EV Chopper Project
Re: EV Chopper Project
Postby Hugues » Wed Dec 28, 2011 11:10 am
Great project !
I'm dreaming of building myself an electric chopper.
I like your idea of filling up the void left by the engine, looks great.
If i had time and money and knowledge i would buy this baby from Big Bear Chopper
http://www.bigbearchoppers.com/bikes/sled/prostreet.htm
and convert it to electric.
They sell the parts separately in kit if i understand well.
Keep us posted.
Hugues
Switzerland
Mountain bike
XC-204 -> Crystalyte HT3525/Infineon ctrlr 40 A EB712XC board/LiPo 88 V 10ah
All Terrain Vehicle
Hanebrink -> Crystalyte HS/Infineon ctrlr 20 A/Allcell Li-ion 36 V 10ah
Motor bike Cruiser
My build thread here
Hugues
Postby allen_okc » Wed Dec 28, 2011 3:08 pm
thats a pretty clean chopper, the next bike i build will be more of a true custom chopper like that...
long custom forks wide rear tire for that more of a traditional chopper look...
this project was more about how to get that engine look out of a battery box so a clean chopper like the one your showing me can look more natural and still be a EV...
anyway i hope you can get one going for your project, i would definitely like to see more EV's with that kind of a customization applied to it...
and Thank You for the kind words...
For Everything There Is A First Time...
http://www.youtube.com/watch?v=dI3nbn0M ... re=related
allen_okc
Postby Jay64 » Thu Dec 29, 2011 2:08 pm
I like that cover where the tank went, looks real good. Any interest in reproducing it? :D
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby allen_okc » Fri Dec 30, 2011 9:27 am
Hello Jay - im curious is the tank for the Hurricane?
im asking because i dont have a way to do spherical shaped corners - my tank is more squared edge...
but if you want one like mine then yes i can reproduce it for you... i need lots of measurement... not in a mass reproduction mode but i could build one for you...
Im still waiting for Ed to ask for one in hopes of him building an awesome chopper, which i know his would be totally radical...
allen_okc
Postby Jay64 » Fri Dec 30, 2011 6:28 pm
No, it wouldn't be for the hurricane. I have a old school GPZ and an old school GS (but I don't have the swing arm for the GS). I like the exact look of the one you did. I wouldn't want to round it at all.
EV Bikes:
'13 Zero S 11.4kwh.
Jay64
1 GW
1 GW
Postby Jay64 » Fri Dec 30, 2011 6:35 pm
I don't know if it was shown in the pics in the 1st post, they aren't showing up for me, but do you have any inside pics/details of that battery enclosure? That is really sweet too.
EV Bikes:
'13 Zero S 11.4kwh.
Jay64
1 GW
1 GW
Postby allen_okc » Tue Jan 03, 2012 2:07 pm
here is the beginning to end of the battery box photos...
everything on this battery box is custom built by me from aluminum scraps from the sign shop...
it is insulated with rubber spray paint and three sheets of 1/16 inch lexan - bottom and both sides to prevent the ends of the headway battery cells "Headway 38120P 8ah cell (LiFePO4)" from shortening against the aluminum wall.
the battery wiring is channeled through a braided water line with air fittings at each end for the hose to clamp to.
the box is bolted down by the front and back ends only - the side covers are extruded out to allow room for fuses and charging connectors, bms and a on board charger which will added later, the outlets inside of the removable side covers allow each cell to be charged individually and tested, two external plugins for a 72 volt and a 12 volt lifepo4 charger.
the whole box without the batteries is about 25 pounds all together - it looks heavier than it is...
it will also hold hold 88 headway cells...
the whole purpose of the custom battery box is to keep the general public from tampering with the batteries, to protect the battery from the weather elements and to give a motored look for a chopper motorcycle...
the base of the aluminum box...
adding the fins...
side cover construction
almost done...
adding a way for the wires to be concealed...
allen_okc
Postby allen_okc » Tue Jan 03, 2012 2:15 pm
the batteries have been the next step to the wiring - the 12 volt system will be powered by four Headway 38120P 8ah cells...
the photo shows the beginning of the charging - when done the cells will be 14.4 volts... using EV ED's system they get a perfect charge every time...
A Special Thanks To my friends at Manzanita Micro Power Systems and to ED, Travis and Ted...
charging of the lifepo4 1P4S
allen_okc
Postby allen_okc » Mon Feb 27, 2012 2:40 pm
i finally have the sprocket and motor connected and got to paint the parts this weekend, getting closer... :D
video later this week with parts attached...
allen_okc
Postby Brentis » Mon Feb 27, 2012 2:58 pm
Great concept/execution on the Motor/Batt./Ctrl. Box. Unit.
Love the 1pg. Bobber lookin' roller.
Thats my style. :wink:
You've inspired me.
:mrgreen:
Ghetto Build 1.
ScootBike Build 2...
Strong Commuter Build 3...
Brentis
Postby Thud » Mon Feb 27, 2012 3:00 pm
NIce details there Allan.
she's definatly a looker.
get some......
Thud
Postby allen_okc » Mon Feb 27, 2012 3:24 pm
Thank You fellows...
im getting down to batteries now with a layout of 24s3p headway batteries - the box will hold 80 cells so i should be doing ok this coming spring...
allen_okc
Postby allen_okc » Tue Feb 28, 2012 9:33 am
this is just a quick video from this morning, i would like to do a more in depth video later this week...
allen_okc
Postby Brentis » Tue Feb 28, 2012 10:09 am
Man :shock:
That looks real "Pro"
I doubt that 90% of cagers & 50% of motorcyclist will even notice the electric drivetrain. :wink:
Beautiful work.
Have you built your own Stink bikes in the past?
You have skills.
Cant wait for more video action.
:mrgreen:
Ghetto Build 1.
Brentis
Postby allen_okc » Tue Feb 28, 2012 11:03 am
Thank You Brentis - one thing i learned about EV projects, there is always that next project...
allen_okc
Postby Brentis » Tue Feb 28, 2012 11:28 am
allen_okc wrote:Thank You Brentis - one thing i learned about EV projects, there is always that next project...
I can think of about a dozen guys who have quoted that line. :wink:
Myself included.
Personal dreaming of a lowish power
http://www.thunderstruck-ev.com/ac-50.html
Conversion of a Karmann Ghia.
A classy cruiser for me and my lady :wink:
K.G. coupe.jpg (53.72 KiB) Viewed 1048 times
Ghetto Build 1.
Brentis
Postby allen_okc » Tue Mar 06, 2012 10:28 am
:o another video with a better walk around - in two months this motorcycle will be running...
i dont know how far or how fast... but it will run...
allen_okc
Postby Brentis » Tue Mar 06, 2012 10:57 am
:shock:
Looks awesome.
Love the opening vid. pic.
Who did the video/animation production?
Like a crackhead fiending, More, More,More.
:mrgreen:
Ghetto Build 1.
Brentis
Postby allen_okc » Tue Mar 06, 2012 12:27 pm
i did the 3D animation, its kinda hoky...
but Thank You...
allen_okc
Postby Jay64 » Fri Mar 09, 2012 11:15 pm
Nice paint!
EV Bikes:
'13 Zero S 11.4kwh.
Jay64
1 GW
1 GW
Postby allen_okc » Thu Mar 15, 2012 9:28 am
did a light test and security alarm test last night - everything working except for the right hand spot... its fixed now...
all i need is a lot of batteries now, and i can start riding it...
allen_okc
Postby Hugues » Thu Mar 15, 2012 11:27 am
Pretty cool the displays on the fuel tank ! I might steal your idea !
You're gonna display amps, volts and things like this ?
I need to get my own project out of my computer and on the shop floor now !
Hugues
Switzerland
Mountain bike
All Terrain Vehicle
Motor bike Cruiser
Hugues
Postby allen_okc » Thu Mar 15, 2012 11:32 am
Thank You Hugues - you may use any ideal i have and would be honored if you did...
:D Im really looking forward to your project, cause i know its going to be very very awesome...
8) CHOPPERS ROCK...
allen_okc
Postby Xanda2260 » Thu Mar 22, 2012 7:02 am
Cant believe I missed this! Absolutely awesome bike!
I love it!
The White Warrior - viewtopic.php?f=6&t=33918
Homebuilt 40mph+ tadpole!
Xanda2260
Postby granolaboy » Fri Mar 23, 2012 6:58 pm
Xanda2260 wrote:Cant believe I missed this! Absolutely awesome bike!
I love it!
same...unbelievably cool!!! really nice work!
gio 500+ 60v shunted
gio 500 60v shunted
2009 motorino xph
granolaboy
PreviousNext
Return to E-Scooter and Motorcycle Photos & Videos
Users browsing this forum: No registered users and 3 guests
