So... meanwells... have you heard of these?
Postby auraslip » Thu Oct 13, 2011 10:45 pm
So apparently meanwell makes LED power supplies with much wider ranges of adjustment STOCK..... oh and they have built in current limiting adjustment..... and some of them are even water proof.
They cost more than we're used to, but might be a great option for some of you folks. I would totally use the hell out of one of these as an onboard charger for a 12s lipo setup. Wouldn't even need to water proof it; just zip tie it beneath the rack and put the cord in the bag.
http://www.mouser.com/Search/Refine.asp ... 4294902508
http://scolton.blogspot.com/2010/05/sup ... arger.html
this guy uses some for his scooter.
They're pricey, but about what it comes out to when ordering one of those KP chargers after shipping.
auraslip
1.21 GW
1.21 GW
Re: So... meanwells... have you heard of these?
Postby ZOMGVTEK » Thu Oct 13, 2011 11:31 pm
There's a thread around here somewhere with someone using these...
They can be found cheap if you dig around and are willing to wait. The biggest issue is they are lower power units. If you only need a few hundred watts, they are great.
ZOMGVTEK
Postby acuteaero » Thu Oct 13, 2011 11:49 pm
I have a 48V version of the HLG-240 which I use to charge a 12s LiPo pack- it works great. It's completely potted except for the trimpots which are under little rubber caps. They're obviously fanless and operate pretty quietly, only a little buzz above maybe 200w output. It's nice to have the CC/CV operation built in out of the box- and in a pretty tidy package unlikely to raise eyebrows charging at the office, say. It'd be well suited for an onboard charger except that it's pretty heavy- solid, potted... They also get pretty warm while operating at full power, but that's the cost of being sealed and fanless. The only other slight negative is that it's supplied with an unterminated AC input pigtail- but since it's potted you can't replace it with a more legit cord- either must splice it onto another cord or attach a cord head right to the pigtail.
It won't compete with other high powered mean-well supplies or server supplies for $/watt or lbs/watt, but for the right situation I think they're great. I like mine for charging at the office.
I got mine from Jameco, which had better stock and price than Mouser.
acuteaero
Postby auraslip » Fri Oct 14, 2011 12:56 am
That's what I'm thinking. They're for us non-recreational riders. 5 hour charge time isn't bad if I'm crashing at my girls place, or at school. I'm sick of having to worry about on the go charging. These looks reliable and quality.
auraslip
1.21 GW
1.21 GW
Postby icecube57 » Fri Oct 14, 2011 4:45 am
Good find. It would be nice just to have one for current limiting with server power supplies.
icecube57
1 GW
1 GW
Postby dogman » Fri Oct 14, 2011 5:52 am
Downside is it's potted? For an onboard charger that's perfect, not a downside! Looks ideal to me.
dogman
Postby mvly » Fri Oct 14, 2011 10:23 am
How would you know when the charge is done? This looks ideal because there is no fan and pretty simple and of course Meanwell high quality branding. But I would like to know when my charge is done so that I can remove it.
mvly
Postby nieles » Fri Oct 14, 2011 10:35 am
the best way would be to monitor the amps.. when aproaching zero the charging is done.
easier would be to just use a timer. let the batteries connected to the charger for 15-30 minutes longer than needed and you will be sure the batts are charged to 100%. i am pretty sure you wont harm your batteries charging using this method.
what batteries are you charging? for lipo batts i would not go above 4.15v per cell.
nieles
Postby mvly » Fri Oct 14, 2011 10:44 am
nieles wrote:the best way would be to monitor the amps.. when aproaching zero the charging is done.
I will be charging a LiFePo4 with BMS. The BMS will take care of the problem, but I just don't want to leave it plugged in because the BMS does dissipate the extra charge, so it does get hot over time.
mvly
Postby liveforphysics » Fri Oct 14, 2011 1:14 pm
Why have a BMS at all if you're not going to let it balance? lol
liveforphysics
Postby icecube57 » Fri Oct 14, 2011 2:48 pm
Let that ish indefintely float... no harm is being done.
icecube57
1 GW
1 GW
Postby mvly » Fri Oct 14, 2011 5:10 pm
The BMS balances itself afterwords regardless if it's plugged in or not.
mvly
Postby amberwolf » Sat Oct 15, 2011 4:25 am
Not exactly: If the charger is removed, the BMS would then drain down the high cell(s), but it cannot then top-off the still-low cells that were below the HVC.
If the BMS is designed so that it does not use an HVC, but instead depends on waiting for all cells to be shunting before it cuts off, then it would indeed balance all the cells after the charger is removed.
But I doubt many BMSs work that way, instead cutting off as soon as the first cell reaches HVC after it's begun shunting. Then after the shunt drains the excess off of that cell, it turns on again, pulling power from the charger until a cell reaches HVC, with one or more cells in the process of shunting. That process would then repeat until any cell that is still significantly lower than the others is brought up to the same state of charge as the rest of them. On badly imbalanced packs, it can take days or more for this to happen, at the very low shunting rates most ebike BMSs have.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby GGoodrum » Sat Oct 15, 2011 11:09 am
amberwolf wrote:Not exactly: If the charger is removed, the BMS would then drain down the high cell(s), but it cannot then top-off the still-low cells that were below the HVC.
On our Zephyr and Zephyr Lite BMS units, we actually have two HVC trip points. The higher of the two is used as a "failsafe" that keeps a cell voltage from going too high.When this happens, the charge current will be cut for about a second, or so, and then if the voltage is still too high, the cycle will repeat. This won't ever happen under normal conditions because the this "failsafe" HVC set point is higher enough higher than the charge to voltage that the shunt circuits alone are usually enough to keep the cell voltages in check, even for moderately imbalanced packs.
The second set of HVC signals are set to trip once the shunt circuits are in full operation. What the charge controller does is it waits for all of these to be set, and then it signals the end-of-charge condition and shuts off the charge current. This way the charge current is still there to help the low cells catch up, while it keeps the higher cells at the charge to point.
You are right about one thing. Most of the "commercial" BMS units that are out there (Signallab, etc...) have extremely low shunt currents, on the order of 50-75mA. That's way it can literally take days to balance a pack. The full Zephyr BMS boards have about 600mA of shunt current and even the "Lite" versions have about 150mA.
-- Gary
GGoodrum
Postby acuteaero » Fri Mar 23, 2012 12:29 am
Meet my new 1kw/75V charging setup- I like these supplies a lot.
acuteaero
Postby heathyoung » Mon Mar 26, 2012 7:45 pm
Yeah I mentioned these ages ago, just don't have the power density of the other models.
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
Return to Battery Technology
Users browsing this forum: Bing [Bot], Secret1511, snath and 6 guests
cron
