oatnet wrote: I increased the rim diameter to keep the motors equivalent to keep the motors on the same playing field
liveforphysics wrote:That's not how it works my friend. Anytime you increase wheel diameter, you simply decrease the power the motor is capable of outputting. If you find yourself in a situation with a motor that has too low of a kv, you simply increase the voltage to reach the RPM you require.
liveforphysics wrote:That lighter stator with less coreloss and a much better magnetic design is going to love spinning at higher RPMs than the 54xx is going to want to see.
itchynackers wrote:What are the benchmarks? Are we having an acceleration shootout? Top Speed without melting? What?
oatnet wrote:itchynackers wrote:What are the benchmarks? Are we having an acceleration shootout? Top Speed without melting? What?
I wet my 'Depends' above 50mph on a bicycle, so I'll leave the Top Speed without melting to young bucks like Luke and Doc. I was looking more to compare acceleration at different speeds, efficiency (although I expect similar results), some handling at those speeds - just to compare and contrast on the butt-dyno.
-JD
hillhater wrote:Just curious:-- why use the Norco's ..when all those TF750's are stacked around there ??
Microbatman wrote:Are those modular(removable) drop outs in the Norco Frame ?
Are you planning on making a custom machined steel torque arm droppout to be compatable and simply bolted into the frame replacing the stock ones?
Microbatman wrote:It will be very intresting to see where you put the batts in that teardrop shaped frame triangle.
Kepler wrote:Looking forward to seeing how these builds shape up. Love your work oatnet.![]()
The bike pictured a couple of posts ago is already one of my favorite hub motor powered bikes on the forum. Keep up the good work.
Kepler wrote:I really need to try a front battery mount setup. Makes sense to balance the bike weight with that battery position when using a hub motor. Biggest issue in my opinion is keeping the bike looking reasonably elegant. The Pelican case setup does the best job in keeping the build tidy I have seen so far.
veloman wrote:Slap a fairing on the front of the battery box. Say it's to keep the battery dry in the rain
Users browsing this forum: competitions and 7 guests
