Re: Your Creation's Before & After Pics
Postby friedwires » Sun Aug 28, 2011 11:59 am
nice work! where did you get that threadless stem extension? i've been looking for a way to raise my bars about 2"
friedwires
Postby FastDemise » Sun Aug 28, 2011 12:49 pm
I got the bike off Craigslist with the extender but I believe I saw them at my local REI store. Hope that helps.
21" Hardtail, Docs Torque Arm, Lipo 20s2p, ebikes.ca 9C 8x8 and Lyen 6fet (both Mineral Oil cooled)
FastDemise
Postby icekreme1002 » Sun Sep 18, 2011 3:14 am
Before....
After.....
Seeing I didn't know much about bikes I decided to build one part by part so when it came to servicing i would know what to do.
There 18s2p lipo stuffed into the battery box, and the motor is the hs3540 although i really wish i went the HT instead.
Since the 'after' i have made much larger cooling holes in the motor, and a vent/window in the battery box.
Just sorting photos to make a build thread so keep your eye out :-)
1st build - Norco Hardtail, 18s Lipo, HS3540, Lyen 18fet 45/120amps
http://endless-sphere.com/forums/viewtopic.php?f=6&t=32041
icekreme1002
Postby iCoke » Tue Sep 27, 2011 3:12 pm
I totally love this bike. Lot's of work.
painted Motor :P
shortened controller
selfmade battery + selfmade mount
Before... A Ghost ASX 3700
After:
iCoke
Postby hillzofvalp » Tue Sep 27, 2011 9:03 pm
how much did you pay for that bike pre-electrification?
hillzofvalp
Postby lianjuin » Tue Sep 27, 2011 9:29 pm
Before:
20'' Juiced Riders ODK Utility Bicycle...
Blue side right4b.gif (100.65 KiB) Viewed 1495 times
After:
+ 9C, CA, 48V LifePO4, 22A controller, wire basket and bag of chips.
26mph, solid ride.
lianjuin
10 µW
10 µW
Postby CX » Wed Sep 28, 2011 12:35 am
Before it was just a $200 wallmart bike, now its.. Hot Wire
started in May 2007
and still a work in progress
CX
Postby iCoke » Wed Sep 28, 2011 1:48 am
hillzofvalp wrote:how much did you pay for that bike pre-electrification?
Only the bike was like... 1000 euro.
iCoke
Postby Alan B » Thu Sep 29, 2011 8:02 pm
REI Novara Bonanza AL MTB Commuter Conversion
Not complete, but up and running well enough to use. Finishing will come later.
Before
Aluminum MTB frame
Suspension front fork
After
Nine Continents 6x10
18S2P 72V 10AH Turnigy LiPoly (soon to be 3P 15AH)
Lyen 12 FET
Dual torque arms
Hayes Hydraulic front disc
Shimano XTR Rear Vbrake
Magura throttle
Rhyno Lite rims
ThudBuster seatpost
Topeak rack and trunk
covers to come soon
Details
https://docs.google.com/spreadsheet/pub ... utput=html
Build Thread
viewtopic.php?f=3&t=21390
Alan B
1.21 GW
1.21 GW
Postby Danos » Fri Sep 30, 2011 5:21 pm
Trek 4100 commuter
Before:
Trek 4100 before.jpg (116.33 KiB) Viewed 1349 times
After
Trek 4100.jpg (131.93 KiB) Viewed 1349 times
Cellman kit:
Mac 500W
9 FET Infineon 30A controller
16S4P (58V 9.2Ah) A123
Danos
Postby anothercanadian » Sun Oct 02, 2011 8:56 pm
Another kona, lipo 74v 5a(so far) and crystalyte hs sensored. The box is made of a sheet of lexan which I bought at home depot. I folded it with a heat gun than painted it.
there is not that much space in the triangular part of the frame, so trying to fit more than 5a 74 with the controller is impossible
kona left.JPG (83.86 KiB) Viewed 1286 times
It's almost a miracle that everything got inside in the first place!!!
kona right.JPG (90.79 KiB) Viewed 1286 times
Another French from Canada!
anothercanadian
Postby hillzofvalp » Sun Oct 02, 2011 9:20 pm
like it a lot... how much was that bike alone?
hillzofvalp
Postby anothercanadian » Mon Oct 03, 2011 4:27 pm
I bought it used for 500$. I think it was sold for more than 2000$ when it was new.Surprisingly stable at high speed with a double suspension
anothercanadian
Postby SamTexas » Mon Oct 03, 2011 9:28 pm
anothercanadian wrote:Another kona, lipo 74v 5a(so far) and crystalyte hs sensored. The box is made of a sheet of lexan which I bought at home depot. I folded it with a heat gun than painted it.
Nice. Is the controller inside that box too? It would be great if you can start a new thread showing the technique for folding lexan with a heat gun. I have no idea how that is done.
SamTexas
Postby hillzofvalp » Mon Oct 03, 2011 9:52 pm
you have to set up good right angle jigs and work fast with gloves to protect from hot plastic. If you over heatt it or let gravity pull it you won't get an even surface. worth experimenting over but any long lengths (15"+) get hard to bend cleanly because keeping the heat distributed is difficult...
hillzofvalp
Postby anothercanadian » Wed Oct 05, 2011 4:54 pm
Yes, the controller is in the box too. There is a finger large gap between the box and the rear shock the turn on the switch.
I used 0,093 inches thick lexan. Maybe that why I didn't have much problem with it. I used a sheet of plywood on the bottom and on top of the lexan with two adjustable clamps. To fold a long distance, you just have to bend one small part at a time ( around 6 inches) with the heat gun and continue to end of the piece. You just have to go progressively like 30 degres at once. If it starts to bubble, you've heated it to much. I pratice with a small piece first to get the hang of it. It's not that hard and if you miss one place and bubbles are showing up, paint is going to make them disappear. :P
I hope it helps.
anothercanadian
Postby SamTexas » Wed Oct 05, 2011 7:41 pm
anothercanadian wrote:Yes, the controller is in the box too. There is a finger large gap between the box and the rear shock the turn on the switch.
I hope it helps.
Great. That does not sound too bad. I'll give it a try.
SamTexas
Postby gwhy! » Thu Oct 06, 2011 5:35 am
Its a little frocker :P
Just thought I would post this up.. I have just finished it for my son-in-law :D
micks finished.jpg (136.13 KiB) Viewed 1044 times
Its not fast but it is fun :mrgreen:
gwhy!
Postby PeteCress » Wed Oct 12, 2011 9:50 am
lianjuin wrote:20'' Juiced Riders ODK Utility Bicycle...
My experience battery-wise has been that lower is better - and really-low is a *lot* better.
That one appeals for that reason.
On the pre-built electrics they sell (http://www.juicedriders.com), it looks like it could even go 4-6" lower.
PeteCresswell
FWD 400w eZee Kit, 2 Dewalt 36v batteries, Surly 1x1 full-rigid frame. Weight as ridden = 37#
PeteCress
Postby docnjoj » Wed Oct 12, 2011 2:49 pm
I've never posted my Steintrike here so without further fanfare here it is:
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby Brentis » Fri Oct 14, 2011 7:43 pm
Before a perfectly good late80's early90's XL Miyata SportRunner
The Bike 80's-90's Miyata Sportrunner ES.jpg (151.82 KiB) Viewed 1668 times
After a dirty Ghetto ho
Ghetto Bird.jpg (103.37 KiB) Viewed 1668 times
Ghetto Build 1.
ScootBike Build 2...
Strong Commuter Build 3...
Brentis
Postby sn0wchyld » Tue Oct 18, 2011 5:19 am
gwhy! wrote:Its a little frocker :P
how much does that one weigh? looks like it could be good nippy fun!
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby hillzofvalp » Tue Oct 18, 2011 4:20 pm
Just don't corner with the crank downward...
hillzofvalp
Postby gwhy! » Wed Oct 19, 2011 12:03 pm
I didn't weigh it but my bike which is nearly the same weighs 22kg but has tripple clamp forks so that one should be a tad lighter.
gwhy!
Postby gm6046 » Wed Oct 19, 2011 7:08 pm
Here is my bike.
Raleigh mountain bike with MAC 500W rear motor and Ping 48v 15Ah pack.
I made the fibreglass panels to hide all the workings. The charge port and on/off key are mounted on the left hand site in a recessed panel.
gm6046
PreviousNext
Users browsing this forum: Kepler, korpin, WhatcomRider and 4 guests
