auraslip
- Joined
- Mar 5, 2010
- Messages
- 3,535
The best solution IMHO is to build the double-hall throttle. It is the natural solution and builds in slightly less power to the front hub.
That would be important! I was thinking of a way to limit the throttle to the front hub at starts anyways. Keep the front wheel from just spinning (also it'd reduce the need for giant torque arms) This would kill two birds with one stone. Probably the smoothest way to do it too. Just wish it worked with a magura.
XLYTE has a two motor controller out. Probably could just reverse engineer the circuit on that to figure it out?
