jonescg wrote:DAMMIT! Who has $5000 I can borrow?
http://www.ebay.com.au/itm/2008-Honda-C ... _500wt_950
I'm worried it might be hot
Otherwise there is this option:
http://www.ebay.com.au/itm/SUZUKI-GSXR1 ... _500wt_950
However the 2004 Blade trackbike is probably the best deal going.
Damn I wish I weren't so broke right now
jonescg wrote:Holy CNC shitcakes. I had no idea this sort of thing would be so expensive!
Otherwise would I be better off making a mould so I can fill it with HDPE or something? Apparently it doesn't take a thread well, so I could mount M4 nuts behind the front plate, but again, recessing all 32 nuts per plate would take a long time... More thinking required...
Hillhater wrote:Chris... do you really need enough tab protruding to "punch a 5mm hole through" .. ?
If you have enough ( 5mm ?) tab to fold down, can't you simply clamp that to the board with a clamp plate covering the two tabs , with the screw in the middle ?
just a thought.
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: Drunkskunk and 2 guests
