Bamboo Scooter
Bamboo Scooter
Postby salty9 » Tue Oct 25, 2011 5:09 am
Check http://goodcleantech.pcmag.com/travel/289426-this-electric-scooter-is-made-from-bamboo#fbid=6HKCXlpJiqV.
The stress on that sharp bend in the frame must be tremendous. I wouldn't think that bamboo could take it.
salty9
Re: Bamboo Scooter
Postby Jay64 » Thu Oct 27, 2011 7:22 pm
We might be talking about two different bends, but the one I think you are talking about looks like it is two pieces joined together, not bent.
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Re: Bamboo Scooter
Postby Kin » Fri Oct 28, 2011 1:02 am
Someone was describing to me today that you can take bamboo, denature it's bamboo-form somehow, then compress it into other shapes. There are two curves there, one obviously two pieces and the other one possibly two pieces, or simply one piece that was-re compressed into the oddly sharp curve you see. Since stuff was made with machinery, which is cooler on one level, but also less cool than some of the natural bamboo bikes I've seen on instructables
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Re: Bamboo Scooter
Postby nak25 » Fri Oct 28, 2011 8:16 pm
I wonder how many falls it can take, before it needs replacing. Didn't think bamboo was strong either.
nak25
10 µW
10 µW
Re: Bamboo Scooter
Postby Kin » Sun Oct 30, 2011 4:11 pm
Nak25, Bamboo is actually tremendously strong. It's possibly you'd want to varnish or otherwise protect the outside, but I think you'd be surprised at how well it'd hold one. One part that I like the most about this one is that the frame should provide a sort of natural shock, since bamboo flexes like a spring well.
Kin
Re: Bamboo Scooter
Postby Zoot Katz » Sun Oct 30, 2011 5:40 pm
Jay64 wrote:We might be talking about two different bends, but the one I think you are talking about looks like it is two pieces joined together, not bent.
It looks like laminations similar to bamboo flooring. The deck pieces are joined to the neck/down tube.
I wonder if the main member is carved out of a solid laminated chunk or if it's hollow.
The deck sides appear to be solid. Hope it's soy based epoxy to be green.
Zoot Katz
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: atom1025 and 1 guest
cron
