Letting the cat out of the bag...........
Postby recumpence » Mon Dec 19, 2011 6:07 pm
Hey Guys,
I wanted to share with you Guys what I am working on; If you remember a couple months ago I asked what you guys would like me to work on next. Well, I got a lot of good input and I spent a bit of time talking to some specific people about this new project. Here are the primary suggestions I recieved;
#1 Not high power. Many people want a federally legal system.
#2 Find other motor options to add to my normal Astro motors.
#3 Mutiple ratios.
#4 Light weight.
#5 Low cost.
Ok, it will be very difficult to meet all of those challenges. However, I can meet most of them. Here is what I have been designing (trying to meet as many of these suggestions as possible).
I am designing a complete crank drive system. :D
Here is the list of components related to this;
#1 Motor. This system will be compatible with Astro motors, but for those who are looking for lower power, lower cost, and lighter weight while retaining quality, it will also be compatible with a small outrunner based on a standard Maxx Products outrunner. This motor will retail for under $200. The normal motor is $180. However, my motor will use a longer shaft and a few other minor changes. Also, this motor is readily available and I can pick them up 15 minutes from my house! And if someone manages to smoke the motor, the stator/windings retail for $50 and are easy to replace! This motor uses high-end bearings and is, overall, a very high quality motor! I am thrilled to find this option so close to my house. Also, these motors have been tested in very dirty environments. So, I am confident it will run well in this application. It is also a very quiet motor.
#2 The drive itself is based on my V4 drive, but with a few specific changes; First, it will be lightened a bit. Second, the ratio of my V4 drive is 4 to 1. This drive will be a belt drive 9.5 to 1 ratio from motor to jackshaft. Then it will use a 13 tooth freewheel to crank chain drive. This will allow for a deep enough ratio in just two stages to match pedal cadence while retaining high enough RPM to make use of a relatively small motor. Also, this new drive will retain my proven slipper clutch in hard-coated aluminum to save weight. That will help protect the pedal drive system and prevent unwanted wheelies if set properly.
#3 The drive unit will mount firmly to the bottom bracket bearing cups on each side with a simple strap holding it up to the bottom of the downtube. This system should fit 90%+ of the frames out there including some very odd styles. It will easily adapt to either 68mm or 73mm bottom brackets. Lastly, the drive will not hang below the bottom bracket. It will tuck up to the frame very well without screwing up ground clearance. It should also be relatively quiet.
#4 The freewheeling crank. This is one thing I am really excited about! It will use a second support bearing to eliminate the overloaded freewheel bearing issue that is so common with freewheeling cranks. It will also use standard 130mm BCD chainrings for multiple ratio options. I am very excited to have come up with a solution to the FW crank bearing issue. I am not the first to do this, but I think it is the first to be readily available. My system will come with this new FW crank system and a new lengthened bottom bracket.
I am planning on making this availble in a couple different kits. First it will be available without electronics for those who want to find their own controller and batteries. Second, it will be available as a complete kit with battery pack and charger as a complete bolt-on system. The battery will be mounted to water bottle bosses and will be either 6S or 8S (to be determined).
This system will come as a kit with complete assembly instructions, setup instructions, and tuning instructions.
This is not a concept, it is already completely designed and most parts are in the que for manufacture. I have the pulleys in stock right now.
I was planning on leaving this as a secret until it wwas ready for market. However, I have found the need to ask for more input and I wanted to run some things by a wider audience than just the few guys I have told so far. Also, this has become a very large project. I am shocked how many individual suppliers, machineshops, and manufacturers I have had to become connected with to make this happen. I wanted to share this with you so you guys know what I am working on and why it is taking so long. I am used to developing and refining drive systems. However, the actual drive system is the smaller portion of what this project entails.
At any rate, I am pushing to make the highest quality crank drive that uses the stock derailer and pedal system that I can while keeping an eye on the cost. It looks like the kit consisting of motor, drive unit, FW cranks with chainrings, all mounts, motor and all hardware will come in at around $1,500. With a basic lipo pack, mount and charger it will be around $2,000. I wanted to make sure the quality remained really high. But, I wanted to try to keep costs down. My goal with this system is to make sure nothing needs to be upgraded. I want it to run reliably and smoothly right out of the box. I know $1,500 may not seem like low cost. But, the quality and quantity of components used dictates this. That being said, I find the cost of a couple systems out there to be obscene and I am trying to offer as much as I possibly can for the best price I can while covering the huge development time related to this project. What I am trying to achieve is the best, most complete non-hub system with features asked for by most people. That will help increase quantity, lower cost, and increase product availability while reducing wait time.
Oh, I am about a month and 1/2 away from having a prototype system complete for testing and another month for production.
Also, this is not replacing my current drives. It is an additional system to add to my line. :)
What are your thoughts?
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
10 GW
10 GW
Location: On Earth right now. That can change at any time, though..........
Re: Letting the cat out of the bag...........
Postby Alan B » Mon Dec 19, 2011 6:32 pm
Wow. Verry interesting!
Alan B
1.21 GW
1.21 GW
Postby lostrack » Mon Dec 19, 2011 6:33 pm
I think this is a great idea. And if it looks anything like your existing creations, it should be a sufficient bar-raiser to push the whole genre forward.
Well done Matt! (full praise pending pics...:) )
Tom
lostrack
Postby Hillhater » Mon Dec 19, 2011 6:38 pm
Matt:.. What power levels do you plan to cater for with the Maxx motor ? ..500 -750 W ?
..will you be offering a "bare" hardware kit ?,.. no electrics or motor ?..at what price ?
We know your products are first class in design, manufacture, and support, but i fear your price point will exclude a large number of customers looking for something better than a Cyclone. :cry:
Hillhater
1.21 GW
1.21 GW
Postby neptronix » Mon Dec 19, 2011 6:43 pm
$1,500 is too hard to swallow for me, as i am looking for something better than a cyclone kit but don't want require perfection.
I wish you the best of luck however.
neptronix
Postby recumpence » Mon Dec 19, 2011 6:49 pm
The motor I am specing is good for 800 watts continuous (as in endlessly continuous) without supplemental airflow, 1,000 watts with modest airflow and 2,500 watts peak for short bursts.
Yes, I can sell the hardware without anything else.
The main issue is the long parts list;
Reduction unit consists of 18 parts
Mount kit consists of 7 or 8 parts
freewheeling crank is crank arms, bottom bracket, spindle, retainer, spacer, bearing, sprocket adaptor, White Industries freewheel, two chainrings, bolts, etc.
There are just so many parts that the cost is high no matter what I use. For example, when I looked at the lowest possible cost, I found that it only saved a couple hundred bucks and the quality went into the toilet. However, increasing the quality higher than where it is at now would cost a huge amount more. So, this seems to be the sweet-spot.
It just happens to be a very involved kit with lots of parts and huge development time. For instance, the large 95 tooth main pulley is $90 by itself! I paid a bit less than that, but I had to order 20 of them. Cost is a constant battle. Cost really can only go lower if everything is ordered in very large quantities. That is something I would love to do when I can get to that point.
Another problem is, Cyclone stuff has issues I am not willing to live with, and the next option is Eco-Speed for $2,700 without pack or charger! Their price goes up to $4,000 with pack and charger. That is insane.........
Matt
recumpence
10 GW
10 GW
Postby adrian_sm » Mon Dec 19, 2011 6:54 pm
Sounds fantastic. Especially the fact you plan on offering a complete package batteries, charger and all. That is the major hurdle in taking products from ES types, to the consumer level.
The drive unit sounds great, can't wait to see it. Already thinking it might be time to rip the hub motor of my full suspension bike, and transplant this in....
Also very interested to see the battery solution you have. Love the idea of using the bottle mounts. What is the deal with shipping LiPo these days in the US? I thought any ebike sized pack had severe restrictions around them, with a lot of testing required before you were allowed to transport them legally. :cry:
Price will always be too high when you ask people here. More important to make sure it can compete with other commercial products.
Best of luck, if this is straight forward to install, complete, and suits a lot of bikes, as long as the price is reasonable compared to other things on the market, you will do very well.
- Adrian
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby recumpence » Mon Dec 19, 2011 6:57 pm
adrian_sm wrote:Sounds fantastic. Especially the fact you plan on offering a complete package batteries, charger and all. That is the major hurdle in taking products from ES types, to the consumer level.
- Adrian
Shipping restrictions are based around battery capacity. I can ship a 6S 8ah pack legally. So, that is what I am specing the system to use (hopefully). A second pack can be shipped in a second box and simply plugged in.
Also, to give you an idea of how committed I am to this project, I purchased a set of Kreitler training rollers to do indoor testing of this system under controlled conditions this winter. I will be able to heat my test room as hot as I want and run in whatever gear is needed to achieve a given load (amp draw) and monitor motor heat, current consumption, and other variables while "Riding" the bike. This is testing I have never been able to do before. It will be very valuable information for full development of the system.
I have met with the motor manufacturer and they are willing to work with me to do "Anything I want" (obviously withing reason). I have been meeting with machine-shops, engineers, and other individuals regarding this. I am also looking into patents for a couple aspects of the system.
Matt
recumpence
10 GW
10 GW
Postby adrian_sm » Mon Dec 19, 2011 7:17 pm
recumpence wrote:Shipping restrictions are based around battery capacity. I can ship a 6S 8ah pack legally. So, that is what I am specing the system to use (hopefully). A second pack can be shipped in a second box and simply plugged in.
Ahh. Good plan. Does limit the range and therefore user appeal a bit, but if you can add an extra battery easy enough that should solve that problem. Any pics of the battery mounting solution. Very interested to see how you have done this to make them weather proof and expandable.
Great idea. I bought a cheap bike trainer but found that it heated up very quickly at eBike type power levels and transferred that heat to the roller that then softened the tire. Not good for a friction drive load test. :roll:
Looks like the Kreitler nicely decouples the power sink and the roller, so this should be a much more suitable. Actually look at it a bit more, this could probably turn into a nice little ebike dyno, wonder much much those 4.5" rollers weigh :D
adrian_sm
Postby MitchJi » Mon Dec 19, 2011 8:24 pm
Hi Matt,
Congratulations :D, sounds great, IMO the price is reasonable and I think it will sell very well. Maybe Justin would be interested in carrying it?
Matt wrote:#3 The drive unit will mount firmly to the bottom bracket bearing cups on each side with a simple strap holding it up to the bottom of the downtube.
Do you plan to offer this BB mount for use with your Davinci and V4 drive units?
Best Wishes!
Mitch
MitchJi
Postby Whiplash » Mon Dec 19, 2011 8:46 pm
Wow Matt! You arevdoing what I wished I had the time and money to achieve! I can't wait to see it! Do you have any drawings yet? I am sure we would all love to see em!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby AussieJester » Mon Dec 19, 2011 8:48 pm
Sounds like another great product Matt, good to hear its suitable for non-astro motors too. :wink:
KiM
AussieJester
Postby adrian_sm » Mon Dec 19, 2011 9:02 pm
recumpence wrote:And if someone manages to smoke the motor, the stator/windings retail for $50 and are easy to replace!
8)
adrian_sm
Postby Zerox » Mon Dec 19, 2011 9:13 pm
Kudos Matt, Ive been following since 2008 and feel like I Know many on the forum personally at this point. I registered today just so I could say thank you and keep up the good work
Zerox
Postby recumpence » Mon Dec 19, 2011 10:37 pm
I am doing everything I can to make sure everything possible is reverse compatible with my previous drives. So, the bottom bracket mount is designed with the same bolt patern as my previous drive systems. Also, the jackshaft bearing tube, jackshaft, pulleys, belt, clutch, and motor plate are all compatible with each other. So, I will end up with a wide range of ratios, motor plate styles, mount foot styles, and frame mounts that are all mix and matchable. :)
Matt
recumpence
10 GW
10 GW
Postby StudEbiker » Mon Dec 19, 2011 10:38 pm
Sounds like a great product. At that price point I think many, including myself, will be interested. Can't wait to see pictures.
TidalForce S-750-(build #2) w/9C rear w/EV Components Headway 36v 10ah LiFePo4 pack: http://endless-sphere.com/forums/viewtopic.php?f=6&t=15443&hilit=+headway+rack+pack
Bike-E (Build #3, mostly done)- 400W Kollmorgen mid-drive: http://endless-sphere.com/forums/viewtopic.php?f=28&t=25980#p375646
My Bike E Facebook group: http://www.facebook.com/groups/165756106813440/
"Facts do not cease to exist because they are ignored" - Aldous Huxley
StudEbiker
Postby flyinmonkie » Mon Dec 19, 2011 11:08 pm
Sounds fantastic Matt. A qaulity mid priced kit between the cyclone and the ecospeed. Also to have the variety of options (motors, ratios, batteries, etc) is a great idea. You can sell complete kits to average punters and parts to ES members.
I love watching what you come up with. I am looking forward to seeing this one. The price sounds great for what you get. Many people want the cheapest to start with, but soon upgrade when they want better quality. Others look for the middle of the road to get the quality without paying crazy prices. And of course there are those that want top of the line and pay what ever it costs.
You now provide the 2 most important segments of the market, the middle and the hight end. Let others deal with the low end as it usually doesn't have the quality that is synonomous with your name.
Clay
flyinmonkie
Postby recumpence » Tue Dec 20, 2011 7:55 am
This would be mearly impossible without the first drive systems being developed and debugged because that allowed me to make an altered version of my V4 drive that I know works and spend the new development time on the FW crank, bottom bracket mount system, and other bits I have never made before. I did the exact same thing when I developed my RC helicopter; first I developed individual upgrade parts of an existing helicopter, then using those parts as a foundation, I developed the last few bits required for a complete helicopter. The project as a whole would hvae been too time consuming and too costly to do all in one shot. Same here. This would have been a bit too big for me to do all at once, or it would have taken well over a year to do. As it is, it will take a total of about 4 months from inception to production.
Matt
recumpence
10 GW
10 GW
Postby recumpence » Wed Dec 21, 2011 4:28 pm
Hey Guys,
One thing I forgot to mention about this drive system;
The motor plate can rotate on the jackshaft bearing tube identical to my V4 drive. So, the motor can be up against the under side of the downtube or swung down to be just in front of the bottm bracket, or anywhere in-between. That should help with various frame layouts because in some situations the motor would be best in one position and in other situations, it would be best in a different position.
I am doing everything I can to make this system as universally compatible as possible.
Matt
recumpence
10 GW
10 GW
Postby slacker » Wed Dec 21, 2011 5:16 pm
sounds like a great product and alternative to hub motors.this may be a stupid question but will this system work on a tadpole trike?i acquired a terratrike path dl and am exploring alternatives to hub motors.the reason i think this may be a stupid question is because of the trike in your signature and youtube videos.
slacker
Postby recumpence » Wed Dec 21, 2011 6:30 pm
Yes, the drive would be under the pedal boom with the freewheel just behind the chainring. That is one application I want to make sure I cover because trike customers seem to be very open to electric systems.
Matt
recumpence
10 GW
10 GW
Postby Tench » Wed Dec 21, 2011 6:40 pm
I will look forward to seeing this, i had allready decided my next build was going to be an RC running through the gears, price sounds right to me for an out of the box solution.
Simon.
Project Two viewtopic.php?f=6&t=37489
Project one viewtopic.php?f=28&t=20304&hilit=tench
The uk's first Stealth Bomber
Tench
Postby MattyCiii » Wed Dec 21, 2011 10:54 pm
Matt,
You clearly have a lot invested here - time and talent, yes, but real dollars too. Sadly though if the low volume sweet spot you described above s too expensive for the market sweet spot, you are the one left holding the bag.
Do you know about KickStarter (.com)? It's a place where you can essentially crowd source venture capitol for a project. People commit to buy, but if not enough leave a deposit to reach the funding goal, all bets are off for both buyers and seller. I think it's a great concept, and just this week I received a product funded through kickstarter (a new kind of bicycle lock, http://tigrlock.com/pages/).
Anyhow, $1500 is not too rich for my blood. I'll be watching closely and ordering one when the time comes.
Matt C
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Postby maxwell92036 » Wed Dec 21, 2011 11:22 pm
Good products sell for reasonable prices and looking at your work and attention to details I am sure you will do well. You could price it at 2 dollars and some people would say that it is too much! My main sport is mountain biking and good mountain bikes start at least at $1,000 and many are over $4,000 and some over $9,000! If you want quality you have to pay for it. Right now we have been conditioned to buy cheap and then throw it away and then to move on to the next thing.
maxwell92036
Postby damonjackson_spl » Thu Dec 22, 2011 5:18 am
Great sounding product but the most important aspect that seems to be missed is the price. Your volume could exponentially grow to massive production if you made a product better than cyclone but not as exxy as ecospeed or ego.
Still seems like a boutique type drive, need something around $800-$1000
With lower power can't you go cheaper and smaller belts?
the ALL MOUNTAIN - Commencal meta 55
the BMX - Sputnic Skyline (park)
the City - Kona Dew Deluxe 29er
the Ebike - Santosa ALPHA FD (dirt jumper)
damonjackson_spl
Next
Users browsing this forum: panurge and 7 guests
