zEEz wrote:Is this topic really DEAD? No COLOSSUS talks anymore????![]()
Arlo1 wrote:Whats there to talk about we are at the mercy of mosfets that cant handle colossus!
zEEz wrote:Arlo1 wrote:Whats there to talk about we are at the mercy of mosfets that cant handle colossus!
Weppppp, Arlo, a lot to talk about it would be ....![]()
Some months ago I heard about a website to sell colossus online, about an imminent
ultimate version for people willing to buy, a matched controller tested in Croatia ....![]()
But after that just Dead Forum and nobody around![]()
By the way, Arlo, how about the super-fets from lfp you wanted to use?
have fun!
zEEz wrote:Thanks from the updates from arlo and splinter .... 7kW is a good output
for that motor if the system is reliable and working fine ...![]()
have fun!
SplinterOz wrote:Note I have not hooked up the water cooling on this yet so until I get my full battery pack and the cooling I will not be pushing it much harder.
markobetti wrote:Splint , do you have cycle analyst ? Some readings from it ?...would be good
markobetti wrote:We are working on them , i have made something new ; so i am waiting for factory to send it a . After 3 months we will start taking orders i think. Just give us time to get all bugs controller-motor figured out .
SplinterOz wrote:markobetti wrote:Splint , do you have cycle analyst ? Some readings from it ?...would be good
I am not running the Cycle Analyst I have as it is a direct plugin model and that does not work with the Kelly.
However I am going to rig up a small camera, volt meter, amp meter and GPS speedo so you can all see how it is going. Give me a day or so.
Arlo1 wrote:If you follow the wiring you can open up the Kelly and install the CA to work with it. Just have to cut the end of the CA wire plug off and solder the wires where they need to go on the circuit board.
SplinterOz wrote:Arlo1 wrote:If you follow the wiring you can open up the Kelly and install the CA to work with it. Just have to cut the end of the CA wire plug off and solder the wires where they need to go on the circuit board.
Arlo1, I am quite happy to leave my working and in warranty Kelly intact. I might be able to get hold of a cycle analyst and shunt later this week. That would allow some real data.
However I can get nearly all the same info with a amp meter (already on the bike), speedo (have to put on the magnet) and volt meter. That will give me the instantaneous usage at any time for any given speed. I just don't know Wh per km not a big deal at the moment.
Arlo1 wrote:SplinterOz wrote:Arlo1 wrote:If you follow the wiring you can open up the Kelly and install the CA to work with it. Just have to cut the end of the CA wire plug off and solder the wires where they need to go on the circuit board.
Yeh if you have the data you need its not worth the hasle. Have you got something to watch phase amps?
zEEz wrote:Hey SplinterOz!
Your motorbike is already useable for short range commuting ... that is Great!![]()
are you planning to add more headways???![]()
I wonder how fast you could go with full motor current and Liquid Cooling ...![]()
130kmph should be there ...![]()
Do you plan to make it street legal? How it is with regulations in Australia?![]()
have fun!
SplinterOz wrote:The ADR (Australian Design Rules) have a section on modified motorcycle and another on EV conversions. I just have to comply and get an Engineer's Certificate.
Already having fun.
Users browsing this forum: gwhy! and 4 guests
