SURVEY: Your watts at various speeds
Get the forum community involved in polls and surveys.
Re: SURVEY: Your watts at various speeds
Postby Metallover » Fri May 28, 2010 11:30 am
Some rough numbers. 26" 9c at 66.6v lipo. I am using the ebike calculator for these predictions, and they seem pretty accurate.
Watts at:
10mph - 75w
15mph - 150w
20mph - 280w
25mph - 500w
30mph - 800w
35mph - 1225w
40mph ~ 1750w
45mph ~ 2450w
The numbers are all estimates from the e-bike calculator. I can almost always hit 35-36mph with a my 20a, 1500w power limit.
I got a graph out of the ebike calculator.
Add your bike to the Unofficial E-Bike Garage! - http://spreadsheets2.google.com/ccc?key ... OWcg&hl=en
Novara Buzz FS MTB- 18s 15Ah Turnigy Lipo - 12Fet controller @57A - 9C 2807 motor - 600W charging - 4500W peak - 40Mph - 20Mi range
Metallover
Postby piersdad » Mon Jun 14, 2010 2:43 pm
Watts at:
10mph - 75w
15mph - 150w
20mph - 280w
25mph - 500w
30mph - 800w
35mph - 1225w
interesting.
i specialize now (in retirement) with mobility scooters
24 v at 6km/h =6 amps 144 watts
24v at 12 km/h =12 amps 288 watts
total weight approx 150 kg 4 cross ply tires all independent suspension and wind shield
combination of cog belt and chain drive.
so although i cant have 26 inch wheels there would be lot of potential improvement here for this sort of transport
much of scooter design is 100 years behind the times
http://www.storydad.com/forum/index.php?topic=261.0
you don't know how little you know
till you learn enough to know you know nothing
piersdad
10 µW
10 µW
Postby amberwolf » Tue Jul 20, 2010 9:51 pm
Crossposted from the DayGlo Avenger MkII build thread:
viewtopic.php?p=292010#p292010
There was some slightly gusty breeze that varies in direction, so I rode in all four cardinal directions with the streets around here and get these readings, using the 9C, 36V 13Ah NiMH, and Lyen 6FET. I forgot to look at the Watts reading but was instead looking at Amps, :( so that's what I've written down below:
5MPH = 3-4A
10MPH = 4-6A
15MPH = 5-7A
20MPH = 11-13A
To get to the desired speed for steady reading, I rode for at least 3 seconds at that speed with no spedometer variation before glancing at the WU readout. Would've been longer, but there is too much traffic this time of day in the neighborhood and the roads are too short in some cases, before coming to stop signs or other speed-altering situations.
Since the voltage for 5-15MPH is around the same, at 38-40V, and at 20MPH is around 33-35V, that puts calculated watts-at-speed at these numbers:
5MPH = 114 -160W
10MPH = 160 -240W
15MPH = 190 - 280W
20MPH = 363 - 455W
Accelerating up to those speeds takes a lot more power; the peak watt reading was 841W, and the peak amps were 24.63. Minimum voltage was 32.44, resting voltage after return was 38.5. Total of 1.544Ah used up.
Total mileage doing these tests was 3.396 miles, and total Wh was 56.3, giving a Wh/mile of 16.58. Surprisingly low given that I was not pedalling at all, and the heavy accelerations I did for extended periods for the 20MPH runs (which were interrrupted multiple times due to heavier traffic out on the faster longer roads).
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby amberwolf » Fri Nov 19, 2010 12:38 am
Less-scientific post this time, but a probably more accurate reading:
http://www.endless-sphere.com/forums/vi ... 13#p334613
CrazyBike2 using a Vpower/CammyCC 48V20Ah pack, running a 12FET Infineon generic with a 9C front 26" wheel. Total bike weight (including battery packs/etc) is probably 185lbs right now plus my own 155lbs.
I failed to remember any data other than 20MPH took 260-290W, consistently throughout a 2.9-3mile trip, with varying directions and very slight slope changes (nearly completely flat for all intents and purposes).
I'll have better and more data at some point soonish, now that I have the large-screen CA to make reading this stuff while riding possible. I may also be able to log the data once I make the cable and rig up an old laptop with serial port in the cargo pod.
Then I can also take the pods off and compare readings, to see if it is much lower without them.
As an aside, it is interesting to note that CrazyBike2 (semi-recumbent) is so much lower than DayGlo Avenger (regular fully-upright riding) for power for the same speed, using the same motor and wheel, even with a slightly higher voltage battery pack (about 4V) and that CB2 is MUCH heavier than DGA, at least twice as heavy right now.
amberwolf
Postby amberwolf » Tue Nov 23, 2010 3:27 am
Hunh. When I tested same conditions but using the NiMH (~4v less total pack voltage), I got 360-390W for 20Mph. :?
Why *more* power needed for less voltge at same speed? More current, sure, same power total expected.... kless, actually, since the heavy vpower pack was not on the bike .
amberwolf
Postby Joe90 » Thu Jun 09, 2011 1:19 pm
44km/h = 820w input upright on the bike this is 18.6 wh/km
70km/h = 2400w input crouching on the bike this is 34.3 wh/km
Michel Cote
Norco Tactik 9C-2805 20"
21S2P 10Ah lipo + Kelly KBS72121
70km/h top speed
7+ kW max input power
Joe90
Postby mylittlepony » Tue Sep 27, 2011 10:28 am
Hi everyone,
I found these results useful but I thought it would be nice if they were collated better. I've made up a survey thing that will collate and graph all the results automatically. Anyone fancy entering their data into it here?
Check out my ride - E-Patriot
Take part in my Power vs Speed Survey
mylittlepony
Postby veloman » Tue Sep 27, 2011 10:45 am
20mph = 250watts
25mph = 450watts
28mph = 650watts
I don't have the typical ebike.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby Doctorbass » Tue Sep 27, 2011 11:00 am
GIANT DH motocross style ( NOT EFFICIENT. BUT BRUTE !! :twisted: )
0km/h 60W (DC-Dc, controlle and LED) :D
32km/h 550W
75km/h 4300W
100km/h 8000W
113km/h 11500W
140kmh/h ??
at up to 75kmh it's with my 20 x 3.00 moto tire and 5305
at above 75km/h it's with my 24 x 2.5 maxxis wookworm and 5303
KMX e-trike
5304 on 20'
0km/h 30W (DC-Dc, controlelr and LED) :D
32km/h 450W
75-80km/h 2800W
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby mylittlepony » Tue Sep 27, 2011 11:10 am
I didn't mean put the data in this thread - I meant HERE
mylittlepony
Postby Farfle » Wed May 23, 2012 7:52 pm
Watts at:
10mph - ~150
15mph - ~250
20mph - ~300
25mph - ~400
30mph - ~ 850
35mph - 1.5k
40mph - 3.6k
45mph - 4.5k
50mph - 6k
>50mph - @ 70mph, 11.2kw (120A @ 94V)
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby veloman » Wed Jul 04, 2012 3:21 pm
I did some riding with the watt meter on some dead flat stretches. There was a strong sustained wind, so I averaged the two below:
22mph into headwind 570watts
22mph with tailwind 350watts
so, that would give about 460watts at 22mph. With no wind, it should actually be less, like 400watts I'd say. Introducing wind with make things slower overall.
Not very scientific, but the best I could do without uploading data into a graph or excel.
BTW, my no load wattage at 38mph is 145watts. (52v on Mac 8 turn). I think this is kind of high, but not sure.
veloman
Postby veloman » Wed Jul 04, 2012 3:24 pm
Farfle wrote:Watts at:
10mph - ~150
15mph - ~250
20mph - ~300
25mph - ~400
30mph - ~ 850
35mph - 1.5k
40mph - 3.6k
45mph - 4.5k
50mph - 6k
If you were to chart these numbers, I think you'd see they don't look right. How do you get a 2.1kw jump from 35 to 40, but only a .9kw jump from 40 to 45? I guess it's possible if a setup has a weird torque band.
veloman
Postby Farfle » Wed Jul 18, 2012 10:46 pm
I may have my data a bit messed up, it was taken on the fly. Ill try it again with the new motor. hopefully should get some more accurate numbers up to the 90 mph mark :twisted:
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby veloman » Thu Sep 06, 2012 7:56 pm
Tested tonight with light wind on the same flat stretch as before, but on my 2806 9c. Averaged 480watts at 25mph, no funky aero tuck or anything. The 9c should be more efficient at this speed than my macs. I seem to average slightly less wh/mile overall.
25mph - 480watts - standard 9c wheel, 48v battery 4110 fet controller
20mph is 300ish, but I didn't do a real test of it.
veloman
Postby idontknowwatt » Wed Dec 05, 2012 8:16 am
31mph
20in rims and tires inflated to 58psi
15ah @ 36v LiFepo4
Currie 36v 750w motor
36v 30a 1000w controler
15t front sprocket 90t rear
Total weight with rider 362 Lbs
It’s not what you know, or don’t know. It’s what you know that isn’t so that can hurt you
Roy Rodgers – circa ( 1939 )
idontknowwatt
Postby e-biker » Sun Dec 30, 2012 5:40 pm
I get 67wh per mile @ 44.6 mph @ 2100 watts
24s 3P lyen 18fet clyte 3595 double crown monster ft forks Large hard tail steel frame
24 s 3P lyen 12 fet magic pie 2 double crown monster ft forks large steel frame
e-biker
Postby pendragon8000 » Wed May 15, 2013 7:28 am
30kph 200watt (may by more, I can pedal it up to 40kph for many mins limited at 200 , 29er xc bike)
60kph 1100watt tuck position with semi slick tyers on high psi.
pendragon8000
Previous
Return to Polls & Surveys
Users browsing this forum: No registered users and 0 guests
cron
