NeilP
1 GW
Ouch. Not a simple conection then. Beyond what I can knock up in the shed
Cheers
Cheers
o00scorpion00o said:That's a beefed up controller if ever I saw one!
o00scorpion00o said:I just tried flashing new settings into the controller and the motor won't turn, It flashed fine, so whatever is different with this controller I don't know. I sent Lyen a message hopefully he can set me straight!
NeilP said:o00scorpion00o said:I just tried flashing new settings into the controller and the motor won't turn, It flashed fine, so whatever is different with this controller I don't know. I sent Lyen a message hopefully he can set me straight!
what software did you use when you flashed the controller that no longer works? the Lyen software or the one from cell man? Earlier you said you have the software from cell man, yet you talk of contacting Lyen ...so i assume you have a Lyen controller? Maybe try with Lyens software or XPD
o00scorpion00o said:Here you go, hope this helps!
NeilP said:Hi Sorry to bug you again...but could do with one more pic if you have a moment. Pictures helping, yes, but one issue..
What happens to the black ground wire at the USB plug end? It comes off the controller board header, via the black plugs at controller and programming lead then disappears when it gets to the red board on the USB plug...
On the USB plug, I see the red goes to one side of the board and yellow to the other. is that two separate connections? It looks like one side (rd is 5v (Vcc) and the other is gnd (yellow) ?
I guess the section of heat shrink just out of shot in this pic, holds the key. does yellow change to black in the heat shrink..perhaps via a push button switch?
Cheers and Happy Christmas
Neil
Mac 500, 12 fet Infineon, 16S Zippy LiPo
neptronix said:Completely different wiring scheme for the USB adapters. You also need the right software. Kinda unfortunate that it's proprietary.
I couldn't figure out how to get my lyen cable workin' on the new cell_man controllers.. so i ordered one from him -_-
DAND214 said:Mac 500, 12 fet Infineon, 16S Zippy LiPo
Are you running a MAC?
No REGEN on gear hubs, if that's the case.
Brake switch cuts power to motor and clutch comes in and coasts.
If you are running a DD then the voltage is still too low as on 15s I see regen below 59v. No res mod.
On my MAC I don't get any.
Dan
o00scorpion00o said:neptronix said:Completely different wiring scheme for the USB adapters. You also need the right software. Kinda unfortunate that it's proprietary.
You serious, the cell-man 312 is different to Lyen's 312 ? I didn't know that, the wiring looks the same ?
Cell-man's software programs the Lyen for me ?
NeilP said:I have an Xlyte EB312 from ElectricRider..possibly different again
Lyen can't help, he told me so, so it will be just a matter of waiting on Paul to see what he comes up with
o00scorpion00o said:Ah no problem Dave, you had me wondering lol
By the way, when do you expect to have the pie ? I can't wait to see how you get on with it!
