Trilska wrote:Nice to see the Kelly working so fine together with the turnigy 80 100.
I am in the planning stage of a project including the same motor and a Kelly keb esc. Did you go for the esc upgrade to enable higher electrical rpm? Also what Kv do you get out of your motor?
/Trilska
bose wrote:I really like the simplicity of your build! Seems as if it works well too![]()
Which bottom bracket and cranks did you use? Is it the same ones as in the cyclone kits?
Great work!
Jay64 wrote:I know this is a little late, but nice build. Any updates to it recently? You had mentioned that the suspension wasn't up to par. You could probably just upgrade just the suspension. I've been looking into some of that stuff and have found some stuff for pretty good deals on ebay lately.
Where is that video taken? Looks like somewhere up country like Pukalani or Kula.
mauimart wrote:I have also been working on refining my Arduino based instrumentation/logging system (see photos). It's currently installed on my build #1 and is working quite reliably. In addition to displaying the critiacl e-bike parameters, similar to cyclye analyst, I have it logging the data to an SD card. There is still one bug I need to resolve. For some reason when the SD card is installed, the distance and wheel speed data is a bit off (1 to 2%). I think it has to do with the interrupt activated by the wheel sensor causing timing conflicts elsewhere in the code.It's spot on when not logging data.
AussieJester wrote:This is looking very very good! i think your going
to be extremely pleased with the performance
looking forward to video and hearing your impressions
after thrashing it for a bit hehe...
KiM
Whiplash wrote:How are you planning on mounting the box to the top tube? I have had really good luck with thread-serts, you can get the kit from harbor freight for like $18!
mauimart wrote:Another freshly uploaded video of what I have now named "The Vortex". Must get more batteries so I can ride longer...
Jay64 wrote:Man, that video brings back some memories. As little kids we used to charge down that road on our skateboards with long pipes for stability and then after college me and my buddy used to ride our motorcycles up and down that road all the time.
Users browsing this forum: electricbandit, rossasaurus, waynebergman and 8 guests
