ALL ITEMS ARE NOW SOLD.
I've edited the title and ad since all the other items have sold.
I have a 48volt ping pack, 15ah bought in December 2010. Pack has been used on a commuter build in parallel with another 48v 15 ah pack, to power a 5303 and later a HS35. Amp draw was limited to 50 amps between both packs. So the pack has presumably never seen more than 25 amps even during peak usage. At about 24 miles each way, (charging while at work for ride home) the pack probably rarely saw more than %50 usage, seeing as I did make a round trip once without charging when I forgot to bring the charger. Anyway, the pack is in good condition, and probably only has 100 or so cycles on it due to lots of bike trouble along the way (hall sensors, lacing issues, and even some spun out dropouts) all unrelated to the pack. The only sign of wear I can see is the bms tape has browned a bit (possibly from heat while charging?). All the BMS lights do turn on after charging, and the resting voltage is 58.4 volts. It is the left battery in the pictures (the one without the popped cell, that one is sold already). It does come with the original ping charger.
I accept paypal only as payment, and I will gladly ship it in the US for free, or Canada for $20.
