way hey... just found this section of ES... Nice as I have "accidentally" gone a a bit scooterish (as part of what i do, I occasionally get to buy dead or dieing e-vehicles, and pull em apart to figure out how they work, then hopefully put em back together again, only better and last couple of weeks I've managed to get a couple of smaller kick scooters... kinda razor ish style... )
BUT that's not the main point of this post...
This is my latest "transport of choice"....
- 1355114842757.jpg (39.97 KiB) Viewed 750 times
This is a converted Adult Sized (20" wheel) kick scooter
- 1355007080149.jpg (37.02 KiB) Viewed 750 times
- 1355007081171.jpg (50.81 KiB) Viewed 750 times
Kinda got lucky with this fram design being THREE down tubes which makes for a neat little space for batteries and controller...
I have placed a 20" geared hubmotor on the back, originally sourced from a front wheel drive trike... had to expand the dropouts about 10mm to fit it...
Currently it is running 48v 15ah (57v hot off the charger via a split Konion cell 14s pack) through a 10 amp controller, giving... roughly 500 watts... Top speed is around 30 km/h (faster than the average cyclist) and at this "low" wattage I get a range of roughly 50 km.
On steeper grades I assist it with kick... at max speed tho, kicking is kinda pointless (leg wont move fast enough to add any power)
As you can see it is still in the "prototype" stage (wires and shizzle and packs strapped to the frame)... so it looks wierd science... but functionality wise... it is the bizz
I am going through the process right now of neatening it up, and will be adding a rack over the rear wheel.... and looking to enclose the batteries and cntroller in their current strapped to the downtube format, and bring switchgear and meters up onto the handlebars.
It is purty heavy.. I'd guestimate around 25kg... 10 kg of which are the batteries (konion pack is heavy, and ultimately the reason it is on this vehicle, cos personally I reckon the pack is too heavy for the WHrs for a bike.
Handling wise it is a dream... The weight down low seems to suit this type of vehicle well... The dinky little kick stand is failing but that is no surprise...
It is running oldskool single pivot brakes front and back (with motor cutoff)
Clearance is a slight issue... in my opinion this is definately an urban surface vehicle, and I have learnt to judge ramp exits and such fairly well, and avoid/dismount/slow down with the odd scrape occuring still...
In the urban environment there are a lot of plusses... it is very easy to bring up onto the back wheel and wheel around, mono style, which works well for negotiating steps and escalators and the like... so much so that I reckon rear wheel drive REALLY has a huge advantage over front, just for this purpose....
I MIGHT up the power to 1kw... but gotta say that the current range really floats my boat...
All in all I am really astounded with the convenience of this vehicle... it'll fit anywhere a bicycle will fit (IE easy for Public transport)... very simple step-and-go (no need to worry about trouser cuff and shoelace "interacting" with chain and chainring...) the current max speed of around 30km/h is more than fine for cycle ways and lanes, and the configuration makes it easy to step off in crowded ped areas and has less widt for wheeling around than a bike.
Far more transport versus fitness though
Well pleased to see that 20" wheel kick frames are still being manufactured, cos for the life of me I can't find any here in AUS except for being really lucky with this one which I picked up second hand....
Oh and one final MAJOR point.... Chicks Dig It
Joe
