5403/5404 US/CANADA deadline! order is made!!!
Re: 5403/5404 US/CANADA Quota met! still taking orders! UPDA
Postby mvly » Tue Sep 27, 2011 10:59 pm
Will there be another run eventually? I really want to get one but do not have the. Money for it right now.
mvly
Postby Doctorbass » Tue Sep 27, 2011 11:40 pm
I spoke to a guy from italy that said he bought a 5405 ?? did you heard about them?
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby damcard » Thu Sep 29, 2011 6:39 pm
Max, just saw your email. I will send my info soon.
Can someone help me decide on the 135mm vs 150mm axle spacing. I am not concerned with gears and actually a 1 speed is fine. Also, I will be building my rear fork custom for this so I am not trying to put it into an existing bike. I do want a strong wheel. My concern is the 135mm will be the same as the 150mm motor simply with a shorter axle. If that is the case, I am guessing the 150mm would have the rim centered and the 135mm would have to dish the rim a bit. I want as little dish as I can get. Will the 135mm axle spacing require me to dish my wheel when I lace it up, or will it be centered? Is there anyone with a 135mm spacing 5400 out there? -Damcard
damcard
Postby cassschr1 » Thu Sep 29, 2011 8:56 pm
Food for thought. Last time I bought a 5305 in a rim I thought every thing was fine. Got to LBS and found a flat spot. Probably happened in shipping as lacing improperly would not have been able to do this. This was a used motor with a brand new rim. So I bought a salsa gordo rim ,new spokes etc and end up with much better setup. A bent rim could happen real easy tossing those boxes around.
Most rear dropouts 135mm wide.....like 95% Ok , just read you thread again. Why don't you try emailing kenny at crystalite?
cassschr1
Postby scriewy » Fri Sep 30, 2011 8:31 am
damcard i think the 135mm will be less dished.
i was checking disk brakes spacing from the frame on 135mm and 150mm frames, in bike stores and they seem same, only the hieght of bracket changes with bigger disk diameter, but i didnt measure it with caliber.
if the disk spacing is the same then that means the motor should be at same distance from the rear fork on disk side, wich leaves you with more space on the freewheel side in a 150mm axle, so if looking at the bike from it's back where freewheel is in right and disk is on left, the motor will be more dished to it's left.
i have the 405, which is same width, and from posts i red about the 400 there was a problem using a disk, not anough space with 6-7 speed freewheels, so i am guessing they moved the motor to the right side on the expanse of speeds so we can use only 3 speed freewheels, what tells me that in 135mm axle the motor is more centered
it's a pitty i wont stay to see the world crumble, u jedi Scum
clyte 405,
went through battle, bloody resurected Dewalts 4x28v 2s2p usable 2.7ah, 52v drops to 44v at 54kmh
78v 2ah Vdrop to 58v at max 66kmh.
72kg rider + 23kg bike.
keywin 20a 30-70v mod to 6 4110 as methods advised for noobs, shunted 38a
clyte 24-72v 40a mod 4310 to 4110, shunted to 77a
17.5.11 - 5000km
at 78v 4ah 72.7kmh Vdrop to 68v
10.11 - 82.1kmh
30.8.12-17000km
a place for lasers as ES is for e-vehicles - laserpointerforums.com
scriewy
Postby wojtek » Sat Oct 01, 2011 2:39 am
Doctorbass wrote:I spoke to a guy from italy that said he bought a 5405 ?? did you heard about them?
Doc
yes i did. I know crystalyte europe were supposed to have some USED 5405s for sale at some stage next year.... But last time i contacted them they didnt recall saying me that haha
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby PaulD » Sun Oct 02, 2011 10:07 pm
Payment sent! This is going to make for a badass little scooter...
PaulD
Postby damcard » Sun Oct 02, 2011 10:34 pm
Payment sent. Please let me know if I did it right or you have any questions. Thanks -Damcard
damcard
Postby Andje » Mon Oct 03, 2011 3:44 pm
payment sent.
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Postby Deutch420 » Mon Oct 03, 2011 4:37 pm
My payment is sent as well. :D
GM Rear, 12 FET Lyen @ 45A, 24s2p Turnigy LiPo, 1999 Mongoose: 49MPH.
5304 rear 18FET lyen @ 80amps, 24s4p Kona Dawg: 52mph | 5403 rear @ 80amps 100v = 58mph
Winter build *5403 rear 24FET Lyen @ 100amps, minimum of 100v 20ah. Phasor 4130 frame
Deutch420
Postby Evoforce » Wed Oct 05, 2011 1:51 am
Me sent payment too!
"Energy is all consuming and it is never ending. It just changes form as it morphs through time and space... " Evoforce
        Several 5403 motors,  no time to build projects! Phoenix Racer(5303) crystalyte suspension mtn bike LiFepo4 72/20.  (409) crystalyte 48 volt hardtail.  In process... Phoenix Cruiser(5304)  LiFePo4 48/20.  First electric bike a 2009 XB 502-700 style, 36/20 sla scooter bike.  All charged by solar!
Evoforce
Postby sabb » Thu Oct 06, 2011 3:04 pm
Are we supposed to have email responses from Max and be sending payment.
I have not received any response to my email yet and don't want to miss the boat.
Stephen
sabb
Postby Deutch420 » Thu Oct 06, 2011 3:09 pm
sabb wrote:Are we supposed to have email responses from Max and be sending payment.
Stephen
yes, you should've gotten an email from max about a week ago. It tells you what to do, prices for different options, who to pay etc... I think Max was looking to get all his replies by October 3rd. Atleast that's what the email said. I would just shoot max an email and jump in ASAP.
Deutch420
Postby sabb » Tue Oct 11, 2011 8:13 pm
Max I reforwarded you an email that i sent back on sept 16 if you do not recieve it can you please pm me so we can figure out why
I do want a 5403 with 135 mm axel and laced into a rim
Stephen
sabb
Postby Beavinator » Fri Oct 14, 2011 1:38 pm
Hello everyone! Im sure that everyone is anxiously awaiting their motors like me. I was just wondering if anybody has any idea what the RPM per Volt is on the 5404 motor?
Beavinator
Postby damcard » Fri Oct 14, 2011 2:21 pm
Is there a list somewhere to know for sure that my payment was received? -Damcard
damcard
Postby geetarboy » Fri Oct 14, 2011 8:22 pm
Beavinator wrote:Hello everyone! Im sure that everyone is anxiously awaiting their motors like me. I was just wondering if anybody has any idea what the RPM per Volt is on the 5404 motor?
I was discussing this w/ ZOMGVTEK, and we're hoping to hit 50mph running (24s) 100v,but that's just a guess. We know it's big, we know it's heavy, we know it has 11 gauge phase wires, so we will be able to throw a sh%@!load of juice at it without burning it up. It' gonna be fun :mrgreen:
geetarboy
Postby ZOMGVTEK » Fri Oct 14, 2011 8:32 pm
For some reason nobody really knows what speed these run. I'd be fine with it only going 30 on 24S, it would just give me an excuse for 48S!
As long as its >20MPH @ 100V, and <60 MPH @ 100V, i'm happy.
ZOMGVTEK
Postby Doctorbass » Fri Oct 14, 2011 10:55 pm
30s lipo + 5303+24" + 10kW = 113km/h ( I confirmed)
My guess:
30s lipo +5403 + 10kW = 115km/h ( more efficient motor bnecause more copper crossing the magnetic field)
24s lipo + 5403 = should be around 100km/h
24s lipo + 5404 = should be around 85kmh
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby itchynackers » Sat Oct 15, 2011 5:42 am
damcard wrote:Is there a list somewhere to know for sure that my payment was received? -Damcard
I second that! Haven't heard anything since payment was sent. It would be nice to receive confirmations.
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
itchynackers
Postby geetarboy » Sat Oct 15, 2011 10:46 am
Doctorbass wrote:30s lipo + 5303+24" + 10kW = 113km/h ( I confirmed)
My guess:
Doc
Sounds good Doc, You are talking about a 20 inch wheel? I have been thinking about running the 5404 @ 36s to keep the amps down. If I set-up the controller for 65amp, would I get the same result as 24s @ 100amp? - Mark
geetarboy
Postby itchynackers » Sat Oct 15, 2011 10:49 am
And a place for estimated delivery date.
itchynackers
Postby Andje » Sat Oct 15, 2011 11:08 am
yes mark, you would, watts are watts no matter what volt/amp you use to get there. HOWEVER. more volts=higher top rpm, so higher final top speed. more amps=controller melting/motor melting+heat... so most of us prefer volts to amps like you are suggesting :). Basically with the lipo rc, you wont be maxing it's amps out, but you will be capable of blowing controllers or motors for sure; that is the limiting side of the equation for most people; start with a top speed you want to hit, figure the kv out for the motor, find a controller that hits that speed at a certain voltage and there you go.
x5304- 95km/h
144v Kelly 300amp
5403/ future HS60
Andje
Postby itchynackers » Sat Oct 15, 2011 3:49 pm
And a place for updates in general (from the organizers)
itchynackers
Postby sabb » Sun Oct 16, 2011 9:05 pm
Max I need an email invoice from you so I can pay.
If you are not getting my emails at least pm me here and tell me that.
Stephen
sabb
PreviousNext
Users browsing this forum: incememed, kfong, rojitor and 3 guests
