Kepler wrote:This is shaping up to be a nice variation on the concept. Good work.
I really like the way you have locked the pivot axle to the swing arm.
I can see mechanically there are two more areas for you to attack, adjustable swing arm travel adjust and some way of neutralising the weight of the motor.
What do you have in mind here?
adrian_sm wrote:Woo hoo. First real ride, you must be pretty happy. Efficiency stats look nice. 7.9wh/km is great.
adrian_sm wrote:I am surprised that the skateboard deck grip survived. I tried something similar and the motor had too much torque, and just sheared the material. I now use something with a fabric backing to handle the shear forces, when I use grip tape.
adrian_sm wrote:As for tire wear it could be a few different things:
1) too high power. Your tire can only take so much torque before it shears the rubber apart
2) initial contact angle of motor and tire. Needs to climb the motor and not slip on first contact. Simple test put the rear brake on, light hold the motor on the tire, then try to turn the motor. In one direction it will slip, the other should climb the tire. If it slips in both directions, then you need to have a more perpendicular contact angle.
3) amount of tire/motor engagement. Not enough slips at high torque, too much and it distorts the tires across the motor causing additional tire wear.
4) drive angular alignment. The motor shaft may not be parallel to the tires rear hub, this will cause the motor to shear tire side ways. Have a close look at the rear tire as you engage the motor under power, and make sure it is not pulling the tire to the left or right, if it is rotate the drive on the seat tube and check again.
5) acceleration rate of the motor. If it ramps up too quickly it can rip through the tire too.
6) Tire pressure may have some impact, but I have done enough testing to understand it properly yet.
adrian_sm wrote:As for my interface, it is so close now. It will eliminate all the non-alignment issues mentioned above.
I am really happy with how it is turning out. The firmware side is pretty settled now, but I do need to clean up the hardware side a bit. Now that I have made and tested a few I have found a few minor things that need tweaking. I totally underestimated how much time and effort it would take to make something that functions so simply on the outside.
- Adrian
adrian_sm wrote:2) initial contact angle of motor and tire. Needs to climb the motor and not slip on first contact. Simple test put the rear brake on, light hold the motor on the tire, then try to turn the motor. In one direction it will slip, the other should climb the tire. If it slips in both directions, then you need to have a more perpendicular contact angle.
adrian_sm wrote:3) amount of tire/motor engagement. Not enough slips at high torque, too much and it distorts the tires across the motor causing additional tire wear.
adrian_sm wrote:4) drive angular alignment. The motor shaft may not be parallel to the tires rear hub, this will cause the motor to shear tire side ways. Have a close look at the rear tire as you engage the motor under power, and make sure it is not pulling the tire to the left or right, if it is rotate the drive on the seat tube and check again.
adrian_sm wrote:5) acceleration rate of the motor. If it ramps up too quickly it can rip through the tire too.
adrian_sm wrote:6) Tire pressure may have some impact, but I have done enough testing to understand it properly yet.
Users browsing this forum: Kabbage, kunting, Majestic-12 [Bot] and 3 guests
