kentlim
kentlim26
Postby wesnewell » Sun Aug 14, 2011 1:15 am
It should work with any brushless motor. What I'm looking for now is reverse and a way to up the regen voltage, and any other things that might be useful. Just don't want to mess with it till I get the spare I ordered in case I blow it up.
wesnewell
Postby iovaykind » Sun Aug 14, 2011 11:36 am
Have you found use for reverse? I never found it useful to have it. This regen mod im hoping you'll figure out wes. would definitely use it especially at the speed of these bikes.
iovaykind
Postby wesnewell » Mon Aug 15, 2011 1:07 am
Reverse would come in handy for trikes. But basically, I just think it would be nice to know what all features it does support and document them somewhere.
wesnewell
Postby John in CR » Tue Aug 16, 2011 10:15 am
If it's a 100% power reverse then it would be useful for a retro-direct 2 speed, however, reverse are often programmed at only around 30% of max power.
John in CR
Postby iovaykind » Tue Aug 16, 2011 2:37 pm
I tried rigging up the voltmeter today but ran into a problem. The "alarm" plug that's supposed to be Battery+/5v/ground isn't giving me the 5 volts I need to run my voltmeter. It's only giving out 4.2 volts and that's not enough to turn it on. Anyone else had this problem and figured out a way to get the wire to give out 5v?
iovaykind
Postby wesnewell » Tue Aug 16, 2011 5:58 pm
There's a 5V bus inside the controller. Use it. The grey alarm lead isn't connected directly to the 5V bus, but to A3. I got 4.6V out of it.
wesnewell
Postby iovaykind » Tue Aug 16, 2011 6:03 pm
ended up using an old phone charger. 20s makes it work and I got 5v out of it that way.
iovaykind
Postby wesnewell » Wed Aug 17, 2011 3:24 am
OK, I found the phase/hall match ups for Lyens controller. They should be the same as the Hua Tong controller.
Below are the known color linings for both hall and phase wires:
Lyen Controller to Crystalyte motor wire color lining:
Controller: Motor:
HALL:
Yellow Yellow
Green Blue
Blue Green
PHASE:
Yellow Blue
Green Green
Blue Yellow
_______________________
Lyen Controller to Ebikekit 9C motor wire color lining (around 2A unlaced freewheel at 44.4v):
Controller: Motor:
Hall:
Yellow Yellow
Green Blue
Blue Green
Phase:
Yellow Yellow
Green Blue
Blue Green
or
Controller: Motor:
Hall:
Yellow Yellow
Green Blue
Blue Green
Phase:
Yellow Blue
Green Green
Blue Yellow
Lyen Controller to Puma/MAC/BMC geared hub motor wire color lining including motors from Ebikes SF, motors from Australia, and the silver color ones (around 4.7A for Puma/MAC and 3.7A for BMC unlaced freewheel at 44.4v tested on 4/5/2011):
Controller: Motor:
Hall:
Yellow Green
Green Yellow
Blue Blue
Phase:
Yellow Green
Green Yellow
Blue Blue
or
Controller: Motor:
Hall:
Yellow Blue
Green Green
Blue Yellow
Phase:
Yellow Blue
Green Green
Blue Yellow
or
Controller: Motor:
Hall:
Yellow Yellow
Green Green
Blue Blue
Phase:
Yellow Green
Green Yellow
Blue Blue
Lyen controller to Ezee geared hub motor wire color lining:
User tested (works with 3 combination):
#1
Controller: Motor:
Hall:
Yellow Yellow
Green Green
Blue Blue
Phase:
Yellow Blue
Green Green
Blue Yellow
#2
Controller: Motor:
Hall:
Yellow Green
Green Blue
Blue Yellow
Phase:
Yellow Green
Green Yellow
Blue Blue
#3
Controller: Motor:
Hall:
Yellow Blue
Green Yellow
Blue Green
Phase:
Yellow Yellow
Green Blue
Blue Green
Lyen Controller to Maxi Might motor wire color lining (3/28/2011):
Controller: Motor:
HALL:
Yellow Yellow
Green Blue
Blue Green
PHASE:
Yellow Blue
Green Yellow
Blue Green
Lyen controller to Cyclone motor:
Controller: Motor:
Red Yellow
Black Orange
Hall:
Yellow Red
Green White
Blue Black
Phase:
Yellow Red
Green White
Blue Black
Throttle:
Controller > Throttle:
Red Red
Black White
Green Yellow
Lyen Controller to Golden Motor MagicPie motor wire color lining (5/19/2011):
Controller: Motor:
HALL:
Yellow Green
Green Yellow
Blue Blue
PHASE:
Yellow Green
Green Yellow
Blue Blue
wesnewell
Postby PeeHell » Wed Aug 17, 2011 1:41 pm
Do you know what the phase angle is for the motors listed above ? Because it's the first time I see such a connector on a controller.
PeeHell
Postby iovaykind » Wed Aug 17, 2011 1:43 pm
Phase angles just try 60 and if it doesn't work try 120 by connecting the ends together. Doesn't hurt the motor.
iovaykind
Postby wesnewell » Wed Aug 17, 2011 1:56 pm
I'm pretty sure they are all 120.
wesnewell
Postby PeeHell » Thu Aug 18, 2011 12:19 am
Does anyone knows if it can be programmable and/or have a 3 speed switch ?
PeeHell
Postby iovaykind » Fri Aug 19, 2011 9:11 am
I don't think its programmable or has 3 speed switch, though the 3sp would be awesome since our throttles can be quite jumpy when you've got so much power going to the wheels.
iovaykind
Postby bobale » Fri Aug 19, 2011 5:29 pm
Did anybody of you who opened controller noticed which FETs are inside?
RWD 2807 9Continent rolling on Kenda Flame 26x2.125
12S3P out of Turnigy 4S Hardcase 20C (600Wh)
35A 9FET Infineon Controller (Regen, Cruise control, Speed limit)
Top Speed 27mph (31mph@120%)
bobale
Re: 72v 1500W 40A Hua Tong CA08 XM06AD_P04.1 controller
Postby wesnewell » Fri Aug 19, 2011 5:37 pm
The fets are 4410's, rated for 100V.
wesnewell
PreviousNext
Return to E-Bike Technical
Users browsing this forum: No registered users and 6 guests
