Terminating the 15Ah and 20Ah Cell-Man cells
Re: Terminating the 15Ah and 20Ah Cell-Man cells
Postby jonescg » Mon Jul 11, 2011 7:49 am
Hi guys,
After checking out the removable battery pack Dainel (Ripperton)had, I was inspired for my next electric race bike. I still want to go with A123 cells, especially since I will be able to source them through TTX-GP. I figure I could use the poly acetal plastic that Daniel has used, and opposite-stack* the cells to give me a bit more room to tension down the tabs using 2 mm aluminium and some stainless steel screws. Does acetal take a thread easily? Does it cross thread easy? I guess you could always seat some nuts into the plastic.
Since this is clearly a rip-off of Daniel's idea, I have no problem with sharing it for suggestions / improvements :)
What do you think?
EDIT: Should point out that I have drawn the cells in the left hand image just to show where they sit relative to the tabs. In reality all you will see is two folded up tabs with a bit of aluminium holding them down. The tabs would slip through 1 or 2 mm slits in the 12 mm thick plastic.
*this is what I mean:
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby Malcolm » Mon Jul 11, 2011 9:22 am
I was looking at Ripperton's pack yesterday, trying to work out how those tabs were joined http://www.diyelectriccar.com/forums/sh ... 73p35.html
It looks as if those screws go through the tabs straight into the acetal block. I'm sure it would take a thread easily, but not so sure I would want to rely on it for consistent clamping, especially if you want to reconfigure cells any time in the future. Maybe use rivnuts/nutserts?
Malcolm
Postby jonescg » Mon Jul 11, 2011 9:36 am
I was thinking you could simply countersink / mount some nuts in the holes on the back of the acetal, otherwise, yeah, those screw-in-screw things might work OK.
I will eventually get a plywood mockup made of my idea. I reckon I'll need lots of cells in series to get close to an EMRAX's operating voltage :) However, that means a stack of 110 cells, or a cartridge about 840 mm deep :eek: Might need a small crane to lift them in :)
VoltronII 8)
jonescg
Postby Malcolm » Mon Jul 11, 2011 9:49 am
The countersunk nuts would work just as well and be cheaper/easier to install, but if I was building the pack I'm sure one of them would fall right into the middle of the pack just as I was finishing it. You could minimise that risk by making the nuts a push-fit into the recesses though.
Just looking at this photo again. Is that (nickel?) strip that joins the cells in parallel deliberately narrowed between the cells to act as a fuse? It's hard to make it out.
Malcolm
Postby CamLight » Mon Jul 11, 2011 3:52 pm
Malcolm wrote:It looks as if those screws go through the tabs straight into the acetal block. I'm sure it would take a thread easily, but not so sure I would want to rely on it for consistent clamping, especially if you want to reconfigure cells any time in the future. Maybe use rivnuts/nutserts?
I agree, metal inserts pulled in from behind would be a good idea here. If they can't be used, I recommend that the plastic be threaded for the largest bolt possible using UNC (coarse) threads, not UNF (fine), and should be as thick as possible (1/2" would be great).
Even then, you can't tighten the bolt too much. And, the plastic and bolt have very different expansion/contraction rates when heated/cooled and this will encourage loosening of the bolt over time. I recommend using a threadlocker compound. But, some aren't rated for use with such a slippery plastic so check the specs.
John M.
Owner
CamLight Systems
CamLight
Postby jonescg » Wed Jul 13, 2011 12:20 am
Malcolm wrote: Is that (nickel?) strip that joins the cells in parallel deliberately narrowed between the cells to act as a fuse? It's hard to make it out.
Nope, its all aluminium. It's only thickened in the middle to allow for a fastener to hold it down. There wouldn't be much need to have a 15 mm wide strip to hold each parallel section down if the currents aren't too high. Personally I'd make them a bit thicker, but maybe not a problem for my next bike since I will only ever be pulling a maximum of 300 A through the pack. But at 360 V that's a fair bit of power :D
VoltronII 8)
jonescg
Postby adriano-brazil » Tue Nov 01, 2011 11:00 am
Friends, I can not see or download the pictures that were in the posts.
I have done my enrollment in this forum, I still can not see the pictures that friends place.
I'm in Brazil
I am studying on the issues discussed here for you.
I am very interested in learning.
Please help me.
adriano-brazil
Previous
Return to Battery Technology
Users browsing this forum: ErikDK and 12 guests
