Justins presentation on Hub motors (88min YT vid)
Postby Lock » Tue Dec 27, 2011 11:14 am
If you like this message feel free to donate BeerCoins (BTC) to:
1LxAXWmbjY6SeMf8r9HHhSKt6pWyPvWg6L
Toronto Electric Riders Association:
http://www.ebikeriders.com/
Canada, eh?
Lock
10 GW
10 GW
Re: Justins presentation on Hub motors (88min YT vid)
Postby retread » Tue Dec 27, 2011 2:16 pm
Thanks for posting this Lock.
Although I was sitting right behind the camera, I'll have to watch the talk again to see if I missed any details.
Good job Justin!
"If we knew what it was we were doing, it wouldn't be called research, would it?" - Albert Einstein
retread
Postby Farfle » Tue Dec 27, 2011 2:41 pm
Wow, LOTS of good information there, I love the water ingress-egress problems, never expected water to wick thru the seals at such a speed.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby amberwolf » Wed Dec 28, 2011 12:27 am
"I've amassed an enormous amount of experience, most of it unwanted, some of it enlightening" :lol:
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby parabellum » Wed Dec 28, 2011 1:40 pm
Thanks, Lock for posting, Justin for outlining problematic and ideas for solutions. :)
parabellum
Postby Ypedal » Wed Dec 28, 2011 2:00 pm
awsome video.. i love the geared to DD prototype idea !!!
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby ZOMGVTEK » Wed Dec 28, 2011 10:57 pm
Nice video with some useful insight.
YouTube never fails to disappoint with its streaming speeds. Is it that common to not be able to stream YouTube videos, at any reasonable quality? It took over 3 hours to download the 1080P version, meaning it would take about 2 hours of buffering before it would play uninterrupted. It's not my network speeds, its just them.
ZOMGVTEK
Postby ohzee » Thu Dec 29, 2011 12:29 am
I just grabbed the 1080 version in under 30min , but i used some you tube down loader.
http://www.youtubedownloadersite.com/
Also agree some good information in this video. Justin is pretty good on camera talking to an audience I enjoy watching him.
ohzee
Postby Alan B » Thu Dec 29, 2011 1:01 am
Very nice, thanks to Justin et al.
So the Magic Pie has no advantage over the 9C on the dyno. Interesting.
Alan B
1.21 GW
1.21 GW
Postby MattyCiii » Thu Dec 29, 2011 11:24 pm
WOW.
Thanks Justin for all the intellectual effort and having a passion for the sport.
Thanks Lock for posting the video.
F'n wow.
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Postby spinningmagnets » Fri Dec 30, 2011 10:25 am
...I love the geared to DD prototype idea !!!
At 1:14:45 near the end. It sounds like a retro-direct (Miles?), and it looks like he is showing a prototype running (9C sized) at 1:16:39. In a geared hub, the motor normally runs in reverse, and the "torque improving" gears convert that movement into forward motion in the process of transmitting the power from the motor to the rim.
When he reverses the motor, it locks up like a direct drive for higher RPMs at the same volts?
E-motorcycles desperately need this, and its the next major improvement that I think would benefit them the most...
spinningmagnets
10 GW
10 GW
Postby retread » Fri Dec 30, 2011 12:55 pm
I think that's where he says my name, "Mick." He was just mentioning that we started work on this years back, and yes, e-motos are very much in need of this, and I personally can't wait for that since I'm kinda out of the ebike scene now (health). Like Justin said, the system can be automated to switch drive modes on the fly automatically, or it can be done manually, but auto would be the obvious choice for a motorcycle. 2-3 times the thrust of a direct-drive motor off the line would be pretty sweet :)
To answer your question: when the rotor is in reverse, the hub is in low mode -- like a typical geared motor -- and the hub (outer casing / wheel) spins forward at a rate set by the planetary gears and voltage on the rotor, but when the rotor is reversed, into the forward direction (so, same as the hub), it goes into direct-drive mode, which means it spins the hub much faster (1:1) for the same voltage. It's somewhat hard to see on this particular video the reversal happening, but it does so literally faster than one can discern. One moment is running backwards, the next instant forwards, with seemingly no transition. It's pretty cool to watch up close.
retread
Postby Miles » Fri Dec 30, 2011 1:55 pm
retread wrote:I think that's where he says my name, "Mick." He was just mentioning that we started work on this years back, and yes, e-motos are very much in need of this, and I personally can't wait for that since I'm kinda out of the ebike scene now (health). Like Justin said, the system can be automated to switch drive modes on the fly automatically, or it can be done manually, but auto would be the obvious choice for a motorcycle. 2-3 times the thrust of a direct-drive motor off the line would be pretty sweet :)
That's cool. I didn't know Justin had actually done some development on this when he commented before or I would have been more tactful... :)
Miles
Postby neptronix » Fri Jan 06, 2012 2:39 am
After paying full attention to the water ingestion part.. I am thinking... maybe a chain drive build next would be best..
:shock:
neptronix
Postby dogman » Fri Jan 06, 2012 6:40 pm
80% of his motor problems from water. Wow, makes me so glad to be living in a desert. I'm in ebike heaven. :mrgreen:
Gonna have to watch that about 6 times to get it all straight. The part about cogging I found really interesting. I keep saying cogging increases with the speed you try to pedal an unpowered motor. Now I have proof of Justin saying it too. The hysterisis varies by rpm.
Really great that he spends the time to investigate this stuff, and try to design a better motor.
dogman
Postby cell_man » Sat Jan 07, 2012 4:00 am
Very interesting and informative presentation.
I had the pleasure of meeting Justin in November when he was over in China. He was great and gave me lots of useful info, he stayed all day at my place and got a Taxi back to Ezee late in the evening. Justin is so free with his info, very generous indeed. Can't fault him, apart from he's maybe a bit too smart..... :)
http://www.emissions-free.com/ has just come online. It's a bit naff at the moment, but it can only get better :)
Drop me a line on emissions-free_worldwide(at)hotmail.com if you want to discuss any products I stock or you would like to source in the future.
cell_man
Postby bigmoose » Sat Jan 07, 2012 9:10 am
Great presentation! The you tube title says it was given at VEVA. Anyone know what that is? Vancouver Electric Vehicle Association?
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby Lock » Sat Jan 07, 2012 11:39 am
bigmoose wrote:Great presentation! The you tube title says it was given at VEVA. Anyone know what that is? Vancouver Electric Vehicle Association?
Exactly right:
http://www.veva.bc.ca/home/index.php
"On paper" lots of content about electric cars but they have a nice sub-set of ebikers... They meet once a month for "The Kilowatt Hour":
http://www.meetup.com/vancouver-electric-vehicles/events/40850122/
l0Ck
Canada, eh?
Lock
10 GW
10 GW
Postby El_Steak » Sat Jan 07, 2012 6:15 pm
Very impressive. Great to see someone this smart so passionate about ebikes.
TidalForce S-750 frame
Rear 2807 in a 24" wheel fed by a Methods 100V 100A controller
LiPo config: 24s3p 15ah
All the details here: viewtopic.php?f=6&t=17166
El_Steak
Postby darkshirikens » Mon Jan 16, 2012 6:25 am
I have to say that has to be the best and educational videos I've seen Justin do, I also admire his dedication to the ebike revolution like some of the motors i seen on his videos ive never seen the insides of them and always have wanted too just to see whats out in the market of LEV's thanks to his videos i feel as though im getting a little closer to what kind of knowledge i want to have about electric motors in particular :D
Schwinn Sidewinder Crystalyte 7240 controller, X5305 motor, Headway 72v 12ah 50/100 bms done !!!
Next project on way: Crystalyte Ht rear 3525
darkshirikens
Return to Motor Technology
Users browsing this forum: No registered users and 3 guests
