Floont wrote:
For curiosity sake, for those who use dual throttle setups for their 2WD's, which side do you control the rear motor from and which side do you control the front motor from?
sangesf wrote:...
Left Throttle = Front Motor
Left Brake = Front Brake / Rear Brake Light
Right Throttle = Rear Motor
Right Brake = Rear Brake / Motor Cutoff for Both Motors...
Floont wrote:sangesf wrote:...
Thanks! That's the way I think it ought to be. The motor throttle goes with the brake for that wheel... very intuitive.
cassschr1 wrote:2wd rocks, no doubt about it. Don't knock it till you tried it.I'm the guy Methods built the throttle for in that thread. My bikes are both tidal force's. One is a dual 9c 2807 60v 20a V konion and the other a 5305 28s5p a123. These are the only e-bikes I've rode. Cass
sangesf wrote:Are they both running off of one battery or two?
sangesf wrote:...Every ebike I've ever bought had a motor in the rear and the throttle on the right...
Just easier to setup starting from that configuration anyways.. So when adding a second (front) motor, the new throttle has to go on the left anyways.. Hehe
hjns wrote:Wow, KF!
Did I count correctly, and did you carry 13P 15S with you? Assuming 5Ah per lipo, that would be 3.6kWh....
Alan B wrote:Kingfish, why do you think the 5V regulator was the problem with the throttle dropping out?
Alan B wrote:It is very important that the controller grounds be referenced together and have very low impedance between them if a common non isolated throttle is to be used. Or use an isolation amplifier to re-reference the throttle signal to the local ground on the slave controller.
Could this have happened to KF's setup?
hjns wrote:Alan B wrote:It is very important that the controller grounds be referenced together and have very low impedance between them if a common non isolated throttle is to be used. Or use an isolation amplifier to re-reference the throttle signal to the local ground on the slave controller.
Hi Alan,
I am working towards a 2WD setup now. I can always try the dual-Hall-single-throttle solution, but I am interested in hearing how you would re-reference the throttle signal to the local ground on the slave controller. How would you do it?
thanks!
Alan B wrote:Perhaps a better choice is a difference amplifier. Here is one example:
http://cds.linear.com/docs/Datasheet/1990fb.pdf
Fishmasterdan wrote:1 wheel drive= Grin
2 wheel drive= Permanent smile and giggles.
Seriously;
I have burned out SEVERAL motors and ESC's over the last few years .
I have not been able to burn out my 2wd set up. Dual halls throttle, Cell man made the whole package and it just plain works.
My personal opinion;
2wd if you want a motorcycle. To heavy to be a fun bicycle.
1 wheel drive for assist. Keep the weight down.
Users browsing this forum: andrewlsu1, Google [Bot] and 6 guests
